Panoramic roof headliner swap - Mercedes Benz SLK Forum
 50Likes
#1 Old 02-29-2016
Vehicle: Black 2013 250 CDi
Other Toys: CBR 650F
A big box came today, with the label showing A1727900045 / 9H23 for a panoramic headliner in black.
The pictures show before and after on the roof, and the removed headliner, which shows where the clips are. Also, I've shown how you can peel back the original trim to make sure you can see through the roof before ordering the part - newer ones have been painted to prevent this.
Hope this helps someone in the future. It's a pretty easy job where you just gently pull off the old and press in the new.
littleghoti is offline
The Following 3 Users Say Thank You to littleghoti For This Useful Post:
#2 Old 02-29-2016
Quaser8386's Avatar
Vehicle: Was a 2013 SLK 250 CDi - Alas! Gone Forever
Other Toys: Vauxhall Cascada (the wife's really)
Quoted: 183 Post(s)
Hi. Forgive the newbie question!
Does this kit mean that if you have a 'hidden' glass roof, you can buy this to replace your existing inner lining?
I've taken delivery of my 2013 SLK 250 TODAY. I knew it didn't have the 'optional extra' panoramic roof, but mine is certainly made of glass. This may just be an economic way to get the view.
Thanks for posting
dbgrn and Pictor like this.
Quaser8386 is offline
#3 Old 02-29-2016
Vehicle: Had a 2013 SLK 250 Cdi in F/O red, now have 'Woody' a 2017 A*** TT Coupe in tango red (what else?)
Other Toys: Mini Cooper in Red
Quoted: 152 Post(s)
Yep, littleghoti's post shows how to check the glass panel hasn't been nobbled by MB, but the model year of your car suggests that it'd be OK for you to do this mod.. unless the roof panel has already been replaced by for some reason.
This cheap upgrade is just one of the reasons I chose my particular car.
bastivock is offline
#4 Old 02-29-2016
Quaser8386's Avatar
Quoted: 183 Post(s)
Much thanks for this. How cheap is 'cheap' ? Given that I have just spent the best part of *£loads of dosh*, not sure I could persuade 'er indoors to let me spend much more!
bastivock likes this.
#5 Old 02-29-2016
Quoted: 152 Post(s)
Sorry, by cheap I mean ****ing expensive for what it is (a piece of textured black plastic with a hole in the middle)... around the £190-£200 mark!
But it's a lot less than MB were charging for the pano roof option when specced on a new car!
#6 Old 03-03-2016
Quaser8386's Avatar
Quoted: 183 Post(s)
Agreed that for what it is, it's a lot, but a drop in the ocean compared with what my new car cost, and I'm pretty sure that a new handbag will get me the Ok from SWMBO. Thanks
#7 Old 03-04-2016
More thoughts
So, the fancy bit of plastic cost £190.08 to me, including delivery, and fitting was easy.
Driving along, it's quite easy to forget that the change was made, but it has made everything a bit lighter inside. There hasn't been too much sun to check out if it gets hot, but so far I have no regrets. There was one slight drawback that I came across the other day, where on crossing lanes, the divider reflected off the roof and out of the corner of me eye, there was some flashing.
The tint on the roof is a bit darker than I would have expected it to be as well.
#8 Old 03-08-2016
Fishsf's Avatar
Vehicle: 250 CDI AMG Sport 2014 R172 iridium silver Rear Lip spoiler, Rear View camera and Windrestrictor.
Other Toys: BMW X3 35d M sport, Bmw 1200gs
Quoted: 22 Post(s)
Roof liner
I did this when we bought ours, we nearly did not buy the particular car until we found out that we could simply swap it out and have a see through roof!!!
It was news to the dealer, who now offers this optional service. If anyone wants a panel to block out the light i am sure we can come to an arrangement
Fishsf is offline
#9 Old 04-13-2016
An update- leaking water
So, it all seemed fine after fitting, but we've had some nice weather, followed by some nasty weather so after opening and shutting there is now a leak in my roof.
It is on the front seal, where the roof meets the windscreen - there is a gutter that looks like it should collect the water, but rather than draining down, it drops onto me and the seat - see attached photo.
My best guess is that something has fouled on the liner that stops the roof re-latching properly. I've removed and replaced the liner so hopefully that will stop it. I have stuck a bucket of water over it since, and it seems OK, but if anyone has any ideas or experience, then let me know,
Cheers!
#10 Old 04-28-2016
Separate problem
I found some spare parts in the boot / trunk that looked unimportant, but had fallen off the roof when folding. It seems there are some parts on the B-pillar that locate and provide some thrust against the front seal. After screwing them back on the leak is gone!
