Battery dead but all is fine after charging again - Page 2 - Mercedes Benz SLK Forum
 15Likes
#21 Old 07-17-2019
Vehicle: 2006 SLK350, 6 speed manual, AMG pkg
Other Toys: BMW K1200GS, BMW K75S, Triumph Daytona, MB GLC300
I experienced same symptoms as OP.
Battery is of unknown age.
Battery compartment clean.
Fully charged battery with CTEK charger.
Car seems normal again but it has been only 3 weeks.
Iím carrying my emergency start battery in the trunk for now.
Sorry, I now this is of no help for troubleshooting your problem.
Originally Posted by Merc55 View Post
It happened again! The car was not used for 7 days and the battery only had 2,6 volt. While removing the minus of the battery I had put an amperemeter still connected to the minus clamp and minus pole the and reading showed that there was 0,02 amp flowing. That is not much and it should not drain the battery in a week. I left the headlamp switch to ďoffĒ since the last incident. I have switched daylight light running to on in the menu so I always have my lights on when driving the car.
Does anyone also have this issue? Al was well for more then 7 months!
George_in_KG is offline
#22 Old 07-18-2019
Merc55's Avatar
Vehicle: R171 55 AMG 2005
Quoted: 62 Post(s)
Did you measure the voltage? I have had cars drain a battery over time but never below 9 volt.
Merc55 is online now
#23 Old 07-18-2019
Yes. Something around 3.2 volts. I donít remember the exact number because it was so low. The low reading is why Iím so surprised that charging was successful. I assumed the battery had developed an internal short and was junk.
#24 Old 07-19-2019
Merc55's Avatar
Quoted: 62 Post(s)
Sounds like the same issue indeed. So we have 3 people now with this randomly appearing issue. The optical ring (or CANBUS?) issue VII7 suggested sounds plausable. I donít have the original radio but have for example an Alpine CANBUS adapter. I too suspected the battery but I find it strange that in all my (previous) cars only the (new) battery in a SLK breaks down to a real low voltage. I too plan on bringing a charger (and jumper cables) to roadtrip because you can not rely on it to start in the morning.
The optical cables an the MOST ring in my car are pretty much out of use since I took out the comander unit, HK amplifier and telephone. There was navigation in the car but not with a DVD unit. Satelite radio was not present either. Did you do similar removals?
#25 Old 07-20-2019
Original COMAND system and radio
Factory iPod interface
parot Bluetooth cellphone interface
No factory phone
No sat radio
In other words, pretty stock equipment
#26 Old 07-20-2019
Quoted: 551 Post(s)
If you physically took out all that stuff then forget MOST as the cause. Nothing left of it, just not used fiber.
Btw, navigation, but no DVD in trunk? Probably not Comand but APS50 (small screen,navigation with arrows) then?
And what about the trunk light as possible cause. If that keeps burning for some reason (bad switch?) it will stay unnoticed until the battery is empty.
You could remove the bulb and see what happens. Hard to tackle this problem though as it only happens once or twice a year as it seems.
Sneaky Pete is offline
#27 Old 07-20-2019
ZeroZero's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 257 Post(s)
Hi All
Just a small question , with UK SLKs should we have a plastic trim cover above the battery area fixed to the bonnet inner? . I have one on the other side but not above the battery
Andy
MartinatMersea likes this.
2005 Obsidian Black 55 AMG
Black Power Coated Rims with Diamond Cut Edge
Magnaflo Xpipe kept all 4 Cats (now two removed)
Shorty Antenna (no signal type)
Tar.ox Front Rotors
Blackvue DashCam
with In-Car Wifi
AMG Puddle Projectors
Kleemanns Headers
Eurocharged tune
Spyder Black Headlamps
AMG Logo Lower grille
G Paddles
ZeroZero is offline
#28 Old 07-20-2019
MartinatMersea's Avatar
Vehicle: 2012 SLK55, Iridium Silver, Bengal Red Leather. Sold 2010 SLK350 Obsidian Black
Other Toys: BMW325i Convertible with Smarttop, Honda CRV, Volvo 480 Turbo, Various Gadgets
Quoted: 358 Post(s)
@ZeroZero Andy the short answer to your question is no. You should have a battery cover that diverts any water to the drain hole next to the battery. The rubber lip of the battery cover provides a seal around the underside of the air intake grill on the bonnet. There should be no cover attached to the underside of the bonnet above the battery cover as this would prevent air getting to the in car ventilation system. The cover on the drivers side attached to the underside of the bonnet is to divert water away from and protect your fuse box from water. Hope this makes sense.
Martin
Mods:
CKS Bonnet/Hood Fins
AMG Grill Badge
STHFMZ2 SmartTop v1.52
MartinatMersea is online now
#29 Old 07-20-2019
Quoted: 551 Post(s)
Hi All
Andy
What @MartinatMersea says.
Read this thread https://www.slkworld.com/slk-r171-ge...h-airflow.html . Especially post #6 .
#30 Old 07-20-2019
ZeroZero's Avatar
Quoted: 257 Post(s)
Hi All
Cheers for the infor , It just looks like there is something missing when you open the bonnet , All the mounting hole are there .
