R172 2012 SLK350 Center Console Removal - Mercedes Benz SLK Forum
 19Likes
  • 14 Post By jerryholt813
  • 2 Post By nimbusgb
  • 1 Post By OldskoolRS
  • 1 Post By Windinmyhair
  • 1 Post By JudgeMing
#1 Old 01-28-2018
Vehicle: 2012 SLK350
Other Toys: 2015 Harley Road Glide
My Comand Control Knob shaft broke recently which renders the zoom capability inoperative for the Navigation system. I couldn't find any videos or steps for removing the module so I've posted the procedures I followed.
Before starting, I ordered an Auto Trim Removal Kit from Amazon. (I paid about $20, but you can get a kit that has the tools you'll need for as low as $9). You can purchase a replacement for the broken shaft and replace it yourself, or you can send the entire module to a place like IE Works (you can find them on eBay) and they will replace it for $60.
1. Start by removing the small cover, then the screw in the control that raises/lowers the top; 2. Pry open the boot on the shift lever (no need to remove the boot at the top of the lever); 3. Remove the screw on each side of the shift lever; 4. Pry off the cover at the front of the storage compartment, then remove the two screws that hold down the rear of the console; 5. Pry of the front of the aluminum cover from the dash; 6. Wiggle the aluminum plate so you can slip the boot through the hole, then flip it over to access the bottom of the control module. (This is the hardest part. I had to start the engine, put the shift lever in reverse while keeping my foot on the brake. That gave me enough room to maneuver the pieces). 7. Flip the aluminum piece over so you can remove the four screws securing the module. 8. Unplug & remove the module.
After removing the module and sending it in for repair, I just slipped the aluminum cover back into place without securing it with screws or the clips. It wasn't too loose, and it did not interfere with the shift lever.
When I received the repaired module, it took less than 30 minutes to get everything back in place. Problem was resolved for about $95 (including the trim removal tools) and about 2 hours work. You could do this without ordering the tools. You could use a 2-inch putty knife, but you'd want to put tape on the blade to keep from scratching your console.
jerryholt813 is offline
The Following 11 Users Say Thank You to jerryholt813 For This Useful Post:
#2 Old 04-13-2018
Vehicle: 1998 SLK230, 2000 SLK230, 2012 SLK250
Other Toys: Tennis Racquet
This was really helpful, but this is even more helpful:
PDFDOC
mightycpa is offline
#3 Old 04-14-2018
nimbusgb's Avatar
Quoted: 235 Post(s)
PDFDOC
if you are prepared to sign up with yet another organisation that wants your data!
mightycpa and CHELZEE like this.
nimbusgb is offline
#4 Old 04-14-2018
True, true! That's why God invented throwaway email accounts.
#5 Old 05-01-2018
Vehicle: 2012 SLK 250 CDI
Doesn't let me see it even with an account, says its not shared
warp is offline
#6 Old 05-01-2018
Quoted: 6058 Post(s)
@mightycpa ...
Wavetrac LSD thread here:
#7 Old 05-11-2018
Vehicle: 2011 R172 AMG Sport 250
Quoted: 9 Post(s)
Thanks for the description and photos Jerryholt813
Could I ask; roughly how thick is the metal part of this console? Ours has some nasty scratches caused by the careless previous owner and I would like to try sanding it to see if I can remove the marks. I wouldn't want to do this with it in place, so knowing how to remove it will be very useful, but pointless if the 'metal' is wafer thin: I have tried to locate a good secondhand replacement, but so far not had much luck and I'm sure a new one would be too expensive to consider.
LIL DON SLK likes this.
OldskoolRS is offline
#8 Old 06-03-2018
Vehicle: 2014 SLK 55 AMG
Other Toys: BSA Motorcycle
Very helpful for me as I was thinking about replacing the aluminium trim as mine has a few marks where the last owner put his bunch of keys in the cup holders. I didn’t fancy breaking the trim because I hadn’t located the screws.
