SLK350 Cooling starts up when car is started from cold!! - Mercedes Benz SLK Forum
 12Likes
  • 2 Post By i860
  • 1 Post By jbanks15
  • 2 Post By Icepilot
  • 2 Post By Sneaky Pete
  • 1 Post By Icepilot
#1 Old 02-18-2019
Icepilot's Avatar
Vehicle: SLK350 R171 2010
Other Toys: Jeep Grand Cherokee V8 4.7L, Skoda Octavia VRS Estate
Quoted: 9 Post(s)
Lightbulb SLK350 Cooling starts up when car is started from cold!!
Just wondered if anyone could help, when I start up our 2010 SLK350 from cold, the cooling fan starts up approx 10 seconds after car has been running, and sounds like like a 747 on take off!
Surely this isn't right?
I have owed the care since October 2018 and I am sure it didn't used to do this when we first acquired it.
Any ideas??
Icepilot is offline
#2 Old 02-18-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 859 Post(s)
Scan the car for errors.
-temperature sensor bad
-relay bad on an electric fan
-electric fan bad
i860 is offline
#3 Old 02-18-2019
Vehicle: 07 280 SLK 6 speed
Quoted: 21 Post(s)
Could it be the secondary air pump? That would be normal. Just a thought.
jfpslk is offline
#4 Old 02-18-2019
Icepilot's Avatar
Quoted: 9 Post(s)
"Could it be the secondary air pump? That would be normal. Just a thought"
Nah, its definately the main radiator cooling fan that is running, it sounds like you are stood next to a 747 at take off and blows like a hurricane under the bonnet.
Icepilot is offline
#5 Old 02-18-2019
Quoted: 6355 Post(s)
besides doing what i860 suggested, no harm in resetting the battery
disconnect neg cable for a minimum of 30 minutes
reconnect cable
reset clock, synch windows
does it still make noise?
how old is battery?
#6 Old 02-18-2019
Icepilot's Avatar
Quoted: 9 Post(s)
The battery was new last October, about two weeks after I had purchased the car. I checked the battery afetr it seemed weak, and it was the original battery that came with the car 10 years ago.
So new one fitted.
Icepilot is offline
#7 Old 02-18-2019
Quoted: 523 Post(s)
What i860 says.
Have it scanned for errors.
The fan has an integrated control unit that receives a PWM signal from the ECU. Duty cycle of the PWM specifies the speed at which the fan runs.
10% duty cycle is fan off,20% is minimum and 90% is max.
If anything goes wrong with this actuation process the fan automatically goes into emergency mode and runs at full speed.
Which is what happens in your case I guess. Could be a bad control unit.
Sneaky Pete is online now
#8 Old 02-18-2019
G0RSQ's Avatar
Quoted: 147 Post(s)
I do not know the answer to this, but would the "emergency mode" not also be triggered by a faulty sensor, such as cooling temp?
My limited experience is that this is what some other cars do. Disconnecting the water temp sensor is often the normal way to test the cooling fan is working!!!
Of course needs diagnostics scanner to identify, but maybe the dash cooling temp indicator might give a clue.
G0RSQ is offline
#9 Old 02-18-2019
Quoted: 523 Post(s)
Yes,you're right. Also a possibility.
#10 Old 02-18-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 324 Post(s)
Feel free to shoot me for asking but have you got the A/C on ?
frogfoot is offline
#11 Old 02-18-2019
Roodster's Avatar
Vehicle: smart Roadster, 2002 SLK 200K, replaced by 2004 SLK350
Other Toys: 1992 Ducati 900SS, 2014 Ducati Hypermotard SP 821
Quoted: 49 Post(s)
It's not that warm in the UK and it's a variable scroll compressor...or how they call it....it should't start the fan, I guess.
As said before: secondary airpump can make a whining noise after start up...
Roodster is offline
#12 Old 02-19-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 324 Post(s)
i hardly have my A/c on and once in a blue moon i have hit the AC button by mistake when i have started the the car and put heating on. by time its out garage and i have locked doors ect and got ready to drive of the fan is running at a higher speed than normal. only reason i asked as i have noticed it in the past........p.s its always hot and sunny in the uk
frogfoot is offline
#13 Old 02-19-2019
Icepilot's Avatar
Quoted: 9 Post(s)
No, not got the A/C on.
And just for your info, its been a barmy 7.5 to 12.5 degrees C over the last weekend........but still no need for the A/C
Booked in with local MB Independent garage on Thursday to get checked out/diagnostics, hopefully cheap outcome!
frogfoot likes this.
Icepilot is offline
#14 Old 02-19-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 324 Post(s)
look north said 16 this satdi !! ...never happen
hope you get it sorted
cheers pete
frogfoot is offline
#15 Old 02-19-2019
Icepilot's Avatar
Quoted: 9 Post(s)
Cheers Pete,
Hope it is 16C this Saturday, could be a good weekend, kids staying away so no cars blocking me on the drive, just me and the wife, top down (the car, not the wife) out cruising then......
I won't hold my breath though
Icepilot is offline
#16 Old 02-22-2019
Icepilot's Avatar
Quoted: 9 Post(s)
Problem sorted.
It was the main cooling fan that was running 100% in emergency mode, as the A/C refridgerant gas sensor was not reading any gas in the system!
Sensor replaced and all good, no fan noise just the burble of the V6........
frogfoot and SLKomatic like this.
Icepilot is offline
#17 Old 02-23-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 324 Post(s)
Problem sorted.
I was on the rite path..( A/C)........close buy no cigar
Glad sorted
frogfoot is offline
#18 Old 02-23-2019
Icepilot's Avatar
Quoted: 9 Post(s)
Glad sorted
Thanks Frogfoot.
Yeah, indirectly you were correct, sort of, nice to have a quiet car again.
Icepilot is offline
#19 Old 02-23-2019
Vehicle: 2005 SLK 350 AMG pack
Other Toys: 2008 Suzuki M109r
Any ideas??
Had the same issue with mine. Fan would run uncontrolled when key turned on. Took the gamble and replaced the Temp Sender unit located at the back of the block and all is well again. Also noticed a another alarm regarding coolant level which was clearly ok when i looked . Apparently the two sensors are on the same circuit. My fault finding knowledge tells me to replace one thing at a time which in this case paid off. $30 and 15min to swap out.
Craig Greenall is offline
2012 R172 SLK350 multiple error codes RJS SLK R172 General Discussion 10 10-11-2018 12:04 PM
Car Thieves Cloning More VINs From Stolen Cars Berliner Heckflosse Off Topic 6 07-06-2017 01:18 PM
Losing the car keySmartphone opens door to new ways Berliner Heckflosse Off Topic 9 10-23-2016 09:41 PM
Vancouver Island Sport/Import/Tuner Poker Run for Camp Shawnigan DDonovan Canada Region 18 11-14-2012 07:50 PM
Car Insurance: When Not to Skimp on Coverage jbanks15 Off Topic 4 09-04-2012 04:48 PM
