"Retractable roof operation only at standstill" error message - Mercedes Benz SLK Forum
 10Likes
#1 Old 09-06-2019
SLK350newbee's Avatar
Vehicle: 2008 SLK 350
Quoted: 9 Post(s)
I am receiving a "Retractable roof operation only at standstill" error message in the message window while my 2008 SLK350 is sitting in the garage! At the same time my ABS light lite up on the dash. I have replaced the front left (driver's side) wheel speed sensor to no avail. Any ideas?
SLK350newbee is offline
#2 Old 09-06-2019
Quoted: 6609 Post(s)
have you driven the car since replacing sensor?
#3 Old 09-06-2019
Quoted: 9 Post(s)
Yes . . . over an hour yesterday. Would unhooking the battery help?
#4 Old 09-06-2019
couldn't hurt until the experts check in
disconnect neg cable for a minimum of 30 mins
reconnect cable
reset clock
synch windows
see hat happens
#5 Old 09-06-2019
is that error message in your owner's manual?
#6 Old 09-06-2019
Quoted: 9 Post(s)
Yes. See attached.
File Type: jpg Retractable roof operation only at standstill.jpg (7.7 KB, 40 views)
#7 Old 09-06-2019
try the battery reset also, is the trunk cover securely in place?
#8 Old 09-06-2019
Quoted: 9 Post(s)
Yes, the trunk luggage cover is signaling closed from the iCarSoft MB II scanner. What I did notice from the scanner is that the 'Hydraulic "CLOSE" won't register ACTUATED when the button to open/close the top is pushed forward to close the roof. Even in the top down position the 'Hydraulic "OPEN" registers ACTUATED when it is pushed down to open the roof even though the roof is in the open position. Does that make sense?
#9 Old 09-06-2019
lets alert the experts and the switch king!
@Sneaky Pete
@mchild
@efair
@i860
@VII7
#10 Old 09-06-2019
Quoted: 9 Post(s)
Thanks! Appreciate the help!
#11 Old 09-06-2019
Quoted: 514 Post(s)
There is the problem to all. The system can not tell if the car is moving or not so it will not let the roof open. You may have other wheel speed sensors not working. Do you have access to the Star SDS system. It will drill down much deeper than the iCarSoft system can. Once the wheel sensor is replaced the fult may need to be cleared and sometime that will require the Star SDS system to clear it.
jbanks15 and Hui Sweetcheong like this.
mchild is offline
#12 Old 09-06-2019
Quoted: 9 Post(s)
I don't have access to a Star SDS system, only the iCarSoft MBII. Having said that, is the Mercedes dealer my only other option?
#13 Old 09-06-2019
that or an indy (independent) mechanic that has that tool
#14 Old 09-06-2019
Quoted: 514 Post(s)
Independents with a focus on MB should have it also. Call and ask what they use. Does your scanner show any faults for the wheel sensor(s)?
mchild is offline
#15 Old 09-06-2019
Quoted: 9 Post(s)
I found a description online for C1100 Left Front Axle Vehicle Speed Sensor Circuit Fault but couldn't clear it with the iCarSoft MB II because it said it wasn't found in the data base.
#16 Old 09-06-2019
Quoted: 514 Post(s)
I think you are going to need a shop that has Star to dig into it.
mchild is offline
#17 Old 09-06-2019
Quoted: 940 Post(s)
Can your scanner examine the actual values from the traction control module? If so, have each wheel up and spin it by hand and see what values are shown for wheel speed.
Sandy&Ben and SLK350newbee like this.
efair is online now
#18 Old 09-07-2019
Quoted: 9 Post(s)
I believe the scanner shows me 0 mph per wheel on the read out but I'll go back in and check. I'll try the 'spinning wheel' tip to see if values change.
I disconnected the negative terminal from the battery for 45 minutes with no change in errors. Battery is showing 12.45 V cold and 14.19 V when running. I turned on the headlights and fan on high and it only dipped to 14.12 so I believe the battery is doing its job.
#19 Old 09-07-2019
Quoted: 940 Post(s)
IIRC, the actual values in the *roof module* will also show you what the roof module has learned about the speed via CAN. That might be helpful. In fact, it would be a good idea to post all the actual values from your roof module here. This is the first time on this site I've seen this message, It's possible that something was lost in translation in MB-land.
efair is online now
#20 Old 09-08-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 1019 Post(s)
You really need a das scan.
Pop and bang mode
i860 is offline
