Vediamo Intro - Mercedes Benz SLK Forum
Star Diagnose Vediamo Coding Any links or post’s leading to pirated software will be immediately deleted. SLKWORLD is not responsible for any damage caused by miscoding, use at your own risk.
 7Likes
  • 4 Post By VII7
  • 1 Post By VII7
  • 1 Post By JudgeMing
  • 1 Post By VII7
#1 Old 08-09-2018
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 193 Post(s)
Post Vediamo Intro
So what’s this Vediamo that keeps getting mentioned and why?
Vediamo is an engineering level diagnostic and development software for Mercedes. This differs from DAS/Xentry as these are workshop diagnostic level tools, the audience for Vediamo is engineers while the audience for DAS/Xentry is Technicians. Vediamo is significantly unfriendlier and riskier than DAS/Xentry but it is also more flexible and provides more access.
With the change to always online coding in Xentry the only way to do manual custom coding in the R172 is Vediamo (Since the R172 is not supported in DAS) and this is why it now pops up here and there in the MB world.
So what is it useful for?
Installation of new/used control units
Retrofits
Fixing some annoying things MBUSA (or MB) did
jbanks15, Cobstar, Avel Du and 1 others like this.
VII7 is offline
#2 Old 08-09-2018
Other Toys: CLS63
Quoted: 193 Post(s)
Vediamo Modules
Vediamo is composed of multiple modules a brief description is provided below
Ecoute - Graphical interface for diagnostics, development and flashing. This is the module you would use to connect to a module in a vehicle, when someone references Vediamo they are usually referring to the Ecoute module.
Flash Station - Useful for mass flashing
Dimelo - Useful to automate data recording
Weker - Useful when working with a test bench
VII7 is offline
#3 Old 08-09-2018
Quoted: 899 Post(s)
Does it have any backwards support for older cars?
What do the technicians repairing cars use, e.g. to view live data, test functionality, etc?
What are the requirements to run this software?
efair is offline
#4 Old 08-09-2018
Other Toys: CLS63
Quoted: 193 Post(s)
1. Yes but usually you don't need it as DAS with developer access provides much of the functionality.
2. Technicians use DAS(older cars) or Xentry(newer cars)
3. Hardware is the same as DAS/Xentry, before using Vediamo you definitely want to have DAS/Xentry setup and working.
VII7 is offline
#5 Old 08-10-2018
Quoted: 316 Post(s)
I had to upgrade my MUX (the gizmo that comes between the PC and the OBD2 connector) to enable Vediamo access. Some kind of IC needed to be upgraded. It appeared that accessing through Vediamo also needed a different serial port on the laptop I use to access the car. Cumbersome.
But the real pain for me is the degree of difficulty working with Vediamo on controllers not knowing what all the codes and options mean. It is about the same as with the engineering menu of Comand. lots of stuff that can be changed but with most options you don't have a clue what they are doing and it could (prob. will) mean nothing because the car at hand couldn't support the option chosen. E.g. the options in Comand to enable the chairs in an SL with cooling and massage. Not likely in a R172.
What would be a tremendous help is a list of Vediamo codes and their explanations. I know that this is a very time consuming job (I did it for Comand) but until than you can do more harm to the car than help it and my advice would be to stay away unless you either know exactly what you are doing or will/can bear the consequences if things work out totally wrong.
MartinatMersea likes this.
JudgeMing is offline
#6 Old 08-10-2018
Other Toys: CLS63
Quoted: 193 Post(s)
Yes, definitely not something you want to play blindly with. I'll post some detailed coding instructions about some quality of life improvements I've done to the R172 (I just have not gotten around to it).
If buying hardware you definitely want to locate a high quality unit so that "upgrades" are not needed.
JudgeMing likes this.
VII7 is offline
#7 Old 08-10-2018
Quoted: 899 Post(s)
Are there options for DAS/SDS and Vediamo that don't involve Windows XP?
efair is offline
#8 Old 08-10-2018
Other Toys: CLS63
Quoted: 193 Post(s)
Yes but for C3 you need a serial port so you would have to go with SDconnect if you want to pair with something modern.
VII7 is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R172 SLK Class Cars > Star Diagnose Vediamo Coding
Vediamo i860 DAS/STAR Coding 20 04-20-2019 09:41 AM
Help needed - how to begin with Vediamo? os62 SLK R172 General Discussion 8 11-20-2017 10:08 AM
New Member Intro 162545 New Members Introduce Yourself Here 17 04-13-2016 10:14 PM
Not so new member intro... CCRIDER New Members Introduce Yourself Here 14 04-15-2014 01:33 AM
