Navigation Laser Replacement (not straight ribbon) - Mercedes Benz SLK Forum
  • 1 Post By G0RSQ
  • 1 Post By HawkX66
#1 Old 03-22-2019
HawkX66's Avatar
Vehicle: 2007 SLK 350
Other Toys: Yes...
Quoted: 48 Post(s)
I decided to tackle my navigation laser today. I read up on it and watched the great video that was posted. Of course, mine is different. Hopefully that means that mine is the cheap replacement though. I'm trying to identify the correct one to buy it off eBay. Any help would be appreciated.
The number is HPD 65A and here are a couple of pics along with one that seems to fit the bill. I know they can look the same, but be different. I don't want to end up with one that only works on the dash DVD player and not the nav unit.
https://www.ebay.com/itm/HPD-65A-Las...53.m1438.l2649
HawkX66 is offline
#2 Old 03-22-2019
Moderator/RoTMorganiser
Quoted: 2074 Post(s)
@G0RSQ
I think you're up to speed on lasers, Peter?
#3 Old 03-23-2019
G0RSQ's Avatar
Quoted: 141 Post(s)
I had exactly same experience as you!
Ready for the expensive laser, and found a HPD 65A inside, which is much cheaper. In fact the whole DVD deck is the same as in the NTG1 Head unit, just the pcb on it is different.
From my experience the HTG 65A is only available in one variant, so any claiming to be this are OK
I have bought on eBay these items without issues.
273581626467
310994127718
The Hong Kong one took ages to arrive, so happy to pay a little more for local supply and quick delivery.
When fitting, do not forget to remove the solder blobs on the ribbon (I forgot on both occasions I replaced mine!)
Peter
G0RSQ is online now
The Following User Says Thank You to G0RSQ For This Useful Post:
#4 Old 03-25-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 48 Post(s)
273581626467
310994127718
Peter
Perfect. Thank you. I ordered one and it's on the slow boat from China... I couldn't find a more local one and for $10 I figured I couldn't complain about the shipping time. I'll post once I get it back together. Thanks again.
HawkX66 is offline
#5 Old 03-26-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 48 Post(s)
I hate that... I left my Nav deck out while waiting for the new laser to arrive. I forgot you need to have all the fiber optics connected. What a poorly designed system that doesn't allow the HU to work if you don't have the DVD player plugged in. It made for a nice 2+ hr drive back to DC... The next few weeks will be pretty quiet in my car. Thankfully my smartphone and Pandora will help a little
HawkX66 is offline
#6 Old 03-26-2019
Quoted: 514 Post(s)
Just put in a loop plug where the navi drive was. Ring closed,problem solved.
Sneaky Pete is offline
#7 Old 03-26-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 48 Post(s)
Not something I have handy.
HawkX66 is offline
#8 Old 03-26-2019
Star/DAS Registered Owner
Quoted: 484 Post(s)
I have used a short section of clear vinyl tubing with one of each fiber cables in each of ends. If need be use something to act as a splint so the two fiber cable ends are looking directly at each other and the light effectively passes between the two ends. If I remember correctly, the vinyl tube was an 1/8" inside diameter - maybe 3/16".
mchild is offline
#9 Old 03-26-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 48 Post(s)
Do they just pull out of the connector? I have plenty of vacuum lines or heat shrink tubing I can use if that's the case. I was picturing a part that needed to plug into the harness.
HawkX66 is offline
#10 Old 03-26-2019
Quoted: 484 Post(s)
The connector that the two fiber cables are held in will open/separate so the two cables can be removed. Keep the holder for future use. but with the cables out of it you can slide them into a suitable tube so that the two ends are facing each other. A small piece of elelctrical tape on each will keep the cables from slipping out of the tubing/holder.
mchild is offline
#11 Old 03-26-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 48 Post(s)
Perfect. Thanks.
HawkX66 is offline
#12 Old 03-26-2019
Quoted: 514 Post(s)
As mchild says, the quick-and-dirty way:
https://uploads.tapatalk-cdn.com/201...728e2e29c9.jpg
and the "OEM" way:
https://www.amazon.com/Easyget-Optic.../dp/B01DZBMFBM
Personally I would spend 10 bucks for an adapter but both will do the trick.
#13 Old 03-26-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 48 Post(s)
and the "OEM" way:
Thanks. If I were leaving it I'd spend the $10 too, but I only need it to work until my new laser comes in. It would be there before I get home, so I might still do it anyway... Thanks for the heads up.
edit: Bah.... I ordered it. It'll probably be weeks before the laser gets to me.
HawkX66 is offline
#14 Old 04-15-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 48 Post(s)
After getting the laser off the slow boat from China, I'm glad to report all is right with the world again. So far so good. I installed the new laser and put everything back together. No hiccups with the navigation so far... The only thing I didn't like doing was using my soldering gun on the ribbon cable to get the solder blobs off. I went to school for electronics for a few years so I know my way around soldering. That was pretty sketchy. I was pretty concerned with melting the plastic, but it worked out though.
G0RSQ likes this.
HawkX66 is offline
#15 Old 04-16-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 48 Post(s)
And.... I spoke too soon. I left the house last night to head back to D.C. After about 20 min I got the check navi disk message again. I swapped out the navi dvd for the factory one and it still had problems, but different. The whole Navi system started getting glitchy. I couldn't plug in my address 3 hours away. Navigation would freeze and reboot the whole head unit or just sit there frozen on one spot on the map. So much for my $10 fix.
I might try to get them to send me a new laser. It might be just a bad one, but I doubt it. It does act very differently than before though so I suppose it's possible.
HawkX66 is offline
#16 Old 04-16-2019
G0RSQ's Avatar
Quoted: 141 Post(s)
What disk are you using?
If a copy, then it is possible it is "wearing" out (the dyes used in DVD-R can deteriorate over time in cheaper disks).
Do a copy to another DVD and see if that improves the reading (copying on a PC will correct the fading data).
G0RSQ is online now
#17 Old 04-17-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 48 Post(s)
I tried both. When I started seeing issues I put the factory one back in. The issues actually got worse.
HawkX66 is offline
Resolved DVD Navigation Error (laser see post 31) marvin-miller SLK R171 General Discussion 39 01-22-2019 01:02 PM
Installing a laser jammer (or laser parking sensor as they're also known as ...) Seanhump General Modifications R171 4 09-29-2013 01:03 PM
New SLK 171 Media Navigation OEM replacement Unit ckone General Modifications R171 14 05-18-2011 02:41 AM
Replacement LCD for navigation? Levi SLK R171 General Discussion 2 06-28-2010 01:25 PM
