Halogen Headlamp Aim - Mercedes Benz SLK Forum
 21Likes
  • 12 Post By Still Learning
  • 4 Post By bastivock
  • 1 Post By oldmercman
  • 1 Post By Topboy
  • 1 Post By Fishsf
  • 1 Post By sleebus
  • 1 Post By Geraldy212
#1 Old 06-01-2015
Vehicle: SLK 250 CDI AMG Sport 2015
The halogen headlamps are set low from the factory and perform pretty poorly as a result.
To adjust them, proceed as follows:
Make sure the adjustment wheel next to the headlamp switch is set to its highest point.
Obtain a standard 6mm allen key.
Locate the hole just above the headlamp as shown in the picture.
Insert the allen key and locate it into the adjuster (this is easy - it will be obvious when it engages)
Turn on the headlamps and shine them on a wall.
Turn the allen key anti clockwise to raise the aim. I turned mine 1.5 turns from the factory adjustment point to get to the desired aim. Remember you can always use the adjustment wheel next to the headlamp switch when trying them out.
IMPORTANT!
Remove the allen key before closing your bonnet!
Still Learning is offline
The Following 5 Users Say Thank You to Still Learning For This Useful Post:
#2 Old 07-11-2015
Vehicle: Had a 2013 SLK 250 Cdi in F/O red, now have 'Woody' a 2017 A*** TT Coupe in tango red (what else?)
Other Toys: Mini Cooper in Red
Quoted: 152 Post(s)
Don't you just love this forum? An absolute gem of information... Thank you
bastivock is offline
#3 Old 07-11-2015
Vehicle: 2012 250 petrol black/red
Quoted: 309 Post(s)
Can't wait for darkness to try this out.
Still Learning likes this.
oldmercman is offline
#4 Old 10-28-2015
Topboy's Avatar
Vehicle: Nov 2016 SLC 250 CDI AMG SPORT in Brilliant Blue - Just Lovely!
Other Toys: 1981 XJS 5.3 V12 HE - And it's a good one! The Wifes ML320 - Dog Truck!
Quoted: 34 Post(s)
Thanks SL - only driven the SLK a couple of times in the dark - but by God, those headlights are dreadful!!!
I'll dig the allen key out and hopefully get some use out of them.
Topboy is offline
The Following User Says Thank You to Topboy For This Useful Post:
#5 Old 10-28-2015
Originally Posted by Simon C Smith View Post
...but by God, those headlights are dreadful!!!
Take a look here also... https://www.slkworld.com/slk-r172-cla...b-upgrade.html
#6 Old 10-28-2015
Delucas's Avatar
Quoted: 1125 Post(s)
The headlamp aim has to be properly aligned by a mot headlamp beam tester .
Yes you can adjust yourself but you maybe charged on both headlights to re align them at a cost .
Delucas is offline
#7 Old 12-11-2015
Topboy's Avatar
Quoted: 34 Post(s)
Just a quick update - I had the Night Breakers fitted a few weeks ago and we also adjusted the beam up a tad.
It's better but still a long way short of what I had in my old E Class.
I'll prob have a go at the 65w lamps as mentioned by Still Learning.
I've done a search on the HID upgrades and there seems to be two strong for and against camps. Can't afford to chuck my warranty away though!
Topboy is offline
#8 Old 12-13-2015
Fishsf's Avatar
Vehicle: 250 CDI AMG Sport 2014 R172 iridium silver Rear Lip spoiler, Rear View camera and Windrestrictor.
Other Toys: BMW X3 35d M sport, Bmw 1200gs
Quoted: 22 Post(s)
Smile headlamp aim /bulb replacement
I Have just done both and can confirm a big improvement, now i can actually see even in the horrible misty rain this morning. As far as the mot is concerned you could count how many turns you adjust by, make a note and change it back for the MOT, tester happy and more importantly you can see where your going!
It cost me Ł25 for the Filaments (bulbs) and about 1/2 hour in time.
Fishsf is offline
#9 Old 12-14-2015
Topboy's Avatar
Quoted: 34 Post(s)
Morning Fish - so just to confirm you went with the 65w yes?
Did you do dip and main beam?
Glad you can see now!!!
Topboy is offline
#10 Old 12-14-2015
Fishsf's Avatar
Quoted: 22 Post(s)
yes i did the 65w bulbs from phoenix auto bulbs and i only did the low beam.
Fishsf is offline
#11 Old 12-05-2016
Vehicle: 2013 SLK 55 AMG
Quoted: 23 Post(s)
I would like to point out that this adjustment works equally well on the adaptive Xenon headlights. THANK YOU! That screwhole is not obvious.
sleebus is offline
#12 Old 04-19-2017
Vehicle: French SLK 200 7Gtro+ 172, May 2015, AMG pack, tenorite grey.
Other Toys: Mercedes A180 CDI, 1.8l auto box, mountain grey 2013.
Quoted: 19 Post(s)
I would like to try to raise my halogen beams to the correct level. What sort of test rig should I use? Shining the beams at a wall....how far away and at what height should the centre (or cut-off) of the beam be set to? Or is it simply best to raise the beam a little each time and try them out on a dark night? Thanks in advance.
Geraldy212 is offline
#13 Old 04-20-2017
Try one turn anticlockwise to start with and go for a drive. Add another anticlockwise turn if necessary.
Don't worry about the wall. I only said shine them on a wall so it is possible to see the beams raising as you turn the allen key.
Remember you can always adjust them down from inside the car by using the rotary dial near the headlamp switch.
The Following User Says Thank You to Still Learning For This Useful Post:
#14 Old 04-21-2017
Quoted: 19 Post(s)
Thank you Still Learning, I will go ahead and try your suggestion. On my car, unfortunately I do not have the headlamp leveling rotary dial next to the headlamp switch. So will try a small manual adjustment with the 6mm allen key and see what happens.
Halogen Headlamps Bulb Upgrade Still Learning SLK R172 Class DIY 45 03-17-2019 02:32 PM
adjusting headlamp level? Wallance SLK R171 General Discussion 4 04-28-2008 11:56 PM
Headlamp? Wallance SLK R171 General Discussion 7 03-22-2008 08:27 PM
Are the left and right headlamp cover the same? coolboarder SLK R171 General Discussion 4 02-11-2008 06:28 PM
