Side roof trim coming unstuck - leak - connected? - Mercedes Benz SLK Forum
 10Likes
  • 1 Post By jbanks15
  • 2 Post By Clabs
  • 1 Post By i860
  • 2 Post By Windinmyhair
  • 2 Post By Clabs
  • 1 Post By MartinatMersea
#1 Old 6 Days Ago
Vehicle: 2013 SLK 200 R172 1.8
Hi folks
I have been tasked with fixing a water leak from the panoramic roof on my sister's 2013 SLK 200. The water drips down roughly where my finger is pointing in the first pic and drips down right where the seat belt buckle is in the same pic.
One of my own cars is a 1997 BMW E36 M3 Evo convertible so I am well aware of the importance of making sure drain holes are kept clear, cleaning seals and applying Gummi regularly. With this in mind, I have methodically checked all drain holes and lubricated all the seals.
Despite this, the leak has still persisted so yesterday, I spent some time really looking at the area of the leak. I noticed that the trim that that runs down the side of the glass (the same bit I am pointing to in pic 1) is coming unstuck.
You can see from my other pics that it is possible to get your fingers under the inner edge of the trim and pull it up slightly. From the little I can see when I gently pry the trim up, it looks like there may be some plastic tabs to locate the trim piece and then it is bonded in place. It does look like one of the tabs is broken.
I have searched for quite a while and have found threads where dealers have squirted sealant into the roof to fix leaks (as well as the drilling holes thread ) but nothing about this trim piece.
My question is, does it seem likely that if water can get under this trim piece, it can leak into the car or is that trim purely cosmetic? Looking back at the drilling holes thread, it does seem like it is likely that water can get in this way. But - if it is just cosmetic then it is a red herring and the leak is probably seal related.
So, to cover all bases, it would seem a good idea to have a go at re-bonding that trim piece back in place. The only way I can see this can be done properly is to completely remove the trim first to allow all the surfaces to be cleaned up properly. But - looking at the parts catalogue, I don't see that trim listed separately so will be stuck if I break it in taking it off.
Has anyone come across this problem before? Any suggestions for me?
Many thanks and best regards
Mark
Clabs is offline
#2 Old 6 Days Ago
Quoted: 6425 Post(s)
Mark,
you say the trim is not listed separately?
where have you looked?
here:
https://slk-links.neocities.org
post your vin and we can look 4 u
#3 Old 6 Days Ago
some search results of our forum with keywords r172 panaramic roof leaking
https://www.google.com/search?source...4dUDCAc&uact=5
#4 Old 5 Days Ago
Hi Jeff and thank you for helping me - really appreciate it.
I did use that link you provided for a parts search and couldn't see those side trim pieces listed separately - will have another look around this evening.
In the meantime, the VIN number is WDD1724482F079438
I also spent some time looking through those other links you kindly provided but so far didn't turn up a similar problem. I will keep digging and see what I can find.
My plan today was to have a go at dropping the headliner to get a better look at the underside of the roof but the weather here has been ghastly all day. Hopefully better weather tomorrow
Thanks again for trying to help me.
Cheers, Mark
Clabs is offline
#5 Old 5 Days Ago
Standby for datacard and then will look for part
#6 Old 5 Days Ago
Datacard here:
#7 Old 5 Days Ago
i'll keep looking
#8 Old 5 Days Ago
if you do not see the part, it is not sold separately
#9 Old 5 Days Ago
Thanks for looking Jeff - that was the exact same place I would have expected to find it - shame it is not available separately.
I am in two minds now whether to try and remove the trim in case I break it. The trouble is that I cannot see that I will be able to achieve a satisfactory seal if I am not able to get the underside cleaned up properly.
Hmm....
Clabs is offline
#10 Old 5 Days Ago
@VII7 @i860 @Col @MartinatMersea
#11 Old 5 Days Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 892 Post(s)
I will first try with some special rubber cleaner from main dealer maybe will rejuvenate the rubber.
i860 is offline
#12 Old 5 Days Ago
or gummi
https://www.slkworld.com/general-dis...ts-hinges.html
#13 Old 5 Days Ago
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 326 Post(s)
Purely a guess on my part is that, if that side trim is not available separately, then it is most likely bonded to the roof section at the factory.
If that is the case, I think that a good clean as far as is practicable and then stick it back with Tigerseal or Sikaflex would be the most likely cure. Just make sure everything is dry and mask off the surrounding parts well. Stick it down and tape in place for 24hrs.
Windinmyhair is online now
The Following User Says Thank You to Windinmyhair For This Useful Post:
#14 Old 5 Days Ago
Thanks for the suggestion Windin - appreciate it.
It is odd because when I was looking at the car yesterday and discovered that trim piece was coming loose, when I gently pulled it back, a lot of water came running out. I held the trim back till water stopped coming out. Today, we have had torrential rain all day but when I went and sat in the car 30 minutes ago, there is no sign of any water drips at all. It is almost as if that trim piece being slightly unstuck was trapping water and funnelling it in somehow. Since I pulled the trim back, it is not sitting quite as snug as it was so perhaps this is allowing the water to drain away rather than be trapped and funnelled?
Anyway, after todays findings, your suggestion was exactly what was on my mind - do my best to clean up what I can and then Sikoflex it back in place.
Thanks for the help mate
Mark
Avel Du and Windinmyhair like this.
Clabs is offline
#15 Old 5 Days Ago
MartinatMersea's Avatar
Vehicle: 2012 SLK55, Iridium Silver, Bengal Red Leather. Sold 2010 SLK350 Obsidian Black
Other Toys: Volvo 480 Turbo, Various Gadgets
Quoted: 342 Post(s)
From the pics am I correct in thinking that it is the last 3 to 4 inches of the top edge of the trim is coming away and that the bottom edge is still attached and secure.. If so I would make sure that the area coming away is completely clean and dry and as suggested use something like tigerseal to stick it back down. Essential to let adhesive cure for at least 24 hours and over that period tape it down so it cannot move and best not to drive the car.
Windinmyhair likes this.
Martin
Mods:
CKS Bonnet/Hood Fins
AMG Grill Badge
STHFMZ2 SmartTop v1.52
MartinatMersea is offline
The Following User Says Thank You to MartinatMersea For This Useful Post:
#16 Old 5 Days Ago
Thanks Martin - it is useful to have further confirmation that what I am planning is not a bad idea!
Clabs is offline
