Replacing R172 Aux/ECO Battery to get Start/Stop working - Mercedes Benz SLK Forum
 11Likes
  • 10 Post By wongl
  • 1 Post By Cozzi
#1 Old 11-25-2018
wongl's Avatar
Vehicle: SLK250 2011 (R172) Sliver
Other Toys: C300h
Quoted: 16 Post(s)
I have recently purchased a 2011 SLK250 in Hong Kong which despite the ECO button showing a green light, it fails to show the ECO icon on the instrument panel even when the engine has reached operating temperature. Needless to say the start/stop function never kicks in. The previous owner reported that the ECO Start/Stop has worked erratically for him.
After researching this matter on this and other forums, I decided to take a punt and change the Aux battery on the SLK250 in the hope that I can restore the ECO Start/Stop feature. I had a choice to source the replacement battery from the one and only one Mercedes dealership in Hong Kong or source an OEM replacement from FIAMM via a reseller in Hong Kong. Sadly, sourcing the FIAMM replacement proved difficult as no sooner they restocked, a local garage had bought the entire stock!
Having sourced the replacement Aux battery from the local Mercedes dealership, I found it trickier than expected to install the new battery due to the limited access behind the passenger seat. The one-piece trim proved difficult to remove entirely, so access was limited by removing the trim only partially, barely enough to gain access to the battery location.
Here is how I replaced the battery; Unclip and remove the net. Then unscrew the two trim buttons behind the passenger seat. Gently prise the trim away from the door seals and pull back to expose a black metal plate and part of a white rubber foam covering the aux battery. Remove the black metal plate which is secured by two 10mm hex bolt at each end, then remove the white rubber foam to expose the battery.
Once the Aux battery is exposed, remove the +ve/-ve battery terminals which are secured by two 10mm hex bolts. CAUTION: the +ve/-ve leads are not colour coded so please make a note of which is which otherwise refitting them incorrectly would be dangerous and your car will suffer sever electrical damage! I also took the precaution to insulate the +ve terminal lead to prevent it from shorting with the -ve lead or against the metal bodywork!
Once the leads are removed from the battery, it was quite difficult to pull the battery out due to the tight fit coupled with the limited access - loosening the rubber battery tray behind the battery aided the removal of the battery.
The original battery fitted at the factory (part number A0009827008Q1) is a 12V 12Ah battery manufactured by FIAMM in 2011. The replacement battery sourced from the dealership in Hong Kong (part number A2115410001-Q8) is also a FIAMM battery manufactured in 2018.
After installing the new aux battery and refitting the rubber cover, metal plate and the trim, the ECO icon finally showed up during the test run. The Start/Stop is also finally working once again - success!
Here are a few photos (credit to my assistant) of the steps I took which I hope will help others to tackle this otherwise simple job. It took me (and my assistant) about 40 mins from start to finish requiring only one 10mm socket wrench.
File Type: jpg SLK250 Instrument console with ECO Icon.jpg (33.7 KB, 45 views)
wongl is offline
The Following 3 Users Say Thank You to wongl For This Useful Post:
#2 Old 12-05-2018
JRTTSLK55's Avatar
Vehicle: SLK 55 AMG R172 2014 Matte Finish, CFiber Trim, P30 AMG Pckg, Bi-Xenon, M.Sky Control, Designo Red
Other Toys: Canon 5D MIII , Red Lenes
cool thanks for sharing. I can confirmed it's the same location and steps as the above on r172 55amg. For me, I didn't replaced my battery but place CTEK charger on the aux battery for 1hr before my long vacation.
|.:: First SLK55 ::.|
JRTTSLK55 is offline
#3 Old 12-07-2018
wongl's Avatar
Other Toys: C300h
Quoted: 16 Post(s)
Curious to find out if recharging the Aux battery (which should be AGM type) with a CTEK charger can restore the aux battery to support the Start/Stop feature?
I have recently ordered a CTEK Start/Stop charger but wouldn't be picking the charger until I return to the UK for my Christmas vacation.
wongl is offline
#4 Old 03-16-2019
Cozzi's Avatar
Vehicle: SLK200 Blue Efficiency Edition 125 Nov 2011
This is a superb tutorial. Take a bow!!!
I followed it to the letter, and changed my auxiliary battery yesterday. One tip...give the new battery a ‘clean’ with Mr Sheen furniture polish: it helps the replacement battery slide in easier. Stop/Start was back working immediately. As in the above post, my battery was made in August 2011(no wonder Start/Stop had packed-in!), and the new one in December 2018.
wongl likes this.
