SLK R172 Delaminated roof fix - Mercedes Benz SLK Forum
 14Likes
  • 6 Post By jammersp
  • 3 Post By jammersp
  • 3 Post By Windinmyhair
  • 1 Post By jammersp
  • 1 Post By Avel Du
#1 Old 1 Week Ago
Vehicle: 2012 R172 SLK Auto 250
There' s a support bar that the roof panel attaches to and it is glued from the factory. Over time, this glue "lets go" and causes delamiation of the plastic roof from the front bar.
I have put together a guide on how to do this with the tools that you can get in the UK, but other countries just improvise!
Pictures show the roof before and clearly in hot conditions the roof rises! Pictures RR1-RR4
Pictures of the equipment and kit next. Picture EQ1
Pictures of the setting process. SP1-7
Pictures of the finally sealed roof. FS1-3
Equipment:
5 x deep-ish clamps (bought from toolstation: One handed quick clamp 73583 6.23 each)
1 x UPol Tiger Seal (ordered off Amazon 11.99) Panel bonding adhesive.
Knife.
Dirty wipes (loads of).
Tape (required for sealing holes that are in the bar as tiger seal leaks through them!).
1. Remove the headliner - pull at one side - i did the front and it snaps away. There are approx 11 clips.
2. There is a solid metal frame and at the front of car there is approx a 3" bar that runs across the front of the roof - the roof release mechanisms are attached to it on each side and the Bar has a "honeycomb" design.
3. I raised the roof on packers (from the inside) so I could squeeze the Tiger seal and put a cloth on your seats.
4. at the front of the bar, raise the roof and get the noozle of the Tiger seal up in there and squeeze - do along the complete width.
4a - In the pictures it is coming down the front - be careful of drips.
5. On the inside - do the same - get the noozle in there and squeeze, ensuring you go the complete width. One complete tube of tiger seal did the entire job.
5a - You can see in the pictures i have the glue coming to the edge.
6. Remove packers and let the roof move down onto the bar.
7. Put cloth's on the roof and then get the clamps spaced evenly along the roof, starting in the middle. 5 clamps will do the job - apply pressure and leave for as long as you can or for the curing time of the Tiger seal (I left for 6 hours before the rain came!)
I have had to spread the photos over 2 posts.
File Type: jpg RR2 Rising rear view of bar and roof.jpg (36.6 KB, 14 views)
File Type: jpg RR1 Rising front view of bar and roof.jpg (36.8 KB, 12 views)
jammersp is offline
The Following User Says Thank You to jammersp For This Useful Post:
#2 Old 1 Week Ago
Photos continued.
Additional Notes:
Note 1:
In photos SP1 and SP2 (first post), you can see the Tiger seal coming through those holes, after it has skinned a bit, remove the excess in that hole. This is because the roof lining grommets, pop back in those holes! Trust me its easier now than later
Note2:
You need to have 2, wooden (?) props to hold up the roof, when you switch the engine off as the hydraulic fluid flows back.
Trev5, Avel Du and Mike Florey like this.
jammersp is offline
The Following 3 Users Say Thank You to jammersp For This Useful Post:
#3 Old 1 Week Ago
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 357 Post(s)
Great guide
One little tip when using Tigerseal - white spirit will remove residue overspill provided it is wiped before it sets but, as jammersp mentions, have plenty of wipes/rag to hand.
Trev5, Avel Du and jammersp like this.
Windinmyhair is offline
The Following User Says Thank You to Windinmyhair For This Useful Post:
#4 Old 1 Week Ago
Vehicle: 2012 R172 SLK 250 CDI in blue
Fab guide!
DavidD is offline
The Following User Says Thank You to DavidD For This Useful Post:
#5 Old 1 Week Ago
Vehicle: 2012 SLK200 R172
Quoted: 7 Post(s)
Fantastic, now all I have to do is see if I'm brave enough to do it at 75! My delamination is only across half the roof, so I'm wondering if I should force the other half apart and then fix the whole width or go with the old principle of 'if it ain't broke don't touch it'. Any thoughts on this?
fatfairy2005 is offline
#6 Old 1 Week Ago
Ummmmmm, so, open the hood to the position you see in my photos (you can keep the engine running) and then press down the roof all along (at the front) and watch at the front where the plastic roof lip, moves up and down on the bar. If you have movement all the way along then prise it off.
If you don't have movement - i wouldn't prise it off, just squirt the tiger seal in the gap (behind the stuckdown side) at least that would further secure that side - i'm sure the factory only put a little bit of glue along it, and at least there will be more surface area to stick roof to bar!
Did that make sense, as I had to re-read it twice!!
jammersp is offline
#7 Old 1 Week Ago
Gbarringer100's Avatar
Vehicle: 2013 SLK250
Other Toys: 2016 GLA250
Quoted: 104 Post(s)
This might be good to have a sticky
I know it will not pull the top down tight to the bar but wonder if a quick simple fix would be using a waterproof tape and run it along the two sides where the top and bar meet.
Gbarringer100 is offline
#8 Old 6 Days Ago
I found as soon as you hit about 70, the roof started to lift with quite a force, so i suspect tape would have not hold if you did it that way.
However, i used waterproof tape along the width of the roof that once closed connected the roof with the front of the car (for a while) thus producing a seal and although the roof rose up i got no draught / draught noise, being a black car with black tape it wasn't too bad!
jammersp is offline
#9 Old 6 Days Ago
Quoted: 7 Post(s)
Thanks for those thoughts, they pretty much mirror my ones, and yes they did make sense!
#10 Old 6 Days Ago
Quoted: 2326 Post(s)
Once the updates are complete we will be looking to organise the diy stickies.
As you can see from the 170 and 171 diys, they can get too long.
I've stickied for now on the grounds that an MB fix requires organ donation
and this is pennies in comparison. Also, though not overly common, it affects enough folk to be useful to find.
Windinmyhair likes this.
