Rattling sound in engine - Mercedes Benz SLK Forum
 6Likes
#1 Old 04-04-2019
Vehicle: 2013 SLK350 AMG, metallic grey
Other Toys: 1974 Honda 350f
Send a message via Skype™ to peroel
Hi guys, last week I started my car after a month of standing still.
A rattling sound came out of the engine for about 2 to 3 seconds.
Then everything was fine.
I know it is the lifters running out of oil when standing for a long period of no starting.
My car has 22k miles on it.
My question, is there any way to prime the engine before starting after a long vacation?
Like taking out the fuel pump relay and cranking the engine for some seconds to prime the lifters?
Will this hurt something?
Thanks on advance...
peroel is offline
#2 Old 04-04-2019
Vehicle: 2005 SLK 350
Other Toys: H20 V-Dubs, MK1s
Quoted: 409 Post(s)
I’m no expert mechanic but I can’t imagine that would hurt a thing. It actually seems like a great idea. In fo mo info...
Roxanne7169 is offline
#3 Old 04-05-2019
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 177 Post(s)
Careful, you might burn the starter.
The speed and time required to generate oil pressure and reach the lifters is likely beyond what your battery and starter would like. Also the engine is still rotating so you didn't gain in terms of lifters. Also after removing relay there will be residual fuel pressure.
VII7 is offline
#4 Old 04-05-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 855 Post(s)
Only if you spin fast enough the engine a few times from crankshaft pulley...
i860 is online now
#5 Old 04-05-2019
Vehicle: R172 SLK350 AMG Sport 2012, Iridium silver with bengal red exclusive leather.
Other Toys: Mini Countryman Cooper-S, Adria Twin motorhome, Gibson Nemesis racecar.
turning over the engine using the starter, in order to build oil pressure, is fine. It's what you would routinely do after a fresh engine rebuild for example. However, in this case it isn't necessary. Even when some oil drains back from hydraulic lifters, it generally only takes a matter of seconds for pressure to build-up again. Historically, some engines have been particularly bad for this and in the 'bad old days' you might have to weight a few minutes befiore all of the lifters pumped-up!
SAlexander is offline
#6 Old 04-06-2019
Rattling sound on startup
The sound is scary. I don't like that sound.
These cars rev up like 1300 or 1500 on start up?
My Kia Sorento starts up with a very low rev en than gradually go to a higher rev.
I think something like that is a better control module programming.
But anyway, maybe removing the plugs (engine will turn faster without starting) and fuel pump relay will do the trick?
peroel is offline
#7 Old 04-07-2019
Quoted: 409 Post(s)
Maybe you can put a video on YouTube with good sound quality. Some of the members may put your mind at ease or offer more info.
#8 Old 04-08-2019
I am quite sure its the lifters, I am thinking of a way to avoid this.
I have to leave the car for a month or something for it to happen again.
After July (vacation) I will record the sound.
It will happen only when the car is not started for more or less a month.
peroel is offline
#9 Old 04-08-2019
Other Toys: CLS63
Quoted: 177 Post(s)
On that engine it's more likely the adjusters than the lifters.
You are concerning yourself with something that is not a problem and considering doing things that will become problems.
The spark plugs in this engine are indexed, plugs installed in the wrong orientation will result in terminal engine damage.
jbanks15 and pwgunny like this.
VII7 is offline
#10 Old 04-08-2019
Quoted: 409 Post(s)
Holy Crap (Frank Barone style). I’ve never heard of such a thing, and I’m planning to install new plugs in my 05 350 soon. What type of engine are we talking about and what procedure is advisable?
ps: my Google finger is in the shop ATM
#11 Old 04-09-2019
nimbusgb's Avatar
Quoted: 245 Post(s)
Say WHAT?
Please expand on this little theory.
nimbusgb is offline
#12 Old 04-09-2019
Quoted: 187 Post(s)
Not sure if you are trolling or what... So HLA's (hydraulic lash adjusters), lifters or tappets are all the same thing.
Others - Yes the newer direct injection engines do require the correct indexing of plugs. MB plugs have a spec, but aftermarket do not.
jet_fl is offline
#13 Old 04-09-2019
Other Toys: CLS63
Quoted: 177 Post(s)
Camshaft adjusters: the gears at front of camshaft, used for variable valve timing (this is what is referred to as an adjuster in MB around here).
Plug indexing applies to the DFI engines and is well documented by MB including instructions for warranty denial if plugs are found to be oriented incorrectly.
Due to geometry considerations for other important aspects of the engine, spark plugs are located off center for DFI engines. This creates the need for indexed spark plugs to ensure the flame front faces towards the center of the combustion chamber and not towards the cylinder wall. If the flame front faces towards the cylinder wall it will burn off the oil film resulting in cylinder scoring, the flame front will also reach the piston too quickly creating thermal overrun that can melt the piston.
VII7 is offline
#14 Old 04-09-2019
Other Toys: CLS63
Quoted: 177 Post(s)
Originally Posted by Roxanne7169 View Post
Holy Crap (Frank Barone style). Ive never heard of such a thing, and Im planning to install new plugs in my 05 350 soon. What type of engine are we talking about and what procedure is advisable?
This does not apply to your engine (m272).
VII7 is offline
#15 Old 04-09-2019
Please correct me if I am wrong.
So, indexed plugs should be used on the M276 engine right?
I understand that the MB plugs are designed to take the right position if torqued right.
So you are better off using only MB plugs..
Thanks for the good info bro....
peroel is offline
#16 Old 04-09-2019
Delucas's Avatar
Quoted: 1123 Post(s)
Mercedes spark plugs are in Fact NGK or Bosch depending on year and what deals they done with them at the time etc
Delucas is online now
#17 Old 04-09-2019
Quoted: 187 Post(s)
Correct, but that does not mean the NGK or Bosch aftermarket plugs will index correctly. They may be used in other cars that do not require the indexing and the aftermarket may be sold as such. This is one of the rare instances I would use MB only as it just isn't worth the possible problems.
jet_fl is offline
#18 Old 04-09-2019
Quoted: 187 Post(s)
Camshaft adjuster is what I always see them called, that makes sense to be a possible cause of the noise as they need to fill with oil to work properly.
jet_fl is offline
#19 Old 04-09-2019
Other Toys: CLS63
Quoted: 177 Post(s)
Yes, M276 requires indexed plugs. The recommendation would be to use MB branded plugs or only exactly the same manufacturer part number present in the MB plugs (Do not use interchange part numbers). A correctly calibrated torque wrench will provide for proper installation with these specially designed plugs, however repeated installation and removal might alter the final resting position.
VII7 is offline
#20 Old 04-10-2019
Quoted: 409 Post(s)
This does not apply to your engine (m272).[/QUOTE]
Thank you for this. One less “Mercedes land mine” for me to worry about. Instead I can focus on the “time bombs” .
pwgunny likes this.
Melania
Fuel additives and engine tick/tap/ping/knock/whine/sluggishness/hesitation and top tier gas jbanks15 Off Topic 251 04-24-2019 01:39 PM
2013 SLK 250 Vibration Sound in Engine Compartment Wick63 SLK R172 General Discussion 32 10-10-2018 05:03 AM
Rattling sound from transmission area when at speed? brian.frazer SLK R170 General Discussion 2 04-11-2018 04:16 AM
30 years go, BMW built a 1350 hp engine for Formula 1 cars Berliner Heckflosse Motorsports 0 04-14-2017 11:21 PM
Mercedes Benz 250 AMG CDI - Is the diesel engine sound really that bad? G6dsn SLK R172 General Discussion 65 06-20-2014 12:50 PM