Cozzi is offline
#5 Old 04-09-2019
Robuk's Avatar
Vehicle: 2015 SLK 200 Hyacinth Red, auto
Other Toys: Mk1 Audi TT remapped, Mercedes C-Class Coupe
Quoted: 17 Post(s)
Send a message via AIM to Robuk
Did you know the actual on the road fuel gains according to Honest John between the petrol R171 and the R172 200 SLK are an amazing 1.9%, the improvements to the R172 are, direct fuel injection, turbo, stop/start and energy regeneration.
Is this worth the cost of a new battery, how much fuel savings are actually down to stop start, this is UK driving not Hong Kong.
Robuk is offline
#6 Old 4 Weeks Ago
Vehicle: White/beige 2012 350
Quoted: 79 Post(s)
Is the AUX battery something to change preventively, or wait until it fails?
Mike6F is offline
#7 Old 4 Weeks Ago
LeonardoDaBenz's Avatar
Quoted: 994 Post(s)
IMO, personal preference. If you must have ECO, then consider that batteries generally last 3-? years. If your system works/doesn't work, it may not be the battery. Many things must be in sync for that system to operate, not just battery quality.
Your money, your choice, your back (being a contortionist with small hands will greatly assist you in this endeavour if you choose to go down this route).
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#8 Old 4 Weeks Ago
Quoted: 79 Post(s)
I know I don't have a ECO button on the dash, so guessing my USA 2012 doesn't have it.
Main battery hasn't been spinning the car over as fast as I would like, so I plan to check/replace that battery soon.
Mike6F is offline
#9 Old 4 Weeks Ago
Robuk's Avatar
Quoted: 17 Post(s)
Before you go to that expense check to see if you do have stop/start and regeneration, lift hood and remove plastic cover fixed to the starter battery(3 clips), if the negative battery clamp, the black lead has one of these in pic below you have stop/start and regeneration, if there is no small box attached to the clamp you don`t. If the battery is original, it may be the battery, My C-Class Coupe (same engine as R172) has original battery stamped Sept 2011, it`s still going strong but I am in the UK.
If you don`t like stop/start (for me it`s a useless piece of extra tech to go wrong) just disconnect the sensor arrowed in pic, this will deactivate stop/start, there will be NO CEL on dash and the car drives normally, (you do loose brake hold but that`s all), you get an extra bonus which is far more advantages, well it is for me. With the sensor disconnected the EMU which controls the alternator goes into a pre-arranged charging mode(as it does if sensor fails) and instead of only charging battery to 75% will now charge it to 100%, at between 13.8 volts float and 14.2/3 volts charge, link below.
Edit, I just reread you post, I own 2 Merc`s a C-Class 2012 model and an SLK R172 2015, on the C Class the symbol stays yellow on dash when stop/start is not working, when stop/start is not working on the SLK there is NO symbol on dash, same as your car.
#104 Old 3 Weeks Ago
I had a bit of time on my hands this evening so I have now implemented my switch idea. I had the switch already left over from another project and some 2 core cable of the appropriate size.
I routed the 2 core to the cabin from the battery compartment using the convenient grommet just behind the battery. The sensor wiring has a red power cable connected to the positive battery terminal and a blue one which is the sensor output to the rear SAM. I’ve put the switch in the blue signal line. I’ve installed the switch in the kick panel above the pedals, so it’s in reach from the driver’s seat but out of sight.
So now with the switch closed it’s OEM behaviour and with it open stop/start and brake hold are disabled but crucially cylinder deactivation is unaffected!
https://www.slkworld.com/slk-r172-ge...ml#post4542330
Robuk is offline
Tags
aux, battery, eco, slk250, start/stop
Mountainaire
Replacing front S.A.M. to get AC working? bigbloch SLK R171 General Discussion 42 3 Weeks Ago 09:04 AM
Original Battery MickSLK New Members Introduce Yourself Here 22 09-07-2013 04:48 PM
Battery needs replacing t2a4testjet Where to get R171 SLK Items 17 11-04-2012 11:30 PM
Side Mirror Indicator not working after replacing with BN mdux SLK R171 General Discussion 7 03-30-2012 11:44 AM
05' 55 AMG Battery size / R&R ? coolsat SLK R171 General Discussion 8 04-25-2011 01:11 AM
