R172 Nose Cone Top Badge Removal/Replacement - Mercedes Benz SLK Forum
 9Likes
  • 7 Post By Mr Tuscan
  • 1 Post By TonyS3
  • 1 Post By oldmercman
#1 Old 02-18-2018
Vehicle: SLK R172 250 CDI 2012 Red AMG Sport
Quoted: 16 Post(s)
1. Twist off the front MB star badge from the front grille by twisting one inch anti clockwise and pull to remove (non distronic models)
2. Using a torch locate the two pins on the underside of the top nose cone badge.
3. Using a short stubby crosshead screwdriver gently place the tip in the end of one of the pins and apply a little pressure to see if their is any movement in the badge above, this will allow you to see if the badge is glued or just pressed into the nose cone, if it appears glued it may have been replaced at some point as MB did not glue this badge, the pins are all that is required to hold the R172 badge in place, the pins are expanded on the ends and create a tight fit into the nose cone holes.
4. Once happy their is movement, use a trim remover tool or similar to gently work your way around the badge working from one side to the other, at the same time you can continue pressing the tabs from underneath to help guide the badge out.
BE CAREFUL NOT TO DAMAGE THE NOSECONE WITH REMOVAL TOOL!
5. Once removed you can simply push the replacement badge into the holes till it secures flat, there should be no need to use any glue to secure it.
6. Stand back and admire your new badge/replacement
File Type: jpeg FF19767E-309B-4F76-B023-A71EA9DEB2B6.jpeg (62.8 KB, 43 views)
File Type: jpg B19C0D91-2EB8-497B-8563-F93200976EA1.jpg (47.9 KB, 56 views)
JudgeMing, Col, Rv8 and 4 others like this.
Mr Tuscan is offline
The Following 4 Users Say Thank You to Mr Tuscan For This Useful Post:
#2 Old 02-18-2018
LeonardoDaBenz's Avatar
Quoted: 996 Post(s)
I really do wish there was a smaller star in there. Personally, I prefer less "in your face" but that's just me.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#3 Old 02-20-2018
Vehicle: 2011 R172 350 Sport AMG (Obsidian Black)
Quoted: 93 Post(s)
It would appear mine has been glued in place.😩
greenmanslk is offline
#4 Old 02-20-2018
Quoted: 16 Post(s)
It is stiff to be sure, took some persuading somewhat
#5 Old 03-05-2018
Quoted: 93 Post(s)
It ain’t shifting...
Might borrow the wife’s hairdryer.....
#6 Old 03-05-2018
Col
Col's Avatar
Quoted: 709 Post(s)
Thanks, I’ve been considering changing to the black badge for a while. Any tips on where to get the OEM black badge at the best price?
I'm not mean... but I am 'roofless' at every opportunity!
- SmartTOP
- Blacked Out Front Grille
- Chrome Bonnet Fins
- Front Camera (Kerb Cam)
- Dash Camera (Hard Wired)
- Gel Resin Number Plates
- Acrylic Wind Deflector
- Ambient Lighting
- Vath X-Pipe and Modified Rear Silencers
- Ispiri ISR6 Alloys Wheels
Col is online now
#7 Old 03-05-2018
Quoted: 93 Post(s)
I bought mine off eBay, from an authorised MB deale, as part of a bundle with black wheel centre caps
#8 Old 11-14-2018
TonyS3's Avatar
Vehicle: 2013 SLK55 AMG
Quoted: 336 Post(s)
@Col
I know this was six months ago but MB Bristol currently have an offer on black badge swaps, either parts only or fitted. Sorry, I didn’t note the prices. May be a nationwide dealer promotion?
TonyS
Col likes this.
TonyS3 is offline
The Following User Says Thank You to TonyS3 For This Useful Post:
#9 Old 11-20-2018
Vehicle: 2012 250 petrol black/red
Quoted: 309 Post(s)
Don't laugh but as my car is black I in-filled the 3 silvered sections of the badge with black gloss paint. Matches the black version of the wheel centre caps.
Windinmyhair likes this.
oldmercman is offline
#10 Old 11-20-2018
Quoted: 309 Post(s)
I agree & the blanked version on the SLC is worse AND looks cheap.
Also I fancy a small Mercedes mascot as per older cars rather than a badge.
Now that I know how to access the badge & remove it I may go ahead.
Fuel additives and engine tick/tap/ping/knock/whine/sluggishness/hesitation and top tier gas jbanks15 Off Topic 251 04-24-2019 01:39 PM
My Thoughts on the R172 SLK55 Col AMGs 27 06-20-2018 02:16 PM
Changing R172 nose to R171 looks JudgeMing General Modifications R172 41 04-24-2015 01:02 PM
R172 Detail Specs UK-C200 SLK R172 General Discussion 5 01-19-2011 05:10 PM
