Roof problem - visit workshop - Mercedes Benz SLK Forum
 3Likes
#1 Old 03-31-2019
Vehicle: R171 2004 200 KOMPRESSOR andradite green
Quoted: 72 Post(s)
Question Roof problem - visit workshop
The roof was working perfectly fine with SmartTop module since I bought the Green Beauty. ~2 weeks ago I couldn't open the roof for the first time, but after 2-3 attempts I got it opened. Yesterday I could not close the roof - it took mi 10 minutes and many, many tries to do it. Right now I can't open it - event the boot lid doesn't go up. After a few tries I managed to get the roof lid up half-open. I checked for leaks 2 cylinders in the top of the boot and the 2 in the rear - bottom of the boot - all dry. I found that hinge of the boot separator was misplaced, but putting it back didn't fix the problem. Once in a while the roof was not moving smoothly - it was like a 0.5 seconds of break and then kept going. I don't think it's oil problem as the 5th cylinder is over my head, so I'd spot a leak
What's the troubleshooting procedure? Should I start with the switches? Help!!!
I have a multi-meter & a crappy OBDII tester.
I found this: https://www.billsden.org/fileadmin/m...vario_roof.pdf
P.S. I use lithium grease and gummi pflege regularly.
racing_green is offline
#2 Old 03-31-2019
TonyS3's Avatar
Vehicle: 2013 SLK55 AMG
Quoted: 336 Post(s)
Mmmmm..... maybe a motor (pump) problem, I had that on my 2004, similar symptoms, luckily fixed under Warranty, don’t ask the price if it is, you don’t want to know......
TonyS
TonyS3 is offline
#3 Old 03-31-2019
Quoted: 6339 Post(s)
disable the smarttop and then see if the roof works as it should
if it does, the smarttop needs to be reprogrammed by you
if it does not, you have ruled out the st as the cause
Wavetrac LSD thread here:
#4 Old 03-31-2019
are you running the car while using the smarttop if not driving?
#5 Old 03-31-2019
Quoted: 72 Post(s)
I did that when I was trying to close the roof - still the same.
#6 Old 03-31-2019
when you tried to open or close the roof and it did not finish the operation, did you try to do the opposite or did you continue in the same direction?
like, if you started to open and then it stopped, did you continue trying the open operation or did u switch to closing it
#7 Old 03-31-2019
Quoted: 72 Post(s)
I think I tried both ways - do I need to "reset" is in a similar way it's with the windows?
#8 Old 03-31-2019
Quoted: 72 Post(s)
In case it's important: it doesn't even get to the stage when the actual roof moves. It stops after very short time when windows/boot lid moves.
#9 Old 03-31-2019
how old is battery?
you can try a battery reset for giggles
disconnect neg cable for minimum of 30 minutes
reconnect
synch windows set clock
see what happens
#10 Old 03-31-2019
Quoted: 72 Post(s)
Max 3 years. I had OEM battery in 2019: https://www.slkworld.com/2720370-post8.html
Battery disconnected.... waiting.....waiting....
#11 Old 03-31-2019
i think u answered this somewhat
#12 Old 03-31-2019
you check the fuses that handle the roof?
#13 Old 03-31-2019
Quoted: 72 Post(s)
SmartTop is disabled since yesterday, but that didn't help.
Edit: Link removed as it was not relevant - it's about noise/leaks.
#14 Old 03-31-2019
@Sneaky Pete
@Seanhump
@mchild
@efair
@i860
@VII7
#15 Old 03-31-2019
Quoted: 72 Post(s)
No.. I though if it's moving the fuses should be OK. I'll do it when I reconnect the battery.
I'm trying to figure out where are the micro switches - I think it might be one of them.
Edit: some info about switches: https://www.slkworld.com/4250586-post19.html
#16 Old 03-31-2019
Quoted: 849 Post(s)
What are you seeing in the instrument cluster, and are you hearing the pump run?
The headliner can hold a cup of fluid before spilling it into your lap.
efair is offline
#17 Old 03-31-2019
https://www.slkworld.com/slk-r171-cl...criptions.html
switches, etc here:
#18 Old 03-31-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 855 Post(s)
Need a decent scanner...
i860 is offline
#19 Old 03-31-2019
Quoted: 72 Post(s)
Battery reset didn't help. Fuses on the left side of th dashboard are OK (one 40A is 25A, but all are good). The roof opened to this position after battery reset and windows reset:
#20 Old 03-31-2019
Quoted: 72 Post(s)
Another excuse to get DAS/Xentry..
R171 Roof Problem Philly Bob SLK R171 General Discussion 41 4 Weeks Ago 01:19 PM
vario roof switch or sensor problem Danslk280 New Members Introduce Yourself Here 24 05-30-2017 04:34 PM
Odd roof problem Dave Whitehouse SLK R170 General Discussion 28 08-24-2016 07:39 AM
Another roof problem GusSLK SLK R170 General Discussion 9 05-21-2015 04:19 PM
