Fog lights and Recirc mode always on? - Mercedes Benz SLK Forum
 13Likes
  • 1 Post By i860
  • 1 Post By VII7
  • 2 Post By VII7
  • 1 Post By mchild
  • 2 Post By mchild
  • 1 Post By 55russamg
  • 3 Post By Terminal
  • 2 Post By GaryLaird
#1 Old 1 Week Ago
Other Toys: My other car is an L-1011
Does anyone know if there is a way of programming the car to do the following:
1. Recirculate mode stays on all the time when selected (or automatically selected in high heat)
2. Fog lights come on with headlights in "Auto" mode
The first one baffles me that they didn't design it that way to begin with. Have they never lived in high heat like here in Houston? I'm constantly having to select that every time I get in the car to cool it down quicker - it literally takes half the time as cooling all that hot outside air... My 2003 Saab does this all by itself. My 2008 ML55 does not and it has basically the same kind of climate controls as the SLK
The fog lights I don't get either. I can only turn them on in the manual on mode, which defeats the purpose of having auto mode. In the ML, I was able to change something in the menus that let me leave the headlight switch in the on position all the time with the fog lights on, but when I turn the car off, they go off so its no big deal - they're basically on when the car is on. Can't find a way to do that on the SLK
I have use of a friend's xentry laptop for another week, so if three is a way to do either of these it would make me love my car even more...
aaronalfa is offline
#2 Old 1 Week Ago
Quoted: 2213 Post(s)
Recirc is on permanently on mine once selected.
The fogs could be set as DRLs I think. That would bring them on in auto mode.
@i860
@VII7
will be able to set the records straight.
Avel Du is online now
#3 Old 1 Week Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 897 Post(s)
If it can be done it will be in vediamo.
i860 is offline
#4 Old 1 Week Ago
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 192 Post(s)
Fog lights are not meant to be on all the time, I'm not aware of coding options to change this.
Recirculation behavior can be changed via coding.
VII7 is offline
#5 Old 1 Week Ago
I can't be certain, but I 'think' I have seen threads where fog lights can be recoded to act as DRLs.
There might be a requirement for a different bulb wattage though and it may also need coding to
dim the resultant drl when main lights are on.
#6 Old 1 Week Ago
Other Toys: CLS63
Quoted: 192 Post(s)
Yes, you can drl but not with fog lights.
Gbarringer100 and Avel Du like this.
VII7 is offline
#7 Old 1 Week Ago
OP your option is one or the other, but not both.
https://www.slkworld.com/gtsearch.ph...t%20conversion
#8 Old 1 Week Ago
Star/DAS Registered Owner
Quoted: 500 Post(s)
Yes, by using MB Star/DAS there are a number of settings of the A/C controller that includes several re-circ settings.
mchild is offline
#9 Old 1 Week Ago
Quoted: 500 Post(s)
Fog lights can be used as DRL if the car has the SmartTop controller added and selected using that controller.
55russamg and Avel Du like this.
mchild is offline
#10 Old 1 Week Ago
6007.us
Padgett's Avatar
Quoted: 564 Post(s)
Guess I am confused: Florida also tends to get a bit warm and I generally leve my windows open a bit when must park in the sun. That said, the outside air is generally tens of degrees cooler than the inside for the first few minutes. Personally use recirc mostly in a cool car in heavy traffic to keep outside odors down.
Padgett is offline
#11 Old 1 Week Ago
Also, SmartTop.
You can drop all the windows on 2 presses of open.
Close/lock car with one press.
Rear windows stay open.
Think that's right.
I discovered it by accident.
#12 Old 1 Week Ago
55russamg's Avatar
Quoted: 665 Post(s)
Cool
Also, SmartTop.
Think that's right.
Smart Top can set fogs as DRL's and the windows can be set up to different things with various clicks, roof down and windows up, roof down and windows down, windows up ( double click lock) and windows down double click unlock)
I believe also Smart Top can now activate reversing lamps for a brighter coming home feature?
One question, how Foggy does it get in Seattle
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is offline
#13 Old 1 Week Ago
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 533 Post(s)
This.
Foglights as DRLs during the day, ok. Foglights on at night when there's no fog - PITA for dazzling. There have been incidents of road-rage due to the latter....
55russamg, Avel Du and MrElbe like this.
Terminal is online now
#14 Old 1 Week Ago
Originally Posted by Terminal View Post
This.
Ditto for high intensity lights improperly set.
#15 Old 1 Week Ago
GaryLaird's Avatar
Vehicle: 2010 SLK350 r171
Quoted: 111 Post(s)
Against the law to run fog lights when conditions don't demand it...at least in the UK:
"You must not use front or rear fog lights unless visibility is seriously reduced (see Rule 226 of the Highway Code) as they dazzle other road users and can obscure your brake lights. You MUST switch them off when visibility improves."
https://www.askthe.police.uk/content/Q400.htm
55russamg and Terminal like this.
GaryLaird is offline
#16 Old 1 Week Ago
Vehicle: 2018 SLC 43
Other Toys: 2013 Lincoln MKT
Quoted: 140 Post(s)
In Dallas, the horn is on by default. Or so it seems with many cars. Also Houston. Horns are disconnected in Austin.
SLKomatic is offline
