Key locked in trunk - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By VII7
  • 2 Post By Pictor
  • 1 Post By igormina
#1 Old 01-27-2019
Vehicle: 2011 R172 SLK200
Other Toys: Fishing Boat and Yacht
Quoted: 9 Post(s)
Key locked in trunk
I have managed to lock my only set of keys in the trunk does anyone know of a method to open the trunk your assistance would be greatly appreciated
Cliviscus is offline
#2 Old 01-27-2019
Quoted: 217 Post(s)
Any more info?
Is the rest of the car locked?
If not open door, push door unlock switch.
If the whole car is locked call RACV.
,,,,,, And it’s a public holiday too so all the locksmiths and dealers are shut. Bugga!
Pictor is offline
#3 Old 01-27-2019
Moderator/RoTMorganiser
Quoted: 2121 Post(s)
If you can get in, look for the button with padlock amongst the main switches.
#4 Old 01-27-2019
Links to others that had this problem
https://www.slkworld.com/gtsearch.php...d%20in%20trunk
#5 Old 01-27-2019
Quoted: 9 Post(s)
managed to unlock the drivers door but unfortunately the door unlock is only unlocking the passenger door.
#6 Old 01-27-2019
Quoted: 6296 Post(s)
check central locking fuses?
Wavetrac LSD thread here:
#7 Old 01-27-2019
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 170 Post(s)
If you have access to the vehicle you might be able to activate the electric trunk lock.
Also try to disconnect the battery to reset alarm status and attempt to unlock again.
VII7 is online now
#8 Old 01-28-2019
Quoted: 217 Post(s)
Are you sure the boot lid is locked rather than just jammed?
Is it possible that something in the boot got caught in the lock and that’s why it wouldn’t open then and also won’t when the doors are unlocked?
Pictor is offline
#9 Old 01-28-2019
Vehicle: 2013 SLK 250 CDi
Other Toys: MGTF 160VVC
Quoted: 25 Post(s)
Lower the roof until the boot lifts and then turn the ignition off? You may be able to reach the key ring round the edges of the separator using a magnet. If the separator is open, this obviously won't work. Edit - stupid suggestion - ignore me, I was half asleep when I wrote it!
I don't think I can lock my only set of keys in the boot because the boot only locks when I press the button on the keys. That means I can open the boot with the button above the license plate. (I have had self locking boots in the past and managed to lock myself out twice in bad situations so was pleased to have the Mercedes system on this car)
TimGriff6 is offline
#10 Old 01-28-2019
Other Toys: CLS63
Quoted: 170 Post(s)
You can by using the trunk open button since the car will remain in locked condition once trunk is closed again.
VII7 is online now
#11 Old 01-29-2019
Quoted: 25 Post(s)
Red face
Thanks for the explanation - sadly my confidence that it couldn't happen to me has been shattered . I hadn't thought about that sequence but it is something for me to avoid doing in future. I must also check to see whether the car locks itself automatically after a short while if only the boot is opened after unlocking all doors.
#12 Old 01-29-2019
stagwcb's Avatar
Vehicle: Slk 250 CDI amg sport 2015
Other Toys: Triumph stag. Jeep Cherokee
Quoted: 92 Post(s)
With mine if you unlock the boot with the key fob the boot lifts and opens andunsets alarm. When I shut the boot again it locks and sets the alarm without the key . So if my keys were in the boot that is where they would stay.
stagwcb is offline
#13 Old 02-01-2019
igormina's Avatar
Vehicle: 2008 SLK 55 AMG
Other Toys: 2006 GTO
May be not the cheapest but still reasonable and fast solution: contact Mercedes Benz Me, explain the situation, subscribe to minimum possible service option and get your trunk remotely open right after completion. Personally had this service performed on 2 occasions. And if you install their cellphone application you can do that by yourself next time.
"Rule number three, you will not cry, or whine, or laugh, or giggle, or sneeze, or burp, or fart. So, no, no annoying sounds. All right?"
igormina is offline
#14 Old 02-01-2019
Other Toys: CLS63
Quoted: 170 Post(s)
Ahh that is truly likely the cheapest option.
I don't remember if the trunk can be actuated via Xentry with ignition off..
VII7 is online now
#15 Old 02-02-2019
Quoted: 25 Post(s)
1 I checked and, for me, using the main unlock button is the way to do it because the car doesn't lock itself when the boot is opened and shut.
2 If it is possible to release the boot by electronics without needing the key in the ignition, calling out the roadside assistance may be cheaper - I did that with one of my other cars when I had an engine warning light come on and got a completely free analysis and clearance of faults done by the man in the van.
3 Does Mercedes Me do this if you only have the plug in adapter and not the built in module?
#16 Old 02-02-2019
igormina's Avatar
Mercedes Me experience
My personal experience was when I press lock button on key fob while unloading groceries, hand getting busy, put it in the trunk, grubbed two hand full of bags and shut the trunk. When I realized stupidity of situation I call them through Mercedes Me app on my android, because my 2008 SLK55 AMG before updated version does not support many automatic functions from Mercedes Me app. But one can get their call center assistance with it, including vehicle soft check up. I would say that 'they" actually have much more variety of the electronic "involvement" than they advertise...
stagwcb likes this.
igormina is offline
R170 automatically locked doors w/ key in ignition [email protected] SLK R170 General Discussion 6 08-05-2018 11:09 AM
2005 SLK350 Trunk not opening marixo SLK R171 General Discussion 9 07-06-2016 05:49 PM
Keys locked in trunk! isslandboy SLK R171 General Discussion 18 06-07-2016 03:20 PM
Emergency trunk escape handle rgvspike SLK R170 General Discussion 0 04-30-2015 12:13 AM
Trunk stuck shut...thinks roof is in operation jcdinkins SLK R171 General Discussion 10 03-25-2013 08:59 AM
