SLK350 Vario roof gap repair - Mercedes Benz SLK Forum
 13Likes
  • 10 Post By SLKed
  • 1 Post By fatfairy2005
  • 1 Post By jammersp
  • 1 Post By Avel Du
#1 Old 09-25-2016
SLKed's Avatar
Vehicle: 2012 SLK350
2012 SLK350, the roof panel was pulling away from the support bar and created about a 1/4 inch gap between the top of the windshield frame and the roof panel. Did not leak, but created tremendous wind noise.
- Took it to the dealer and was told solution was replacement of the roof panel for $5,000
- Took it to a body shop and they would not touch the roof, recommended the dealer
SOLUTION: There' s a support bar that the roof panel attaches to and it is glued from the factory. Appears it is only attached on the edges, thus the lack of mechanical integrity. This can be repaired with 3M Panel Bond or PlioGrip Panel 60, available from Amazon for about $70 with applicator. Do not use Epoxy or Gorilla glue as they do not have the resiliency to hold under stress. (I tried this first!) . You will also need a clamp with at least 9" deep jaws. Purchased this at Harbor Freight for $9. This clamp works like a Vise Grip and was easy to adjust.
1. Remove the headliner (Just snaps out and has a rubber retaining strip on each side)
2. Find the 3" bar that runs across the front of the roof. The roof release mechanisms are attached to it on each side. The Bar has a "honeycomb" design.
3. Put a drop cloth on your seats and dash in case of any spills.
4. Adjust your clamp so it pushes the roof back into place. Be SURE to not put pressure on the roof release mechanism by positioning the clamp so it goes into one of the honeycombs. You will have to fabricate a method of pushing the roof down as it is curved and a flat surface will not apply equal pressure. I put a pad on the roof then used a piece of wood with various size wedges across the surface area. This pushed the roof down equally across the area. ALSO, do not put so much pressure that you bend the roof.
5. Release the pressure on the clamp.
6. There's about a 1/4" to 1/2" gap between the roof panel and bar. Apply the bonding material in this gap as deep as possible. BE SURE TO NOT GET THIS ON THE ROOF RELEASE MECHANISMS. Also do not put so much that is leaks out the front. I think down the middel of the abr is fine.
7. Re-apply pressure with the clamp and let setup for recommended curing time
I let mine setup overnight. So far has worked perfectly. Cost me about $80.
I hope this works for you!
SLKed is offline
The Following 4 Users Say Thank You to SLKed For This Useful Post:
#2 Old 10-02-2016
Robrowdy's Avatar
Quoted: 245 Post(s)
Dude! You could make a fortune repairing these things as there are a lot out there
Robrowdy is offline
#3 Old 07-04-2018
Vehicle: 2012 SLK200 R172
Hi, got this problem on a SLK200 in the UK after the hot weather we are having. This is a stupid question I know but can you confirm that the work, clamp fitting etc is done with the roof half open. Seems obvious but you don't mention opening the roof in your brilliant solution. Thanks, Frank.
LIL DON SLK likes this.
fatfairy2005 is offline
#4 Old 1 Week Ago
Vehicle: 2012 R172 SLK Auto 250
Hi SLK'ed,
So i've had a look at this, and I think the gap you are talking about to squeeze the Tiger seal in, is at the front of the bar where it meets the plastic roof (downward facing lip), see picture?
When i pull on the roof it goes up by about 3mm - which is enough!
I was thinking of using about 4 clamps along the roof line, starting in the middle and working out?
Also I was thinking you could mechanically fix it with self tapping screws as well?
Thoughts?
James
jammersp is offline
#5 Old 1 Week Ago
Mike Florey's Avatar
Vehicle: 2012 SLK 350 (Atomic Death Toboggan)
Other Toys: Jeep Grand Cherokee Overland Summit, Racing plane (pylon racer), Polaris ATV
Quoted: 75 Post(s)
Good job, SLKed! I believe my top is starting to de-laminate as well. Out here in the desert heat, that's no surprise. I'm really interested in this fix because I'd like to get to it before it gets really noticeable.
A guy knows he's in love when he loses interest in his car for a couple of days. ― Tim Allen
Mike Florey is offline
#6 Old 6 Days Ago
There is also the Gap (fall of the roof) between panel and bar, at the rear of the bar.
Now that the headliner is off, as i drive along at 50mph the gap is about 3mm, as soon as i hit "fast" speeds, the gap rises to about 7-10mm, so you actually see the rise happening.
I am thinking of also squirting the tiger seal in three places along that bar/roof panel area, as marked on the uploaded photo.
jammersp is offline
The Following User Says Thank You to jammersp For This Useful Post:
#7 Old 6 Days Ago
Hi SLK170171172, not done this yet as the problem is not too big, except at motorway speeds when it does get noisy. May look at it this winter.
#8 Old 4 Days Ago
I'm going to do it this weekend (weather permitting) and will do instructions with pictures.
jammersp is offline
#9 Old 4 Days Ago
Quoted: 2312 Post(s)
Please add the pics as attachments.
Some third party hosts have scuppered many a diy by later blocking photos (eg photobucket).
#10 Old 3 Days Ago
Good luck jammersp! If it works out I might drive all the way down to Cheltenham to do mine under your guidance!
#11 Old 2 Days Ago
Weather permitting ....... no worries
jammersp is offline
#12 Old 9 Hours Ago
Okay so its done
The tiger seal went off reasonbly quick.
Pleased with the result so far, the roof now, does not move up and down above that bar, although proof of the pudding will be motorway speeds tomorrow .....
Have created a separate blog - got loads of photos ......;
https://www.slkworld.com/slk-r172-ge...ml#post4612892
jammersp is offline
SLK 230 R170 Roof problem - Here we go again scoot_eruk SLK R170 General Discussion 19 05-20-2016 01:52 PM
Vario roof tommy23t SLK R170 General Discussion 2 03-26-2014 02:32 AM
Vario roof not working. solution is found nobody99 SLK R171 General Discussion 1 03-06-2014 04:20 PM
What that dreaded 'check engine' repair will cost you jbanks15 Off Topic 1 12-12-2012 10:32 PM
Zaino and Vario Roof module working in tandem mcat SLK R171 General Discussion 23 10-03-2006 03:10 PM
