Led headlight Upgrade - Mercedes Benz SLK Forum
 9Likes
#1 Old 04-29-2017
PC017's Avatar
Vehicle: SLK 250 CDI AMG Sport Tip 2014
Quoted: 16 Post(s)
Got a bit fed up with how bad the headlights are (even with the aim adjust etc) so decided to go LED for a bit better performance.
H7 120W Philips Lumiled LED Headlight Bulb Kit Canbus For Mercedes CLK SLK 97-On | eBay
Easy enough but high beams are fiddly so will no doubt need light out to do. I dropped one of the bulb collars too so it's gonna have to come out to retrieve and I'll do them at the same time
I'd recommend jacking the car up a bit for easier access but all in all took me around 30 mins.
Some things to bear in mind - careful to not drop the clip!!! Put the bulb collar on first and then fit buld.
Steps to do are;
1) Turn wheels away from side you are working on
2) Jack car up at least 6 inches
3) Remove bulb covers
4) Remove connector
5) push clip up and remove old bulb
6) Fit new bulb collar, hold in place and slide clip down
7) Fit ballasts, test and reassemble
8) Rinse and repeat for the other side.
Voila!
jbanks15, Trev5, 55russamg and 3 others like this.
PC017 is offline
#2 Old 05-01-2017
Red 250's Avatar
Vehicle: 2014 slk 250 amg sport (mars red)
Other Toys: vfr1200,gen 1 hayabusa,kawasaki1400
Quoted: 51 Post(s)
This is nice to know,so no lights on dash with this mod and everything works as it should,been looking at an alternative to the usual hid kit
Red 250 is offline
#3 Old 05-04-2017
PC017's Avatar
Quoted: 16 Post(s)
Lights all good - no dash warnings
PC017 is offline
#4 Old 05-05-2017
Fishsf's Avatar
Vehicle: 250 CDI AMG Sport 2014 R172 iridium silver Rear Lip spoiler, Rear View camera and Windrestrictor.
Other Toys: BMW X3 35d M sport, Bmw 1200gs
Quoted: 22 Post(s)
do you have pics at night to show them working /beam pattern etc?
Fishsf is offline
#5 Old 05-05-2017
ixion's Avatar
Vehicle: 2002 R170 SLK 230 Kompressor. Silver. Black Leather. 67k Miles
Other Toys: I also have a 320CDI Estate, Silver,Black Leather, 61k Miles TWIN of SLK & 2013 Smart Car in Blue.
Quoted: 41 Post(s)
I would be interested to know how Hot these Bulbs get and the area of greatest heat. (Front,Back ?)
ixion is offline
#6 Old 05-16-2017
Dub
Vehicle: slk200 r172 2012
Were your lights under the main light yellow before? If so, could you tell me how did you change them to that color and what kind of bulb are they? Thank you.
Dub is offline
#7 Old 06-06-2017
Fishsf's Avatar
Quoted: 22 Post(s)
Bought the same bulbs and fitted them, sadly dash warning, rhs low beam warning , so i guess you must have been lucky or i am just unlucky.
Fishsf is offline
#8 Old 06-06-2017
Moderator/RoTMorganiser
Quoted: 2150 Post(s)
Thanks for joining SLKWorld.com.
This may help you settle in.
https://www.slkworld.com/new-members-introduce-yourself-here/439993-new-wondering-what-do.html
Please post an introduction:
Please update your vehicle/location details:
The reason that we ask you to update vehicle/location details is to save repeating the same
information every time that you ask a question.
#9 Old 06-06-2017
Did you buy from the same supplier?
H7 120W CSP Lumiled LED Headlight Bulb Kit Canbus For Mercedes CLK SLK 97-On | eBay
#10 Old 06-08-2017
Fishsf's Avatar
Quoted: 22 Post(s)
yes, used the link posted.
Fishsf is offline
#11 Old 06-08-2017
PolarisFlyer's Avatar
Vehicle: 2014 SLK250 (R172)
Quoted: 26 Post(s)
Even though I had trouble-free operation with mine for several months, I am now experiencing the same issue with my LED bulbs. However, I did not buy the same as described above. However, I am learning that I may have omitted the Resistor pack that came with my kit. I will be installing them this weekend and will report back.
