Oil problem - Mercedes Benz SLK Forum
 14Likes
  • 2 Post By DAVIETHESCAFF
  • 2 Post By Avel Du
  • 1 Post By osi
  • 2 Post By i860
  • 1 Post By frogfoot
  • 1 Post By DAVIETHESCAFF
  • 1 Post By jbanks15
#1 Old 6 Days Ago
AND MABEL
DAVIETHESCAFF's Avatar
Vehicle: 2008 AMG 55
Quoted: 580 Post(s)
Unhappy Oil problem
200 miles after having a service at the stealership, Mabel tells me to add a litre of oil at the next fuel up. I do. I set off for my Euro trip. 200 miles later, car asks for another litre of oil. I add it. 200 miles later asks for another litre of oil. I don't add it. 100 miles later I fuel up and it asks for a litre and a half. I can see a pattern appearing … half a litre every 100 miles! I add the oil. I'm now at the point of cancelling the trip and returning home. Having checked under the bonnet and car to find no signs of any leaks, and, as there isn't any smoke from the exhaust, I'm at a loss to explain the problem. I make the decision to go for it, and head off to France and beyond. After a couple of days of gentle-ish motoring she hasn't needed anymore oil so I let her horses loose on the passes. Returning to the UK, after a further 2200 miles she asks me for another litre of oil. I don't add it, and have done another 300 miles without a request for oil.
She doesn't normally take anymore than a litre over 10,0000 miles, so three and half litres in 750 miles is crazy. Could it be that she wasn't filled correctly at the oil change? @Col had his code reader plugged in and she wasn't showing anything untoward codewise.
Anyone any ideas as to what's going on?
Col and Avel Du like this.
.........Happiness is not getting what you want, it's wanting what you have.........Daviethescaff
DAVIETHESCAFF is online now
#2 Old 6 Days Ago
Moderator/RoTMorganiser
Quoted: 2132 Post(s)
Only three options IMO.
Dealer forgot to top up.
A leak (which you have eliminated).
Bust sensor.
Good to have you back mate.
DAVIETHESCAFF and M4rCu5 like this.
#3 Old 6 Days Ago
osi
osi's Avatar
Vehicle: 2005 SLK55 AMG R171
Quoted: 130 Post(s)
I did a recent post 'electronic dipstick hysterises'. It may help. As someone said, 55's don't burn oil and mine is no exception . If you we're burning that much oil I'm sure it would be noticeable.. fouled plugs/smoking exhaust etc.
Maya ~ Tapatalk
osi is offline
#4 Old 6 Days Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 855 Post(s)
Need to buy one of those and check manually
https://www.ebay.co.uk/itm/High-Qual...QAAOSw-3FZDUEp
Depending on your engine code ( post your vin nr and I can check ) you have the values in here.
Avel Du and jet_fl like this.
i860 is online now
#5 Old 6 Days Ago
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 324 Post(s)
Talking
Take the bills for the oil to the dealers and ask wtf did I pay for !! If they had it at the correct level and then you put 4.5ltrs in I guess you would of damaged the motor as the oil would of been way over , the fact you didn't and did the trip more than points to a under fill at the dealers.
As you guys with amg motors are stripped from even the basics of a oil dip stick in place of a who built my engine badge , you could jack the car up and drain and measure what oil is in it Davie.
Then put the correct amount back in as per mercedes recommendation , run it for a month and recheck for piece of mind ?
DAVIETHESCAFF likes this.
frogfoot is offline
#6 Old 6 Days Ago
AND MABEL
Quoted: 580 Post(s)
Ordered a dipstick as per your link. Found the right values in the chart, so I'll be able to check the level myself in the future. Thanks.
frogfoot likes this.
#7 Old 6 Days Ago
AND MABEL
Quoted: 580 Post(s)
Just back from my indie garage. They support the idea that Mercedes probably only added 5 litres when they did the service. Will be having words with them next time I'm in there.
#8 Old 6 Days Ago
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 313 Post(s)
And maybe also check to see how many spark plugs they charged you for last time they were changed
EDIT
How many litres did they charge you for Davie? It should be on the printed invoice.
Windinmyhair is online now
#9 Old 6 Days Ago
Quoted: 6339 Post(s)
5! it needs 9 if i remember correctly amg wise
Wavetrac LSD thread here:
#10 Old 6 Days Ago
AND MABEL
Quoted: 580 Post(s)
The indie reckoned 8.6 litres, which would explain the 3.5 that I had to add.
jbanks15 and frogfoot like this.
#11 Old 6 Days Ago
AND MABEL
Quoted: 580 Post(s)
EDIT
I have a service plan and didn't get an invoice, I only received a check sheet saying the oil had been changed in accordance with Mercedes service schedule blah blah blah. I will enquire as to how much was charged for when I'm in there next.
Windinmyhair likes this.
