Flat battery : Just knackered or possible other cause? - Page 2 - Mercedes Benz SLK Forum
 10Likes
#21 Old 1 Week Ago
Vehicle: 2006 SLK55 AMG
Quoted: 18 Post(s)
And the cables that attach as far as you can see.
Bad earthing may be the issue.
All earths I can see look good, no corrosion and tight.
I did some testing over the weekend but not really conclusive. Tried measuring the voltage over the fuses but wasn't getting consistent results and none seemed to add up to the 150mA I'd seen as a drain so wired up the ammeter again and found that the drain was only 30mA but this changes over time, up and down.
I clamped down the door switches and triped the door and boot latches then locked the car and left it for a while for all to go to sleep, after this it could show anywhere between 30 & 150mA.
One strange (to me) thing was that if I pulled the boot handle (car still locked) the drain would go to about 1.5A then step progressively down over the next minute or so to the previous level.
For that kind of draw I'd expect something to be shining, making a noise or getting hot but nothing evident was causing the draw. Possibly alarm circuit but did not go off. Nothing simlar happens if I pull the door handles.
GDCobra is offline
#22 Old 1 Week Ago
Quoted: 2326 Post(s)
Seems to indicate an alarm circuit/motion sensor, not that I know anything.
@efair
@etyu
@Sneaky Pete
@i860
@VII7
Gentlemen, anybody have an idea which circuits might show this behaviour?
One last thought.
The wiring loom passes down the hinge of boot hinges.
Sometimes cables get frayed and throw up electrical issues.
Couple of threads that may interest
https://www.slkworld.com/slk-r171-ge...ing-issue.html
Several threads on various fixes folk made for this issue.
Probably, splicing is the 'easiest'.
https://www.slkworld.com/slk-r171-cl...g-harness.html
https://www.slkworld.com/slk-r171-ge...nk-wiring.html
#23 Old 1 Week Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 1004 Post(s)
Had a similar problem on an cl600. In the end it was the alternator. Disconnect the + from alternator and see. It might be or not your problem.
Pop and bang mode
i860 is offline
#24 Old 1 Week Ago
Quoted: 18 Post(s)
Cheers I860, got to be worth a try when I can get back on it.
GDCobra is offline
#25 Old 1 Week Ago
6007.us
Padgett's Avatar
Quoted: 576 Post(s)
30 ma is about right with everything shut down, 150 ma will drain a good battery in a few days.
Padgett is online now
