Advice Wanted Please - 2009 SLK 300 - Mercedes Benz SLK Forum
 9Likes
  • 1 Post By Mike Swallow
  • 1 Post By Avel Du
  • 1 Post By jbanks15
  • 1 Post By efair
  • 2 Post By Sneaky Pete
  • 1 Post By Avel Du
#1 Old 3 Days Ago
Vehicle: 2009 SLK 300
Hi All,
New to the group, but seems to be the place to be for questions and answers for all things SLK.
I have recently bought a 2009 SLK300 in the UK, but a couple of things have me confused which I am hoping you can advise me on;
1) It has a headlight washer button to the left of the main headlight dial, but it does nothing - the vehicle doesnt have xenons, and the bumper does not have any sign of pop-up washers. Is this normal?
2) On standard beam, the headlights are very low - cannot see an internal adjustment knob, so do they need to be re-aligned by a garage or am I missing something?
Hoping you guys can help me out
Many thanks
Mike
Mike Swallow is offline
#2 Old 3 Days Ago
Quoted: 6601 Post(s)
Mike
check your free datacard
check your manual also
Headlamp cleaning system
With the engine running the headlamps will
automatically be cleaned with a high-pressure
water jet when you have
Rswitched on the headlamps
and
Rthe windshield wipers have wiped the windshield
with washer fluid five times
When you switch off the headlamps, the counter
resets.
i have headlamp washers and that button you are referring to is a 'dummy' button
headlights can be adjusted
see search results
https://www.google.com/search?source...4dUDCAc&uact=5
#3 Old 3 Days Ago
Quoted: 2320 Post(s)
I have the same button and it does indeed wash.
It may be a dummy if it was not fitted as an option (which your bumper comment suggests).
Request a datacard and you will see fitted options listed.
#4 Old 3 Days Ago
Myk, we have facelifted 2009 models....you don't
I have the washer option on my 55 datacard but button is a dummy
see procedure above
#5 Old 3 Days Ago
Quoted: 934 Post(s)
On the pre-FL R171's at least, there are holes through the upper radiator support for adjusting the headlights. Use a socket and extension.
efair is offline
#6 Old 3 Days Ago
Checked the datacard and appears have the washer button but no washers.
#7 Old 3 Days Ago
you don't need em
they over spray onto your hood
I never use mine for 11 years
#8 Old 2 Days Ago
Quoted: 550 Post(s)
Hi All,
Many thanks
Mike
1) No, this is not normal. If you do not have xenons there should be a selector wheel that controls an adujstment motor in the headlight assembly. So that you can control the headlight range depending on the load of the vehicle.
My guess is that the vehicle had a faulty rotary switch (switch and adjustment wheel are 1 assembly) and the PO swapped it for a used switch from a car with xenons. Hence the washer button. Could be the adjustment motor is in the position for heavy load, so they are pointing very low.
You need a headlight rotary switch like this:
Sneaky Pete is offline
#9 Old 2 Days Ago
One thing that I can confirm.
The headlight wash does overspray.
Annoying when you just prep'd the car for a show.
Pete's made a good suggestion.
Another possible is that the bumper has been replaced with one without the wash kit.
Have a look behind the bumper, if you can, and see if the wash lines are hanging there.
You might not be able to see, though.
#10 Old 2 Days Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 1002 Post(s)
If the washer hoses are leaking, or hanging you will have a warning on display as they are feed from the windshield tank.
Pop and bang mode
i860 is online now
#11 Old 23 Hours Ago
Vehicle: 2008 R171 280 in Thulite Red
Other Toys: Holiday home in France
Quoted: 107 Post(s)
The red one, a facelift, does not have xenons but does not have a light switch as per the photo. It just has the rotary light control with a push button beneath.
Redleader is online now
#12 Old 16 Hours Ago
Quoted: 550 Post(s)
You are correct. My bad. Facelift version does not has the thumbwheel but a button with position 1 and 0 that probably switches between lights up and down depending on whether the car has extra load.
The image on the button shows 2 arrows up and down so not a washer button I guess.
Thanks for correcting me. It should look like this
mileoman
