Oil Seepage from Cam Expansion Plugs - Page 2 - Mercedes Benz SLK Forum
SLK R171 Service Campaigns (TSB) This section is for any valid technical service bulletins (TSB) or service campaigns.
 13Likes
#21 Old 02-19-2015
Guest
Vehicle: 2007 Mercedes SLK55 AMG - Red
Other Toys: 2008 Audi A6, 24' Doral Cavalier boat.
Cool
Originally Posted by Steve D View Post
Doubt it's weather related. Take a flashlight and rub your finger around the bottom of the plugs ... if there's a leak there should be some residual oil on your finger.
That's how I noticed the leak on my 2005 350.
You don't say where the oil is leaking? My SLK55 AMG was leaking in several spots around the valve covers and I found that several of the valve cover bolts were loose - leaking stopped when I torqued the bolts down properly to 9 NM
Regards
Rick
100929 is offline
#22 Old 07-11-2015
Vehicle: SLK gone.
Other Toys: Skoda Fabia 1.2 TSI DSG
Quoted: 35 Post(s)
Hi Guys, I noticed an oily film on the LHS cat. so investigated. Saw that oil was dripping down from a leak from the large blanking cover. I checked all the others and no leaks were seen. I bought 1 large and 2 small covers for a total of Ł11.73. I removed the large one with a screwdriver blade after cleaning all round the area and checked inside the orifice with a mirror. Nothing untoward to be seen. Wiped everything clean and installed the cover pressing home firmly and evenly. I did not change out the small covers as no leaks could be seen.
Points to watch. On the cover there are sections that are slotted to make installation easier. I marked the old one before removal and orientated the new one the same way. When removing the old one of the slot segments broke off but did not go inside the engine. I noted that on one the side of the cover all the segments were brittle and broke off easily but the other side was fine. So the old cover needs to be removed with care. I did not lubricate the new cover. The old cover had a lot of oil trapped in it and that ran down the back of the engine so rags should be placed under the cover.
On examination I noted the brittle segments had been on the upper side of the cover as it had been installed. Also here the rubber sealing had deteriorated and maybe caused the leak. Oil pooling may have prevented the lower side from get as hot and becoming brittle. One might say that the leak would be from the bottom but this may not necessarily be so. I also noted the new cover had a different part number and appeared to have a slightly different profile.
So, not a difficult job or indeed expensive and I can see no reason for the cover to leak again anytime soon. A long run I hope will confirm this. I believe all these seals will fail eventually so will need replacing. MB used a cost effective method the close the orifices and my covers lasted at least 60000 miles so not complaining.
curro101 likes this.
thisistrigger is offline
#23 Old 09-06-2015
Vehicle: 2005 SLK350
Other Toys: G500, C240-4M, U1100 (416) Unimog, Military Air-Portable Land-Rover, 1944 Dodge WC-63 6x6
Quoted: 14 Post(s)
I've had my SLK a week. I have noticed that after I drive up a very steep hill (such as my driveway), that when I park, I smell a slight smell of burning oil on something hot, like the exhaust system. I do not smell it any other time, and I've been paying attention after first noticing it. It is consistent that I smell it after driving up my driveway, every time.
If I immediately open the hood, I do not smell it in the engine compartment. Also, there is no sign of oil dripping on the garage floor.
My first thought is that it's the car telling me not to park him, that I need to be driving. I guess that's possible, but in case that's not the reason, I wonder if this plug TSB could be the problem?
I'll be getting in there and taking a look at these plugs ASAP.
Garret
scottgs is offline
#24 Old 09-07-2015
Vehicle: SLK gone.
Quoted: 35 Post(s)
Hi Scott, the oil drips on to the catayser and smokes. I bought 2 small caps and 1 large cap or cover. Only used the large one. Easy job and the parts are cheap. Just take care when removing the old items as they may be brittle and crumbly. if you take off the undertray you'll find oil in there too. If the cover or covers are leaking, well that's where that oil probably came from too. It's Monday, all the parts dept's will be open so get on it!
#25 Old 11-15-2015
SLK.AMG's Avatar
Vehicle: ‘11 Mercedes Benz SLK 200 & '04 Mercedes Benz SLK350
Quoted: 9 Post(s)
So i opened up my hood and noticed a white smoke coming from the passenger side. I looked closely and found out that some oil drips in the exhaust. Ive attached some photos of where i think the leaks is coming from but i could be wrong.
Could it be the valve cover? Or the small and large caps?
SLK.AMG is offline
#26 Old 11-16-2015
Star/DAS Registered Owner
Quoted: 499 Post(s)
Most likely the caps. Easy to replace.
mchild is offline
#27 Old 11-17-2015
SLK.AMG's Avatar
Quoted: 9 Post(s)
Went to a mechanic and told me its the expansion plugs. quoted me at $150nzd including labor and parts. Parts would be only $50nzd. Was thinking to just DIY it.
