R172 SLK350 Cabin air filter replacement - Mercedes Benz SLK Forum
 18Likes
  • 14 Post By jake007
  • 1 Post By jbanks15
  • 1 Post By Mike Florey
  • 1 Post By myeeplacee
#1 Old 07-24-2015
Vehicle: 2012 SLK 350
2012 SLK 350 Cabin Filter Replacement
Part # Mann 999279E
1. Pull back carpet and padding on passenger side floor (PIC#1)
2. Remove panel under glove box. There are three T20 screwsholding it in place. These are located in the front. (PIC #2 )
3. Unhook connector to light and remove panel (PIC #3 )
4. Locate air conditioner cover. It has a hose connected to it and two whiteretaining sliding clips (PIC #4 )
5. Slide clips out and remove cover. The folded filter canthen be pulled out. Note the orientation of the filter so you can re-install itproperly.
6. Install new filter or clean it if it can be re-used. Notethat filter is folded and that the open end faces the right. There is anindentation in the plastic cover that shows the filter orientation.
7. Re-install cover by inserting the two prongs on theengine (back) side of the cover into the notches on the air conditionerhousing. Slide clips on front of cover to lock. Check to make sure cover is installed tightly by pulling on cover. Thenstart the car and turn on the air conditioning to check for air leakage.
8. Re-connect wiring to light and re-install panel using thethree T-20 screws.
9. Push carpet back into place.
JB Edit: Video added post 5
jbanks15, Ynot, tullyking and 11 others like this.
jake007 is offline
The Following 4 Users Say Thank You to jake007 For This Useful Post:
#2 Old 05-02-2016
Vehicle: SLK 200 R172 from the year 2012
Hoi Jacke007,
Can i clean the cabin air filter whit a vacuum cleaner?
kind regards from Holland
Jajo is offline
#3 Old 05-02-2016
Quoted: 6359 Post(s)
Originally Posted by Jajo View Post
Hoi Jacke007,
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
#4 Old 05-02-2016
Hoi Jacke007,
No. It is not that type of filter
#5 Old 01-12-2018
2014 2015 Mercedes SLK 250 CDI Cabin AIR Filter Change / Replacement
Mike Florey likes this.
#6 Old 07-14-2018
pscheuer's Avatar
Vehicle: 2015 SLK 250 R172
Quoted: 11 Post(s)
I appreciate all of the detail. I changed my filter yesterday on a 2015 R172 250. One thing to add is be sure to align the tabs of the cover on the backside (they face the footwell) with their mating slots (see the attached picture). You may need to push the cover toward the back of the footwell to ensure solid engagement of the tabs into the slots. The fit on mine was quite tight.
If you miss engaging the tabs, you probably won't be able to re-engage the slides. The cover will fall off.
I also fitted the filter into the recess of the cover and raised the cover and filter into the housing.
pscheuer is offline
The Following User Says Thank You to pscheuer For This Useful Post:
#7 Old 08-15-2018
NMBruce's Avatar
Vehicle: 2012 Black SLK350
Other Toys: 2006 Lexus GX470 lifted and bumpers
Quoted: 86 Post(s)
Thank You for the write up
I knew I shoulda taken that left turn at Albuquerque! - Bugs Bunny
NMBruce is offline
#8 Old 11-25-2018
From i860
https://www.slkworld.com/4455709-post5.html
#9 Old 01-26-2019
Mike Florey's Avatar
Vehicle: 2012 SLK 350 (Atomic Death Toboggan)
Other Toys: Jeep Grand Cherokee Overland Summit, Racing plane (pylon racer), Polaris ATV
Quoted: 65 Post(s)
On my to-do list
I'll have to spend less time on this forum because I keep coming across more things to do.
I just ordered the replacement filter.
Windinmyhair likes this.
A guy knows he's in love when he loses interest in his car for a couple of days. ― Tim Allen
Mike Florey is offline
#10 Old 04-24-2019
Rooster OG's Avatar
Vehicle: 2013 SLK55 AMG
Quoted: 16 Post(s)
What a goofy set up. I don’t think I could come up with a weirder cabin air filter design if I tried. I guess the air is double filtered? Is that why it’s folded in half? That would be a good thing I guess?
Rooster OG is offline
#11 Old 04-24-2019
Not really. just V shaped
Rooster OG likes this.
#12 Old 1 Week Ago
Vehicle: 2008 SLK 280 EDITION 10
Other Toys: 70 C10 Step 250/6 Built & NOS 375 hp - 89 Honda JDM B16A Hatch - 78 Suzuki 750 GSE
Quoted: 8 Post(s)
I Replaced my Cabin Air Filter
Hope you bought a good filter.
Just finished installing the cabin air filter in my '08 280.
It was a pain but I got it done without destroying anything.
The down side to this project was my choice of supplier and brand of filter to install.
I bought a charcoal impregnated filter, Part # LAK 246, from A**o P***s W*******e. It was supposed to be OEM/quality however it was several rungs below the one I removed. Cheap materials, weak frame and shoddy construction. One of the issues I encountered is that it was limp and very difficult to coax into and button up the housing. It also greatly increased the noise level in the cabin with the blower on a moderate speed.
I have scratched this supplier off my list of approved vendors. I will purchase a good filter from a MB dealership or web site and replace it. Sometimes an education is costly.
Looking back I would have been better off to just blow out the old filter and return the new one - TOO LATE - So much for hindsight.
Dennis
myeeplacee is offline
Fuel Filter Replacement Interval - Update gdb069 SLK R171 General Discussion 26 02-19-2016 09:58 AM
R172 SLK 200 Fuel Filter Replacement andresfg SLK R172 General Discussion 6 09-10-2014 05:29 PM
Slk 230 cabin filter replacement foreign freak SLK R170 class DIY 6 07-01-2013 12:31 AM
Cabin Filter & Gas Mileage wildflower19 New Members Introduce Yourself Here 14 11-15-2011 08:52 AM
Cabin Filter Replacement WhiteRabbit SLK R171 General Discussion 10 05-30-2007 05:37 PM
