Lubricate your roof hinges/joints and seals - Mercedes Benz SLK Forum
  • 1 Post By jbanks15
  • 1 Post By Mensra
#1 Old 03-26-2014
Quoted: 6358 Post(s)
https://www.slkworld.com/226839-post1.html
J&MSLK likes this.
#2 Old 03-26-2014
Fanatical Member
Stinger's Avatar
Other Toys: yes
DITTO Thank you Sarge. I just received my Gummi stuff.....now all I have to do is modify a broom stick so I can complete the job.
Steven
Stinger is offline
#3 Old 03-26-2014
Here is the broomstick mod before someone asks what you are talking about
https://www.slkworld.com/slk-r171-cla...ification.html
#4 Old 03-26-2014
Vehicle: 1998 slk 230
Other Toys: 1994 lexus ls 400/1990 mercedes 230e
I just use spray grease on all linkages and bits I can't get to!!
royt is offline
#5 Old 03-26-2014
That's in the links also
#6 Old 03-26-2014
I forgot to add, if you get a tube of silicone grease and lightly smear the seals that the roof sits down on, it helps to stop the seals sticking to the roof when the roof is closed for long periods during the winter.
royt is offline
#7 Old 03-26-2014
Feel free to paste your comments also in the copied posts in the r170 and r171 diy section also
#8 Old 05-23-2015
Richard in South Carolina's Avatar
Vehicle: 2012 SLK 350 - Black
Other Toys: Honda CRV-2018 Ford Explorer - Two John Deere Gators & John Deer Tractor
Quoted: 19 Post(s)
I have been asking around about what grease to use on the roof's moving parts. Here are the results.
My Dealer – A couple of years ago. Rubber Care by Wurth & any petroleum based grease.
My Dealer – Last week. Krytox #A0009893660 to lube rubber seals. Mercedes does not recommend any lube at mechanical points.
Dealer in Charlotte, NC – Do not grease the top & nothing on the rubber seals
SLK Club – Gummi Pflege & Krytox grease.
What to use, what to use???????
Richard in South Carolina is offline
#9 Old 05-23-2015
as the thread says for vario hinges. Lithium spray grease. trust me
#10 Old 05-03-2018
Vehicle: White/beige 2012 350
Quoted: 77 Post(s)
Does the broomstick work on the R172
Mike6F is offline
#11 Old 05-03-2018
Of course!
When the broomstick diy was made...there was no r172
#12 Old 05-09-2018
Vehicle: 2012 250 petrol black/red
Quoted: 309 Post(s)
DON'T be tempted to lubricate without using the broomstick. I tried & had to move VERY quickly when the roof started to move. Now off to make my own broomstick - lesson learned.
oldmercman is offline
#13 Old 05-09-2018
Mensra's Avatar
Quoted: 330 Post(s)
I just leave the engine running, and stick my head in there. If I lose my head, I won’t lose very much!
SunBurst:2018 likes this.
Mensra is offline
#14 Old 05-10-2018
Quoted: 309 Post(s)
When I nearly caught my head I had opened the roof so the roof moved backwards so I assumed you activate the roof to close then place the broomstick to stop the process continuing i.e the broomstick jams it.
#15 Old 05-10-2018
after finishing with broomstick, make sure one continues the roof operation in the direction it was going
ie., if you were opening it to use the broomstick, when done, continue the opening process
and vice versa.....otherwise, the system will get confused. just sayin'
#16 Old 06-10-2018
Kandi'sSLK's Avatar
Vehicle: 2014 SLK 350 Polar White
Other Toys: Lots
Quoted: 57 Post(s)
Got mine in the mail last week, it will be the second thing on my list!
Kandi'sSLK is offline
#17 Old 06-10-2018
LeonardoDaBenz's Avatar
Quoted: 994 Post(s)
Further to this, in all likelihood your first attempt will leave a larger-than-desired gap between end of stick and the windshileld.
I had a gap of about 2" and the roof would not drop. I waited about 5 minutes but my arms got tired ever-so-gently pushing it to close that gap..
SO I just reversed the motion (close it instead of opening) just a smidge and it came tight. When finished I did fully open the roof (initial action) to remove the stick with no issues.
You can reverse the motion without ill effects mid-action (at least for a 2" range)
YMMV.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#18 Old 06-16-2018
Vehicle: 2016 SLK55, Mystic Blue, Black Nappa, P3, Performance Pckg, Carbon Trim, Illuminated Doorsils
Other Toys: 1700cc Vulcan Cruiser, all black and chrome
Quoted: 113 Post(s)
Out of curiousity, why not just pull the lever to open the roof but release it when the roof is midway open? Doing that on my 2012 350 stops the roof from opening fully. It freezes mid cycle with all the mechanisms exposed. Is this not normal? I'm trying to understand why you need the broomstick mod to keep it in place.
cousjcc is offline
#19 Old 06-16-2018
Quoted: 994 Post(s)
@cousjcc Hydraulic pressure graduallly releases and after a few (5? 10? minutes) is not enough to hold the roof in position/the roof drops whichever way gravity is pulling it down on whatever side it's not balanced on.
Not good when you have your arms/hands in there snaking through the angles to lube stuff
BTW, that is what I've read elsewhere on SLK and I tend to believe what I read here (and not find out the hard way )
LEN
(Moderator)
SAlexander
Lubricate your roof hinges/joints and seals jbanks15 SLK R171 Class DIY 28 04-26-2018 01:58 PM
Is this the stuff to put on the roof seals to stop squeaking? Charlie Croker SLK R171 General Discussion 27 10-22-2014 07:39 AM
Lubricate your roof hinges/joints and seals jbanks15 SLK R170 class DIY 2 03-26-2014 12:07 PM
