Carly Diagnostic SRS codes - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By Razvan Orlando Matei
  • 1 Post By i860
#1 Old 04-26-2019
Vehicle: SLK 200 R171 silver 2005
Other Toys: Kawasaki Versys 650
Quoted: 20 Post(s)
Does Carly clear SRS fault codes as I am thinking of buying one
Marauder
marauder1964 is offline
#2 Old 04-26-2019
Quoted: 225 Post(s)
I am pretty positive it does, but it may come back again. It cannot code them out so they will not reappear.
jet_fl is offline
#3 Old 07-14-2019
Vehicle: SLK 200 (2004)
Well it says it clears the SRS codes but in my case it simply doesn't. I replaced my steering wheel yestarday and since then I have the SRS warning both as a light and it says to take it to the shop (1 malfunction). I made sure I reconnected all the connectors properly on the airbag module but nothing helps. Carly for MB sees error in all items in SRS section but when I choose clear nothing happens. I am positive that the wires are ok and the connectors as well - triple checked. My only alternative is to take it to someone with a software better than Carly to fix this.
LIL DON SLK likes this.
Razvan Orlando Matei is offline
#4 Old 07-14-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 1004 Post(s)
Something is not right, I change my steering wheel 4 times so far and no SRS error.
Pop and bang mode
i860 is offline
#5 Old 07-14-2019
Did you disconnect the battery before replacing the steering wheel? I didn't Anyway, I have checked and rechecked and all 3 connectors are properly seated. Also checked and rechecked the wires for any damage - nothing. All the buttons on the wheel do work. The thing is that the SRS light doesn't even flicker when Carly is "clearing aribag faults".
#6 Old 07-14-2019
i860's Avatar
No, I never disconnect the battery.
Did you took the car for a drive?
Seat in passager seat, with the seat belt for a few seconds door closed.
If the error is active then you need to fix it before been able to reset.
Pop and bang mode
i860 is offline
#7 Old 07-14-2019
Quoted: 937 Post(s)
The connectors have shorting bars that must be fully snapped shut else they will show a short - which will generate a code.
efair is offline
#8 Old 07-15-2019
Yes, I drove it for about 40 km and I also had someone sitting in the passenger seat with the seatbelt on. I checked the connectors again and they are sealed shut. Based on the info I got so far I am hoping that an original Mercedes scanner will be able to clear the codes. All I have is Carly for MB which reportedly doesn't clear Airbag errors. I will try the original scanner later today.
Thanks.
#9 Old 07-15-2019
i860's Avatar
You might damage the steering angle sensor.
Pop and bang mode
i860 is offline
#10 Old 07-16-2019
Using the original Mercedes scanner did it! SRS light and dash warning went away. So Carly really can't clear airbag faults. The guy told me that he got a lot of people with this specific issue (replacing steering wheel and SRS coming on). Eitherway to avoid this I really recommend disconnecting the battery. It is not a certain thing that SRS light and dash warning will appear when changing the steering wheel but why go through the trouble when you can disconnect the battery. For example, a friend of mine changed his steering wheel just one day prior without disconnecting the battery and he had no warning lights.
#11 Old 07-17-2019
osi
osi's Avatar
Vehicle: 2005 SLK55 AMG R171
Quoted: 144 Post(s)
Anyway... I tried Carly, went pro and even bought their adapter. It can connect with some ECUs on my car 2005 55 but certainly not the engine ECU. They say that it works for most 2005 cars onwards and before they refunded me, Carly promised they were working on it. That was 3 years ago and I heard nothing since. Torque pro at least reads some engine ECUs and gives live info. It gets busy checking fault codes but always comes back with no faults found. Torque Pro pic attached
Maya via Tapatalk
osi is online now
Intermittent SRS light - how to read codes? lombrozo SLK R170 General Discussion 4 12-03-2017 03:40 PM
iCarsoft i980 / MBii vs Carly Mercedes & Bluetooth Sparky72 SLK R171 General Discussion 19 04-29-2017 02:34 PM
5 diagnostic codes different from posted muskey67 SLK R170 General Discussion 19 02-26-2017 08:21 PM
Diagnostic Codes my2000slk SLK R170 General Discussion 3 06-30-2015 11:41 PM