Andy
Spro is offline
#9 Old 06-21-2018
Richard in South Carolina's Avatar
Vehicle: 2012 SLK 350 - Black
Other Toys: Honda CRV-2018 Ford Explorer - Two John Deere Gators & John Deer Tractor
Quoted: 15 Post(s)
My 2012 squeaks every time I put my elbow or whatever on the console. Did you notice what might make the squeaking noise?
Richard in South Carolina is offline
#10 Old 06-22-2018
Hi, When I removed mine, one of the posts that attaches underneath was broken. Luckily, it was still screwed in, even though it was detached from the trim. I used baking soda and superglue to put it back together, and that fixed my problem.
#11 Old 09-13-2018
Vehicle: fire opal red 2012 SLK 350
Other Toys: Triumph Spitfires and Kawasaki Concours 1400
3M wood grain vinyl
Has anyone tried covering this centerpiece with the 3M wood grain vinyl? Mine is pretty scratched up as well from a previous owner and I was thinking of covering it. A friend did it in his Jag and it looked very nice. He said it was very important to heat it up with a hair dryer before applying it. Didn't know if anyone else had tried it. Just asking to see if it peels up after making the bend around the sides. His was fairly at and he didn't have any problems.
#12 Old 09-13-2018
bending around corners is tough
just imagine bending around the emergency brake handle?
#13 Old 09-14-2018
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 276 Post(s)
172 has electric parking brake so no handle. Some tight radii around the cup holder/storage cover and other cut outs though.
Botto1964 likes this.
Windinmyhair is online now
#14 Old 09-14-2018
beau1230's Avatar
Vehicle: SLK250 CDI 2014
Other Toys: Harley Davidson Custom
Quoted: 9 Post(s)
I really think wood grain would cheepen the look of the car. Its a fairly easy process usi g a heat gun. Just do a search in you tube.
Sent from my SM-G935F using Tapatalk
beau1230 is online now
#15 Old 09-14-2018
Vehicle: 2012 R172 SLK350 Ed 125
Other Toys: Mini Clubman Cooper S
Quoted: 17 Post(s)
I have a colleague who had his centre console 'wrapped' in gunmetal vinyl to match his re-furbished wheels in the same colour, and is very pleased with the result.
GriffSLK is offline
#16 Old 09-15-2018
JudgeMing's Avatar
Vehicle: 2012-R172 55 AMG, last of the MB-NA-V8 engines
Other Toys: AN650Z (Grey)
Quoted: 314 Post(s)
That's the leather of the armrest rubbing along the lid of the pouch to the roof knob. That little rest can be moved forward a little and fixated again (one torx).
Formerly: Aurë, black 2005 R171-350 w. AMG package, Akzentrot interior and almost full options.
Current: Metallic iridium silver 2012 R172-55 AMG with red accents, BMC airfilters, ECU tune, KW V3 coilovers, SS brake lines, rear cam, dash cam and almost full options.
JudgeMing is online now
#17 Old 01-04-2019
Vehicle: SLK 300 2015
Surfing the net I saw that the SLK 300 with 9G-Tronic had some peculiarities for remove the central console, I read it "distracted" but cause at the time I did not need it, now obviously I do not find the topic: whiteflag:
Do any of you have any idea how to proceed to remove the central console of a SLC or SLK 300 2015 ? :?:
opalis3 is offline
#18 Old 17 Hours Ago
Vehicle: MB SLK200 2013
Other Toys: guitar, piano
thank you for your explanation w/ photos in detail!!!
stereomuse is offline
Tags
center console, command control knob, command control module, navigation zoom, slk350
Botto1964
Approach and Departure Angles for R172 SLK350 Maike13 SLK R172 General Discussion 7 12-03-2017 07:59 AM
Leather center console options DvintSLK SLK R171 General Discussion 20 07-28-2016 08:29 AM
Center Console Light BrianS SLK R171 General Discussion 14 08-05-2009 12:08 AM
Center console removal BikerDrew SLK R170 General Discussion 3 03-06-2007 11:42 PM
Those rear center console speakers bclark SLK R171 General Discussion 43 08-15-2006 09:17 PM