#11 Old 08-03-2016
Vehicle: SLK 250cdi AMG SPORT
Hi, I just bought 2013 250 cdi. Can you tell me where you ordered the panel from.
Cheers!
David Crain is offline
#12 Old 08-03-2016
Quoted: 6355 Post(s)
Cheers!
David,
First please update your location and vehicle (year?: 1996-2017, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable or to ‘edit’, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
#13 Old 08-03-2016
Jules555's Avatar
Vehicle: 2013 SLK 250 CDi AMG
Other Toys: Aston martin DB9 Coupe 1/18 Aston Martin DBR1 1/18
Quoted: 223 Post(s)
Cheers!
Hi, I have swapped mine also, part comes from MB. Part number is in the first post on this thread. Hope this helps.
Jules555 is online now
#14 Old 08-03-2016
Brett12060's Avatar
Vehicle: SLK 250 CDi year 2013
Other Toys: Mazda rx7 Land Rover discovery 3
Quoted: 29 Post(s)
Thinking
I'm thinking about this as an option !
But if it ain't raining the top is down sunny or not windows up its alright on the motorway too at 90mph mmm I meant 68 mph
Brett12060 is offline
#15 Old 08-03-2016
90? real men do 180
https://www.slkworld.com/1675737-post144.html
#16 Old 08-03-2016
Brett12060's Avatar
Quoted: 29 Post(s)
Yes I have heard you like to drive your cars backwards over the pond like 180 degrees 😂
Our roads are very rarely that clear n I like the ride too much to rush it 😎
#17 Old 08-04-2016
Quaser8386's Avatar
Quoted: 183 Post(s)
Like my friend @Jules555, I fitted this option to my SLK. Got the part from my local MB Main Dealer. It took 3 days to arrive as it had to be ordered in. Once I had it, took less than 15 minutes to remove the old one and install the new one. This was the first mod I made (next came the Smart Top, but that's a different story).
I agree that when it isn't raining the top is down - but there are plenty of days here when that isn't an option. The open roof liner really makes a difference, making the car feel lighter inside. I imagine that if you have a dark interior (mine's cream), then the difference is even more marked.
My advice is to make sure that you seat all of the plastic lugs firmly and correctly. As another poster has said, if any of these lugs come loose, especially from near the front, then this could cause water to leak in.
Have fun!
SLKomatic likes this.
#18 Old 08-25-2016
Vehicle: 2015 SLK 250d AMG Sport
Other Toys: 2014 Lotus 7-type
Hi Guys...
2012-2014 SLK's have a glass roof that's mostly black, but with a lighter rectangle in the centre. I assume this marries up with the cutout section of the alternative inner liner.
My SLK is a 2015, but the glass roof in that is entirely black. I would like to get the 'free' pano roof by replacing the solid headliner for one with the cutout, but I'm wondering if there would be any point.
Do both models use exactly the same roof liner(s), and if so, do they attach in the same way?
With my roof seemingly black all over, if I swapped the headliner, would the cutout bit simply reveal a totally black section of glass?
Or is it perhaps not as black as it looks?
Is it the glass itself which is black, or is it essentially plain, but with some finish that could perhaps be removed? If so, how?
Nobody I've spoken to at MB so far seems to have an idea about any of this, and while the car's still under warranty, I'm reluctant to start pulling at the inner liner in case I break something.
Any help appreciated
David
turnipfarmer is offline
#19 Old 08-25-2016
Jules555's Avatar
Quoted: 223 Post(s)
There are other threads around at the moment concerning this, but I am fairly sure that by 2015 MB had started coating the inside of the roof to make it opaque. So as you said not a lot of point in swapping your roof liner.
I have a 2013 model and did do this mod to mine as I had the clear section in the roof.
#20 Old 08-25-2016
Vehicle: 2013 SLK 55 AMG
Quoted: 23 Post(s)
I've just had my roof replaced a few days ago, and it is definitely a glass top now. I see in the OP that you can peel the headline back a bit to see if your top is clear. I don't have high hopes as it's new and probably blacked out. Hard to tell from the pic, but is it from the corner of the pillars where the top locks on to the front windshield?
sleebus is offline
Panoramic roof Dsr207 SLK R172 General Discussion 75 10-11-2017 05:46 AM
R171 Vario Roof Delays akaillwill SLK R171 General Discussion 20 05-16-2016 02:15 PM
Spyshots: All-New Mercedes C-Class Coupe Shows Huge Panoramic Roof Berliner Heckflosse Off Topic 0 07-06-2015 06:17 PM
Roof would not open and headliner sagged GeorgeG SLK R170 General Discussion 5 01-15-2013 11:14 AM