Andy
Tar.ox Front Rotors
Blackvue DashCam
with In-Car Wifi
Kleemanns Headers
Eurocharged tune
G Paddles
ZeroZero is offline
#31 Old 07-21-2019
Merc55's Avatar
Quoted: 62 Post(s)
Hi All
Andy
I had the same question. It looks like something is missing but this is how it shoul be
#32 Old 07-21-2019
Merc55's Avatar
Quoted: 62 Post(s)
Haha. Thatís typical Dutch frugality. Wondering if the light in the fridge is off when you close the door indeed hard to find it as a cause when it happens only twice a year. Doesnít the light in the trunk go off in 10 minutes or so even if the swich thinks the trunklid is still open ? Just like the interior lighting will go off after a while even if you leave the doors open?
I did have the tiny screen with a navigation CD in the unit itself. There might me a phone module in the trunk remaining (the N123/1 - Multiple Handset Interface (MHI)
). Also the GPS antenna (A2/23) in the interior mirror will still be present.
But the other hand: Member george_in_kg does not have these items and he has the same issue
File Type: jpg 097DD944-C9DB-4C21-853D-F86E9FD807D0.jpg (23.0 KB, 9 views)
#33 Old 07-21-2019
Quoted: 551 Post(s)
GPS antenna is a passive device afaik, so that won't draw any power. Phone module might, allthough it is activated by the AGW.Activation is a combination of electrical signals through the wake-up line and a series of light pulses through the fiber. But as you removed the AGW, if I understand you correct, this can not happen. Theoretically.
10 minute timer slipped my mind. You're right there. It should go out after that time. Theoretically.
#34 Old 09-04-2019
Merc55's Avatar
Quoted: 62 Post(s)
I read in another post:
Having the wheel cranked to full lock (either way) apparently makes an electrical connection that can bleed the battery flat.
I park my car in the garage with the wheels in the normal position so it it not the cause in this case. But I thought I mention it here to tick all the boxes in this topic.
#35 Old 3 Weeks Ago
Merc55's Avatar
Quoted: 62 Post(s)
It happened again! The car was not used for 4 days and the battery only had 2,8 volt. Before that the car was not used for a week and started fine. Al was well for almost 3 months!
It looks like the is an unreliable component in the electrical system which randomly uses a lot of current which drains the battery fast but also stops at a certain moment.
The battery is less than a year old, no alarm, automatic headlight switch is on ď0Ē always.
Mayby just replace the battery?
#36 Old 3 Weeks Ago
Quoted: 6604 Post(s)
New batteries might come sold as new when they are sitting for a while on the shelf
what was date stamped on your 'new battery'?
#37 Old 3 Weeks Ago
Quoted: 551 Post(s)
Obviously 1 or more power consumers are at random intervals still active after shutting down the car. Could be some CANbus connected device. Hard to say. But as the MHI interface is of no use anymore I would start be completely removing this item. But solving this will be try-and-error I'm afraid. As it occurs only every few months or so, as I understand it, no much use in measuring idle current of all circuits the after you shut down the car.
Can't imagine you're willing to do that for a few months in a row.
Merc55 likes this.
#38 Old 3 Weeks Ago
MrPid's Avatar
Vehicle: 2006 SLK55 AMG
Other Toys: 2010 C300 4MATIC / 2002 Corvette
Quoted: 32 Post(s)
Interesting but frustrating problem. It could still be a faulty battery with an intermittent internal short. In my experience I've found that most of the electronics in modern cars don't tolerate low voltage very well; best to disconnect the battery for 30 minutes to reset everything.
Can you leave a current meter on the car when you park it for a few days and check it every day? If you get a battery failure with no high current then it very well could be a battery.
galaxys likes this.
MrPid is offline
#39 Old 3 Weeks Ago
Merc55's Avatar
Quoted: 62 Post(s)
Taking out some more CANBUS stuff I donít use might be a smart thing. I will look in to that. I also added an Alpine APF-D200MB CANBUS interface. They are suposed to be on the constant plus of the battery to be standby as soon as you open the doors. However people with no modifications have had this random very dead battery issue also.
Thatís what you want. And then maybe check the voltage drop over fuses and take it from there. Putting an ampere meter in the circuit is quite a job each time I put it in the garage. I kind of hope somebody with the same problem found the cause
#40 Old 3 Weeks Ago
Vehicle: 2012 slk 350
Quoted: 34 Post(s)
If it only charges to 80% you either have a dead cell or the charger is not working. Have the battery load tested.
Just type in" 12 volt battery voltage chart" in google and you will get a chart so you will know the state of the battery for voltage. If you have a weak battery, you are just chasing a ghost . You have to start out with something good and go from there.
Mountainaire is offline
Todd Clinton
Battery charger oldmercman SLK R172 General Discussion 33 11-07-2016 12:08 PM
Dead ECU? Or just dead battery? Wilhelm Sorban SLK R170 General Discussion 5 02-08-2016 02:23 PM
SLK 55 battery goes dead every 24 hours trentdingo SLK R171 General Discussion 25 10-02-2015 10:22 AM
New Radio - now dead battery Newman SLK R171 General Discussion 9 05-12-2014 04:24 AM
