2013 - R172 Reliability? - Mercedes Benz SLK Forum
 13Likes
#1 Old 1 Week Ago
Vehicle: 2013 SLK? - potential buyer
How reliable has your R172 been and at how many miles?
Any major repairs or things breaking during ownership?
I am thinking of buying one, most of them have about 70 to 90k miles and I'm wondering why they are all selling sort of at the same mileage.
damonfong is offline
#2 Old 1 Week Ago
andresfg95's Avatar
Vehicle: 2012 SLK 200 R172
Other Toys: 2008 BMW 325i
My car is a 2012 SLK 200, 44k miles on the clock. I do not live in the states but maybe my experience is of any help.
So far I've had the following issues:
Roof delamination. If you're not aware of this issue, basically look for cars with the glass roof and not the "plastic" one.
Had to replace the fuel pump at around 6k miles.
Engine mounts replaced at around 30k miles.
Had some sort of circuitry from the passengers seat replaced as it was giving me airbag errors.
Camshaft adjusters went bad at around 37 k miles. Known issue with 271 and 271 evo engines. I don't know about the 350 or the 55 engines, but so far IMHO the M271 engine present in 200 and 250 models is not reliable.
Edit:
I've also had a leaky coolant hose and the windshield washer reservoir pump went bad.
LIL DON SLK likes this.
andresfg95 is offline
#3 Old 1 Week Ago
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 149 Post(s)
Reliability as in frequency of unscheduled service requirements I would say above average for MB standard.
As far as high cost items there are a few things to look out for:
1. Solid roof - avoid at all costs
2. Early red cars - also avoid unless already repainted
The mentioned adjuster noise is only on early M271 EVOs.
Avel Du and andresfg95 like this.
VII7 is online now
#4 Old 1 Week Ago
LOA
LOA's Avatar
Vehicle: 2012 SLK350 Obsidian Black, Tan leather, Nav, HK Audio, Adaptive Suspension, AMG pkg
Other Toys: 2016 Jaguar XF R-Sport 35T AWD, 2016 Mini Countryman Cooper S All4
I have a 2012 SLK R172, 65,000 km (41,000 miles).
No issues at all. Car has been bulletproof.
No roof issues, no mechanical, engine or transmission issues.
No major rattles.
Car is not winter driven, and lives in a garage. Not generally driven in inclement weather, but if we are out and it happens, we don't rush to get it back indoors.
Several longer trips, including a 3000 mile round trip to Florida from southern Ontario.
LOA is offline
#5 Old 1 Week Ago
Moderator/RoTMorganiser
Quoted: 2044 Post(s)
It would be worth specifying an engine size.
The 350 & 55 engines are robust across the model range.
The roof & red paint issue hit several 172s.
The reply from VII7 is worth noting.
He is one of the main members that we call upon when trying to assist members.
Has a very wide and deep field of knowledge on the range.
Also, note that members come here to resolve issues.
That can make it look as though an issue is prevalent when it is not.
Few post threads to say 'My car is running well and I have had no issues'.
LIL DON SLK and Deep7 like this.
Avel Du is online now
#6 Old 1 Week Ago
Vehicle: Looking to buy a 2012-2016 SLK350 R172
Other Toys: ML350 4M, CLK 350 Coupe, CLK 320 Cabriolet, CLK55 AMG Coupe, E350 4M, GLK350 4M, CL600.
Quoted: 21 Post(s)
What is up with the solid roof that you want to avoid it for ?
SLK55_AMG_30 is offline
#7 Old 1 Week Ago
Other Toys: CLS63
Quoted: 149 Post(s)
All R172 with solid roof will suffer "delamination" which requires partial replacement of roof (to a glass version). This was determined to be a material issue and not a manufacturing problem and as such all solid roofs will be affected (this is why the solid roof was discontinued).
VII7 is online now
#8 Old 1 Week Ago
Mensra's Avatar
Other Toys: Wellcraft Scarab
Quoted: 300 Post(s)
Yup, happened to me. I was told by Mercedes to “suck it“. It happened seven months outside of the warranty.
Mensra is offline
#9 Old 1 Week Ago
Quoted: 21 Post(s)
So basically I should just buy one with the magic sky control and be done with it?
Mensra likes this.
#10 Old 1 Week Ago
Other Toys: CLS63
Quoted: 149 Post(s)
Normal glass or magic sky will both be fine.
SLK55_AMG_30 likes this.
VII7 is online now
#11 Old 1 Week Ago
Vehicle: 2012 R172 SLK55
2012 SLK 55
Had the exhaust flaps fail both replaced at 23,000 miles, Headlamps were full of condensation modified by Mercedes with the silicon bags added at the back of the lamps, no problems since.
Statler is offline
#12 Old 1 Week Ago
b82012's Avatar
Quoted: 271 Post(s)
2013 SLK350, 50,xxx miles
Only repairs done has been 2 cat converters replaced under CPO warranty at ~30K miles or thereabouts.... That has been it. Knock on wood.
Love the Magic Sky roof in mine but hardly ever use it... reason is I drive my car almost always top-down... But when I showed it off, people loved it cos it is a cute little trick MB added.
