Camshaft Adjustment Solenoid Wiring Harness - Mercedes Benz SLK Forum
SLK R171 Service Campaigns (TSB) This section is for any valid technical service bulletins (TSB) or service campaigns.
 3Likes
  • 1 Post By Gbarringer100
  • 1 Post By Akonion
  • 1 Post By riceball4u
#1 Old 02-28-2014
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
This a TSB for a wire patch in the event of oil leak on Cam Adjuster, USA.
File Type: pdf SCB Camshaft Adjustment Solenoid Wiring Harness 171.pdf (1.32 MB, 358 views)
Rooster likes this.
Gbarringer100 is offline
#2 Old 03-01-2014
Vehicle: 2008 SLK200 Kompressor Fire Opal 6 Spd Manual
Other Toys: Giant & Planet X Road Bikes
Quoted: 26 Post(s)
I did this modification on my 2005 C200, oil can leak from the cam solenoid into the wiring harness and by capilliary action travel to the ECU and the Lambda Sensor with very expensive consequences. When I sold the C200 i removed the modified harness's and fitted them on my SLK. It's very easy to do, just unplug the harness from the engine and fit the mod in between.
The part number on my invoice was MA271 150 27 33 described as D48G Starter Line, and the unit price was 18 + VAT in 2011.
Rooster is offline
#3 Old 03-01-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
I've got it done on mine as well , just in case !
curro101 is offline
#4 Old 03-02-2014
DAS/STAR Registered Owner
Akonion's Avatar
Vehicle: 2005 SLK 350MT
Chats: 3
Quoted: 106 Post(s)
Will investigate having this done - seems like a cost effective proactive measure.
curro101 likes this.
Akonion is offline
#5 Old 12-25-2014
Vehicle: 2005 Slk 350 White
Quoted: 36 Post(s)
will this affect the transmission too?
The car wouldn't shift drive or reverse. I'm pretty sure it is the conductor plate, but im not technical.
Thanks for any input
Der Flieger likes this.
riceball4u is offline
#6 Old 12-26-2014
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
RB, are you saying the car won't shift out of P into either R or D?
FUN 4 2
Der Flieger is offline
#7 Old 12-28-2014
Quoted: 36 Post(s)
Hi DF,
It can shift into d or r, but when push the gas, it just rev up but doesn't move as if it is in neutral, I'm guessing mostly the conductor plate
#8 Old 12-29-2014
Quoted: 123 Post(s)
...off to a good MB independent or transmission shop...
FUN 4 2
#9 Old 01-02-2015
Quoted: 36 Post(s)
Towed it to MB Fort Washington. They said it was valve body n will cost $2000+. Bummer
#10 Old 03-22-2016
Star/DAS Registered Owner
Quoted: 499 Post(s)
If anyone who has had the wiring harness adapters installed on their 272 engine could you post a pic of how the new wiring pieces are fitted. I would greatly appreciate it.
As a precautionary measure I purchased the four wiring pieces to install in case my solenoids leak oil. Problem is the 6 inch sections of new wiring are rather stiff and there is little to no slack in the original wiring at the original connects so not sure how to squeeze these wiring additions into place without bending them as it seems they are designed not to bend.
Any and all help is greatly appreciated.
mchild is offline
#11 Old 03-23-2016
Quoted: 99 Post(s)
They plug in between the original wire connection and the sensor. It is a solid wire and not twisted wire as oil will not wick a solid wire. Oil can wick a twisted wire. That is why is stiff. You can bend it so it will fit.
#12 Old 03-23-2016
Quoted: 499 Post(s)
Thanks for responding.
mchild is offline
#13 Old 03-25-2016
Quoted: 499 Post(s)
Following the advice provided I installed the corrective wire pieces. While I do not question the accuracy of Gbarringer100 comments, the center section of the pieces do not take a bend and hold it as a typical solid wire would do. They spring back to the original straight form so all the bending that is required to get these wire sections in place occurs at the extreme ends where the wiring goes into the connectors. This created sharp bends and some stress on the wires at the connectors so I re-routed as best as I could to reduce the sharpness of those bends at the connectors. I used wire zip ties to secure.
Hope others find this helpful.
mchild is offline
#14 Old 05-20-2017
Slk Rick's Avatar
Quoted: 16 Post(s)
Cam solenoid recall
Hello, all. I received a notification from my local dealership about a cam solenoid recall affecting my vehicle. I'm currently traveling but will have it taken care of when I'm back home.
I know there was a cam wiring harness campaign previously (I haven't had it done), and am wondering if this is the same.
Is there anything I should watch out for or have done additionally with respect to this repair?
Thanks in advance.
Slk Rick is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R171 SLK Class Cars > SLK R171 Service Campaigns (TSB)
Service Bulletin: Retrofit Wiring - Camshaft Adjustment Solenoids REB_TN_06 SLK R171 General Discussion 13 04-20-2017 11:32 AM
Exactly how does the M272 camshaft timing adjustment work? efair SLK R171 General Discussion 11 01-30-2014 07:44 PM
Need help with DNX6160 Kenwood wiring harness Ninja650R Where to get R171 SLK Items 3 06-13-2013 04:38 AM
Adjustable camshaft solenoid Raindog SLK R170 General Discussion 0 05-08-2012 05:08 PM