PolarisFlyer is offline
#12 Old 12-10-2017
Vehicle: SLK350 2013
Hi Guys,
Also upgraded the low beam lighting on my 2013 SLK350 and used the following product.
https://www.auxbeam.com/headlight-bulbs/H7/88621845
Came with control drivers to avoid error messaging.
Lights are looking great. Now I need to find a better solution for high beam since they are super yellow in comparison.
slkblacknc is offline
#13 Old 12-25-2017
Vehicle: 2012 SLK250
Recommendation: sinoparcel 6000k 8000LM passive radiator LEDs. Error free. Decent downfield. Probably not 8000LM more like 4000 but thats still 2x the Sylvania junk that MB uses. Can be used for both projectors and brights. $45 on Amazon.
maxspek is offline
#14 Old 12-25-2017
Vehicle: Audi TTRS MY2017
Other Toys: Whyte Prst-1, MY2017 Audi A6 allroad Competition, 1/50th Twin Squirrel, 2006 Fabia vRS Hybrid
Quoted: 619 Post(s)
The problem with anything from China is that the suppliers are permanently evolving their products ie. to make them cheaper to sell and produce and it’s very common for a supplier to pack 1000 kits that they put genuine time and effort into producing then reinvest the profits from that in 10,000 units that they just bang out. When the warranty claims come in, they’re either not there or not interested.
At least if you buy from eBay and pay PayPal you can get your money back easily enough.
wja96 is offline
#15 Old 12-25-2017
Quoted: 619 Post(s)
Originally Posted by slkblacknc View Post
Hi Guys,
Which of the two packaging designs that they “randomly deliver” did you get? I would avoid any seller outside of the eBay system simply because paying by PayPal gets you your money back if they don’t work.
wja96 is offline
#16 Old 12-25-2017
6007.us
Padgett's Avatar
Quoted: 557 Post(s)
My concern is how long the bitty fans in the base will last and what happens when they fail. Have a set and are bright but would not fit into my projectors.
ps pull 4.2 amps which should not upset the light monitors.
Padgett is offline
#17 Old 12-26-2017
A) eBay and PayPal are both scams. Just like you can "get your money back" they can "take money out of your account."
B) active cooling with a fan is about as backwards in energy dissipation as you can get. I would not buy any design that relies of ball bearings, especially when claiming water resistance.
maxspek is offline
#18 Old 12-26-2017
I got the lights delivered in a black with orange coloring box and bought them through Amazon in the US, so no transaction issues.
#19 Old 01-08-2018
Vehicle: 2017 C63 AMG Cab
Other Toys: W213 E220,
Quoted: 40 Post(s)
Watch this space, mine's having a bi LED projector fitted this week!
PC017 likes this.
Current: R172 SLK200 (tenorite), W213 E220d with a few options (obsidian), B180 Eco, Fiat 500 Lounge Twinair (BNW), VW Caddy Life.
Gone:W212 E220CDi Edition 125 Avantgarde, W204 C320CDI Sport with advanced agility 2007 (black!), W211 E270CDI Classic 2003 auto (silver of course) , W168 A170CDI Elegance 1999 auto
Tim S Kemp is offline
#20 Old 01-13-2018
Quoted: 40 Post(s)
LED conversion
The projectors are in! Went for a bi-led projector setup, and then also had the main beam changed for an LED so at full beam there is massive output.
Will take some good pics soon, but here's some dashcam from my run home! (work was done by Headlight Retrofits in Renfrew)
Trev5 and 55russamg like this.
The Following 2 Users Say Thank You to Tim S Kemp For This Useful Post:
DIY : R171 Replacement of the original bulbs with LED pack michjul SLK R171 Class DIY 62 10-02-2018 07:35 AM
Led Bulbs ixion Off Topic 22 06-07-2017 11:21 AM
LED headlight bulb on US SLK with incandescent drinky1 SLK R172 General Discussion 10 08-26-2016 02:47 PM
Replace Mercedes benz LED headlight bulb-Is it is easy to replace LED bulb? Does there any error code after replace it? Shelly General Modifications R171 10 02-06-2016 06:47 AM