Omo
b82012 is offline
#13 Old 1 Week Ago
Wow! Thanks everyone for the quick replies. This is very informative and makes me comfortable with getting one knowing there is a community that is still alive unlike many other older cars.
I currently drive a G37, extremely reliable but less sexy. The community there has died so looking for parts and information has been pretty much the dealership.
It doesn't sound like the typical mercedes that breaks a lot (although i think they are still probably better than BMW and audi?)
A couple of cars I am looking into:
WAS - SLK250 before this thread, SLK350 or SLK55 AMG now
Z4 - very ugly compared to SLK
Miata - I kind of want to be able to get up to freeway speeds and survive if someone were to hit me
S2000 - over priced for what it is
Porsche boxster - soft top
Nissan GT-R - too expensive for just regular maintenance
F-type - too unreliable
#14 Old 1 Week Ago
Quoted: 6116 Post(s)
55! r171! Bullet proof!
F1 Nose!
Since you are consdiering a 55, these might interest you
My mods - also check my albums in my profile
and my videos in the 'Driving Stories' section
Kleemann Supercharger:
https://www.slkworld.com/performance...re-begins.html
Kleemann ECU Tune and Headers:
https://www.slkworld.com/performance...ipes-vids.html
Wavetrac Limited Slip Differential (LSD):
Carbon Fiber Diffuser:
https://www.slkworld.com/performance...ved-today.html
Carbon Fiber Air Brakes/Side Vents
https://www.slkworld.com/general-mod...ide-vents.html
Driving stories section:
https://www.slkworld.com/driving-stories/
My albums:
https://www.slkworld.com/members/jbanks15-albums.html
FREE GIFT! Post your vin in the Vehicle Datacard Request section to get a free datacard (options on your car). If looking for a car, get the options before you buy!
https://www.slkworld.com/vehicle-dat...-datacard.html
johnslk likes this.
Wavetrac LSD thread here:
#15 Old 1 Week Ago
Vehicle: 2013 SLK55, Diamond White/Red
I have 2013 SLK55 with 60k miles. I bought it used a year ago, but have all of the maintenance records. So far, no issues at all. I have Magic Sky, so I can’t comment on the solid roof concerns others have mentioned.
WolfDog is offline
#16 Old 1 Week Ago
Vehicle: 2012 SLK55 White/Tan
Other Toys: BMW C650GT
I have a 2012 SLK55 AMG with 30,000 and no problems thus far!
MLGoodwin is offline
#17 Old 1 Week Ago
Vehicle: 2014 SLK55 AMG
Other Toys: 2014 E63 S AMG Wagon (wife’s DD)
Quoted: 13 Post(s)
2014 SLK55 bought used October 2018 with 47K, now 51K. Dealer serviced from new, I’ve seen the records, nothing worth mentioning. Daily driver, if I’ve got to go, its got to take me, cold, snow, rain or shine. Roof still quiet and water tight. You’re going to love getting one of your very own.
mckinney is offline
#18 Old 1 Week Ago
Vehicle: 2013 SLK55 AMG
Other Toys: BMW F800ST
2013 SLK55, 39,400 miles:
2000 miles - wiring problem with right DRL repaired
10,057 miles - software update to correct erroneous "add oil" warning message
19,456 miles - windshield washer tank replaced due to sensor failure
23,787 miles - entered limp home mode due to fuel injector error, problem cleared after engine restart
32,638 miles - exhaust flap replaced
32,920 miles - rear brake pads replaced; front sway bar end links replaced due to leaking grease
It's on its 3rd set of summer rear tires and second set of fronts; still on its first set of winter tires.
Total cost for maintenance and repairs so far is $6,268.95 USD.
Fuel economy to date averages 21.98 MPG, and total fuel cost is $5,720.32 USD.
MrPMS is offline
#19 Old 1 Week Ago
Vehicle: 2012 250 petrol black/red
Quoted: 304 Post(s)
2012 250 48k miles on the clock.
No faults until last week when entire air conditioning system packed up. £1000 to sort inc. parts/labour - lovely.
I ran numerous cheapo brands as company cars running up to 150k miles & never ever had a/c problems.
Give me a Ford any day except they don't do a convertible anymore.
oldmercman is offline
#20 Old 1 Week Ago
LeonardoDaBenz's Avatar
Quoted: 943 Post(s)
At the risk of raising the ire of you-know-who, not that I would consider one but 2019 'stang 'vert is available. Don't know what you're referring to.
A/C can go on any car. My loss-of-use on Fords & Mercs was because of lack of use.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
Currently Active Users Viewing This Thread: 7 (3 members and 4 guests)
MartinatMersea, Jimbeaux, TimGriff6
My Thoughts on the R172 SLK55 Col AMGs 27 06-20-2018 02:16 PM
Highlights From Consumer Reports' 2015 Annual Auto Reliability Survey Berliner Heckflosse Off Topic 0 11-02-2015 11:39 PM
7 cars that lose their Consumer Reports Recommendation due to reliability Berliner Heckflosse Off Topic 0 11-03-2014 12:22 PM
R172 SLK55 v R171 SLK55 - interesting changes in pics rocketace2012 AMGs 19 03-16-2014 05:08 AM
