Gps Antenna - Mercedes Benz SLK Forum
 16Likes
#1 Old 07-16-2019
Vehicle: 2014 SLK 250 CDI
Gps Antenna
Hi we have just purchased a Becker Nav unit for our R172. It doesn't seem to be seeing any satellites so is the factory gps module toast ?
Is there a way to check and where is it - I have seen different suggestions - in the rear view mirror area, under the bonnet or in the boot ?
Many thks
LIL DON SLK likes this.
Alfaman321 is offline
#2 Old 07-16-2019
Quoted: 2344 Post(s)
@Seanhump
@curro101
@VII7
@Sneaky Pete
Avel Du is online now
#3 Old 07-16-2019
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 196 Post(s)
Did you have one before? The antenna goes on the dash
VII7 is offline
#4 Old 07-16-2019
The car has 508 pre-wiring for the Becker. We added the becker but it can't see any satellites. Somewhere else said pull the fuse but both fuse boxes seem somewhat inaccessible - couldn't open the one in the boot with a 'flat' object - what the he'll does that mean !
The rear view mirror has two bulges on top - are those for the antennae ?
Not much technical advice on here ?
#5 Old 07-16-2019
Plenty of advice from all continents of the world.
Members do not sit watching for every issue.
There are no paid experts here.
Members help fellow members.
So, until a member with input reads your thread, folks are avoiding telling you any old dross.
Patience pays.
It may be a week before someone can give a specific answer.
#6 Old 07-16-2019
Other Toys: CLS63
Quoted: 196 Post(s)
And you were a little vague
Now if pre wired you should have the antennae, it will plug into the module in the dash.
Is the wire there and it is connected?
The antenna should be under the grill in the dash for the non com and navi.
VII7 is offline
#7 Old 07-16-2019
Not sure how - where is the antenna could be much clearer.
It was pre-wired at the factory so I don't have the antenna hence the question abut its location.. The Becker module is plugged in and seems to function but can't see a satellite.
What is the non com ?
#8 Old 07-16-2019
Other Toys: CLS63
Quoted: 196 Post(s)
Well it would have been helpful to know if you were trying to fix your existing navi or adding this and as you have now stated whether you had a prewired car.
Btw the antenna might not be part of the pre wiring go and check if it's there.
VII7 is offline
#9 Old 07-16-2019
You can look up parts in this link https://slk-links.neocities.org/EPCLINKS.HTM
If you search for the sat nav antenna you should find an exploded view.
Hopefully, that might give a clue to it's location.
It can be laborious going through all of the options, but ...
#10 Old 07-16-2019
'508 pre-wiring for the Becker'
I take it you have sourced a datacard, or bought new with that option?
#11 Old 07-16-2019
Other Toys: CLS63
Quoted: 196 Post(s)
Central dash grill
VII7 is offline
#12 Old 07-16-2019
Central dash grill
Cheers that is very helpful. Where is this - inside the cabin ?
#13 Old 07-16-2019
Other Toys: CLS63
Quoted: 196 Post(s)
--->Central dashboard grill<---
As in below the windshield glass at the center
I'm guessing we are having a terminology problem...
Alfaman321 likes this.
VII7 is offline
#14 Old 07-16-2019
@VII7
@Alfaman321
I believe this location?
The Following 2 Users Say Thank You to Avel Du For This Useful Post:
#15 Old 07-16-2019
Other Toys: CLS63
Quoted: 196 Post(s)
Yes that
VII7 is offline
#16 Old 07-18-2019
Gps Antenna
If I disconnect the battery do I need to have the code number for the radio ?. This may be easier than pulling the fuse which is another suggested fix from elsewhere.
Thks
#17 Old 07-18-2019
Quoted: 6613 Post(s)
Thks
only the r170 needed a radio code after battery disconnect
the r171 n r172 do not
Avel Du and Alfaman321 like this.
#18 Old 07-18-2019
Many thks
#19 Old 07-18-2019
No code as they are tied to vin for your car only.
If someone puts a second hand unit it they have to tie it to the vin.
#20 Old 08-02-2019
So I managed to find a used Gps antenna from the interweaving and took it to a local specialist for fitting. They reckon the head unit and dash plus the air vents need to come out and 3 hours labour minimum. Do I need to find another specialist ?