SLK.AMG is offline
The Following User Says Thank You to SLK.AMG For This Useful Post:
#28 Old 01-25-2016
monzomike's Avatar
Vehicle: 2007 Silver SLK 350
It's such an easy job, it's a crime to pay someone to do it. Just make sure you wipe the hole clean prior to installing new plugs. You can feel the bore for any residue prior to installing by sticking your index finger in it.
monzomike is offline
#29 Old 01-25-2016
Crank081's Avatar
Vehicle: 2006 SLK350 Pewter Metallic
Other Toys: 2015 Audi A6 S Line, 2018 Honda Accord EX-L Hybrid, 1998 SLK 230 (sold)
Quoted: 41 Post(s)
Hey I know you posted in November, but if you still have oil leaking, check your oil separator centerfigue. It's the round piece right above the area you circled. Mine was leaking slightly so I replaced. Very easy, I posted a DIY on it.
Crank081 is offline
#30 Old 10-31-2016
Quoted: 499 Post(s)
I just found where these three caps are available bundled together under Dorman part number 917127. Dorman products are widely available so I checked RockAuto and found all three for $7.63 plus shipping. I have not used the Dorman plugs.
mchild is offline
#31 Old 12-09-2016
Vehicle: 2005 SLK350 Firemist Red
Just replaced the camshaft expansion plugs. $10 worth of parts, 10 minutes of work and some cleanup of seepage below... No smells, smoke or mess now!
PatricioATX is offline
#32 Old 01-05-2017
Other Toys: H20 V-Dubs, MK1s
Quoted: 410 Post(s)
Been smelling oil and feared the worst. Investigated, identified plugs as culprits. Searched this forum and BICKETY-BAM my fears were put to rest. Now to order those puppies.....
I'm left to wonder what purpose these "expansion" plugs serve. The name implies that they might expand under increased pressure, perhaps to avoid damage elsewhere. I remember my uncle telling me "you can't have too much oil pressure" but that didn't make sense then and it doesn't make sense now. Any comments?
Btw thanks to all who take the time to write about and elaborate on these issues. It has really helped relieve some of the anxiety out of owning this beast of a car. I'd like to buy you all a Coke to show my appreciation.
Roxanne7169 is offline
#33 Old 02-18-2017
MiamiC70's Avatar
Quoted: 47 Post(s)
Did mine today very easy and took just a few minutes.
MiamiC70 is offline
#34 Old 05-08-2017
HwoALanG's Avatar
Vehicle: 2007 SLK 280(Current) - Had SLK 350
Quoted: 12 Post(s)
just replaced mine over the weekend
kinda surprised how much oil leak out from there... >_<;;
just to clear things up regarding 1 x Large cap and 2 x small caps
i spoke with dealer and sort this out.
Large cap are for R171 without vacuum pump. (applies to SLK 350 & 55 AMG)??
i believe SLK 280 just needs 2 x small caps. (mine only need 2 x small caps)
SLK 350 will need large cap + 2 x small caps.
best bet is give them your VIN # and ask them if you need all 3 caps or just need 2 x small caps.
hope this helps!
nguyenphananh likes this.
HwoALanG is offline
#35 Old 05-08-2017
Quoted: 499 Post(s)
hope this helps!
I see in the parts manual that the 280 does not use the larger plug. Does that mean you have a vacuum pump on your car/engine? What is the vacuum pump for?
mchild is offline
#36 Old 05-08-2017
Quoted: 499 Post(s)
I thought I would update this thread as the MB part number for the smaller plug (need 2) has been superseded to 000 998 65 90.
mchild is offline
#37 Old 05-09-2017
HwoALanG's Avatar
Quoted: 12 Post(s)
i believe vacuum pump is used to either augment or provide the vacuum power necessary to operate the various other systems on the car, including the brakes, some HVAC functions and more
i am not a mechanic so i can't provide much more detail than that...
thank you for the part # @mchild
HwoALanG is offline
#38 Old 05-10-2017
Quoted: 499 Post(s)
Interesting, as the 350 is essentially the same engine except for a small displacement difference and the 350 does not have a vacuum pump mounted at the rear of the engine. Most systems on the R171 SLK are not run off vacuum. Components like the HVAC are all electric.
mchild is offline
#39 Old 03-01-2018
Vehicle: 2007 SLK 350
Quoted: 13 Post(s)
Thanks for this information everyone. I've had my SLK just long enough to put gas in it, but now that spring is close I can try to address some issues I've noticed. This may be one of them. Thanks again for the information!
shaker is offline
#40 Old 03-03-2018
Vehicle: SLK 350 6 spd manual r171 2005
Other Toys: Vw corrado seat ibiza ford ranger thunder
Quoted: 52 Post(s)
Does anyone have a definite part no for these plugs, or will it be vin decided, i have a 2005 350, and not sure which ones to get
Corradoman12 is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R171 SLK Class Cars > SLK R171 Service Campaigns (TSB)
Oil Leak, Possibly cam shaft expansion plug? Tx280 SLK R171 General Discussion 6 01-05-2019 01:33 PM
Oil leak and cam expansion plug korgua SLK R171 General Discussion 16 05-09-2018 10:35 PM
Blackstone Lab oil report - 2005 SLK350 fgwinn SLK R171 General Discussion 12 08-10-2009 06:11 PM
