Very weird noise from the vent - Mercedes Benz SLK Forum
 5Likes
  • 2 Post By LeonardoDaBenz
  • 2 Post By efair
  • 1 Post By Konicky
#1 Old 02-13-2019
Vehicle: 2008 Jasper Blue R171 Facelift SLK350
Other Toys: 525d Touring, Aston Martin V8 Vantage
Quoted: 54 Post(s)
Bit of a weird one this, but every now and then, and only for a few seconds, there is a very strange sound that comes from the passenger side air vent - I haven't managed to record it, but it sounds like someone has shoved a kid's kazoo into the vent
Local mechanic has cleaned a couple of leaves out, and has put a camera down and can't see anything else that might be causing it - it does seem to change "pitch" when the fan speed is changed, but other than that I haven't a clue what's causing it - anyone got any ideas or are there any "usual suspects" for bizarre vent noises on the SLK?
Thanks in advance!
Grumpydev is offline
#2 Old 02-13-2019
LeonardoDaBenz's Avatar
Quoted: 993 Post(s)
Since it changes pitch(?) when the fan changes, I'd guess there is still something in there vibrating with the "wind".
Not a bearing noise based on what you've described.
jbanks15 and Idiot101 like this.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#3 Old 02-13-2019
Quoted: 54 Post(s)
That was my initial thought, but the pitch would also change if it was a noisy fan changing speed - only ever comes from that vent though and I didn't think it had an independent fan for it/
#4 Old 02-13-2019
Moderator/RoTMorganiser
Quoted: 2138 Post(s)
As the fan is the same side (under glovebox) I wonder if something is trapped there?
Open bonnet and I think you have to remove battery cover (3 x 90 degree clips).
You will see a small letter box opening.
This leads to fan and is notorious for introducing debris.
There's a diy for making a mesh cover,
#5 Old 02-13-2019
Quoted: 851 Post(s)
Keep in mind you can't see much when the "fresh air" flap is closed - so while you're inspecting, set this knob to "fresh air" rather than "recirculate". Also note this flap moves when the key is first turned on.
efair is offline
#6 Old 02-13-2019
Vehicle: SLK350 09
Quoted: 11 Post(s)
As Avel Du says, the noise is normally caused by leaves caught in the inlet behind the battery.
Konicky is offline
#7 Old 02-13-2019
Trev5's Avatar
Quoted: 291 Post(s)
My old R171 had a very annoying noise caused by what turned to be a leaf in fan, behind the battery box...
Trev5 is offline
#8 Old 02-13-2019
Quoted: 54 Post(s)
Thanks for the replies, he has already cleared all the leaves and crap out from there, hasn't fixed it though - he is going to fire some high pressure air through to see if that frees anything up.
#9 Old 02-13-2019
Quoted: 54 Post(s)
Thought we had it, after the high pressure treatment he found part of a chocolate bar wrapper that was wedged near the motor, but on the way home the noise came back 😞
#10 Old 02-13-2019
Quoted: 993 Post(s)
Gotta be more stuff in there.
BTW, cell phone emojis do NOT work here. You have to use the forum-supplied emojies found to the right of the box where you type your message (in ADVANCED mode).
Otherwise we get & # x 1 f 6 1 e ; (without the spaces).
LEN
(Moderator)
#11 Old 02-13-2019
Vehicle: 2006 slk280
Quoted: 116 Post(s)
you need to remove the fan from the bottom (inside the car), then clean off everything in the fan box
nguyenphananh is offline
#12 Old 02-13-2019
Quoted: 54 Post(s)
Hmm, thanks, do you know of any instructions for getting at it and removing it?
#13 Old 02-13-2019
Quoted: 116 Post(s)
there are instructions to remove on this forum. Or you can google... very easy. I think they have youtube instruction too
Vibration/Fluttering Noise from Engine Bay jaykobean SLK R172 General Discussion 40 04-03-2019 01:59 AM
Weird AC Vent Behavior Lioninstreet SLK R171 General Discussion 5 07-30-2018 10:43 AM
Weird rattling noise rakesh Tires, Wheels, Brakes & Suspension 2 05-22-2017 09:05 PM
Noise from: Windshield Center Vent (Demist) Terentius55 SLK R171 General Discussion 12 01-19-2015 06:11 AM
SLK 230 Weird grinding noise. Possible Water Pump failure. Advice needed. JaysonM SLK R170 General Discussion 8 12-27-2014 08:17 PM
