Daytime running light removal - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By Tonyh61
  • 1 Post By jbanks15
  • 1 Post By Avel Du
  • 1 Post By PC017
#1 Old 04-10-2019
Vehicle: 2014 SLK250 CDI, R172
Hi, has anybody ever had to change the led daytime running light located in the front bumper bar? If you have, how do you remove the fitting? There are no screws holding the light in place, so I am assuming that the fitting is pushed into place. therefore, is it a case of removing the bumper bar, or is there a quicker and easier way? Thanks
Tonyh61 is offline
#2 Old 04-13-2019
Moderator/RoTMorganiser
Quoted: 2138 Post(s)
If memory serves there are three plastic tags and it just pops out.
I know @JBanks did his 171. Doubt it is much different on the 172.
#3 Old 04-13-2019
Quoted: 6355 Post(s)
Say what? r172 has it built into light assembly i believe
r171s wayyyyy different
#4 Old 04-13-2019
r171 as u can see not the same
https://www.slkworld.com/slk-r171-cl...procedure.html
#5 Old 04-13-2019
We live and learn.
#6 Old 04-25-2019
PC017's Avatar
Vehicle: SLK 250 CDI AMG Sport Tip 2014
Quoted: 16 Post(s)
Hey TonyH61...
4x Torx T10 screws in the grill, pull the grey lock on the electrical tub up and slide connector off.
On the back you will see four plastic locking tabs. Just a case of pushing them towards the centre and gently lever the LED unit up to release. Repeat for the remaining clips and you are good to go. Put the new LED in and push firmly to lock in place.
Sounds more complex than it is actually is.
PC017 is offline
#7 Old 04-27-2019
Daytime driving lights
Hi, thanks for your reply, but there are no TORX screws in the grille. I've had another look and I think I will have to remove the tray from the lower part of the front bumper bar to gain access to the light fitting. I'll take some photos and upload them, when I decide to do the job and hopefully it can be of some help to other members in the future should they have a similar problem
The car by the way, is a 2014 R172 model 250cdi. It isn't the AMG model, which appears to have a different lower grille set up
Tonyh61 is offline
#8 Old 04-27-2019
https://nemigaparts.com/cat_spares/e...172403/d43/88/
Some explodeded views of the front end here.
May help.
#9 Old 04-28-2019
PC017's Avatar
Quoted: 16 Post(s)
Ah mine is the AMG so will be different grille.
PC017 is offline
No Sir! 'Jet Lag' Is No Excuse For Running A Red Light And Speeding jbanks15 Off Topic 0 02-10-2017 08:58 AM
Daytime running lights? -1- SLK R171 General Discussion 66 10-21-2014 03:30 PM
Fog Light Removal TeeJ General Modifications R171 6 04-18-2010 11:38 AM
Germany and LED Daytime Running Lights Tummy General Discussion 5 06-23-2008 07:02 PM
