Resolved - Additional FuseBox - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By Viviannetv
  • 1 Post By EOD Guy
#1 Old 03-21-2019
Viviannetv's Avatar
Vehicle: 2006 SLK280 (r171) aka Sheila
Other Toys: MercesesML430, Mercedes E320 avantgarde
Red face Resolved - Additional FuseBox
This my first posting in which I need advice on.
You see like I have mentioned in my introduction post. I'm pretty good at the mechanical side, but no so hot when its electrical.
So with that in mind I am wanting to fit a additional fusebox to accommodate front and rear recording camera's, ambient lighting, maybe a few other things too.
I'm thinking of fitting the extra fuse box near the original one. But I would like to know which would be the best wire to connect too. Has I am wanting the power for the extra fuse box to be live only when the ignition is turned on.
Viviannetv is online now
#2 Old 03-21-2019
Moderator/RoTMorganiser
Quoted: 2138 Post(s)
https://www.slkworld.com/general-dis...-fuse-slk.html
#3 Old 03-21-2019
Viviannetv's Avatar
Thanks for the link Myk.
But its a yes and no to my question.
Yes it would do, but a No has l'm no closer to which fuse to put it into.
#4 Old 03-21-2019
Have you looked through the 171 diy guides for cameras?
There's more than just the popular stickied threads at the top?
https://www.slkworld.com/slk-r171-class-diy/
Might need to do a couple of searches. (playing with wording).
Here's one to start you https://www.slkworld.com/gtsearch.php...0camera%20fuse
and some tips for searches https://www.slkworld.com/new-members...searching.html
#5 Old 03-22-2019
Viviannetv's Avatar
Red face Success
Hi Myk,
After taking your advice on searching around here, I did find what I was looking for. Even though it did take me most of the night reading thread after thread.
But I did come across one which member Curro 101 posted in "Aftermarket parking sensors" (#98), which has a photo and description of fuse amplification. Then member JonB posted in the same thread (#108), in which fuse numbers was stated and what is on each ignition fed fuse.I have decided to go with fuse number '43', which (according to JonB) is for the horn only.
Either later today or over the coming weekend I will be attempting to fit the additional fusebox. Of course, I will be taking photos of each stage.
So once again I thank you for pointing me in the right direction.
#6 Old 03-22-2019
Vehicle: 07 SLK 280
Quoted: 12 Post(s)
Looking at your fuse box, do you see any open slots? Not missing a fuse, but the fuse holder installed (the colored plastic fuse holder). If you have a missing holder, you can obtain one, they are not universal, and install it and run your power from there. I think I used the empty 42 (RHD: Steering column module) slot and created a BUSS bar (see attachment). If you have Right Hand Drive, you could use the LHD slot 33.
EOD Guy is offline
#7 Old 03-22-2019
Originally Posted by Viviannetv View Post
Hi Myk,
Photos would be appreciated.
You could add to the thread you found.
#8 Old 03-22-2019
Viviannetv's Avatar
Hi Myk, I wish I knew how to do what you asked. But I'm not sure how to do it, also not sure how to attach photo either. Pleaae, please, please would you talk me though in doing both.
#9 Old 03-22-2019
If you scroll down this thread for posting an intro you will find
instructions to add photos for Red (Full) and Blue (Classic) versions.
https://www.slkworld.com/forum-opera...-post-2-a.html
The only smartphone guide is https://www.slkworld.com/forum-opera...n-how-fix.html
Do not add more than 2 photos at a time. It may time out.
You can add more than 2 photos in total.
#10 Old 03-22-2019
Viviannetv's Avatar
Thank you Myk, that explains alot now. Hopefully I will be able to get the photos attached.
I had a small look today of where I was hoping to fit the additional fusebox. But the engine bay is so packed. That being said I now may have to put the additional fusebox within the battery top cover, or on the outside.
Only time will tell. Stay turned for further installments.
2001 SLK320 how to remove the fusebox? brian.frazer SLK R170 General Discussion 4 11-08-2017 10:59 AM
Ignition switched supply in cockpit fusebox? dbgrn General Modifications R171 4 04-27-2016 04:35 PM
FuseBox > A/C Compressor > Burned Wire simonso SLK R171 General Discussion 3 10-10-2013 12:31 PM
Front Fusebox Seanhump SLK R171 General Discussion 8 05-03-2012 10:46 AM
Additional SIRIUS XM channels jbanks15 SLK R171 General Discussion 0 11-26-2008 04:22 PM
