Service Bulletin: Retrofit Wiring - Camshaft Adjustment Solenoids - Mercedes Benz SLK Forum
 7Likes
  • 5 Post By REB_TN_06
  • 1 Post By Gbarringer100
#1 Old 09-08-2012
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
Took my SLK into the Dealer today to mount two new rear tires and they told me about a new Service Bulletin (attached). They retrofitted four wiring harnesses on each of the Camshaft Adjustment Solenoids. It applies to all R171's with M272 engines.
It states:"due to the settling properties of the seal, oil may leak from the camshaft adjustment solenoid. Dealers will retrofit four adaprter harnesses onto the engine wiring harness as a precautionary measure at the next workshop visit."
I looked and the harness is basically a six inch wiring extension inserted into the smaller of the two connections to the solenoid. I guess that are just moving one of the components away from the potential oil leak.
Anyway - SCB is attached - just thought you guys may want to know. It's free and should happen the next time you visit the dealer. The SA said that is just came out this week. It applies to over 500,000 vehicles.
Attached a picture of one of the harnesses.
File Type: pdf SCB Camshaft Adjustment Solenoid Wiring Harness.pdf (1.33 MB, 273 views)
Woolly, jbanks15, Galo and 2 others like this.
Gene
Last edited by REB_TN_06; 09-12-2012 at 03:58 PM. Reason: Added Picture of the New Harness
REB_TN_06 is offline
The Following 12 Users Say Thank You to REB_TN_06 For This Useful Post:
#2 Old 09-09-2012
Vehicle: 2005 SLK350
Thank you. That is good to know.
poinde is offline
#3 Old 09-09-2012
Vehicle: SLK 350 facelift - palladium + gullwing red leather
REB - which engines are 272 and 273? I've got an April 2008 350.
Chris-h is offline
#4 Old 09-09-2012
fromero's Avatar
Vehicle: 2005 SLK 350 7GTronic
I wonder if they apply these bulletins worldwide (I'm in Spain) or they only do it where thay can suffer a class action..
Will check with dealer though..
2005 SLK350
Sports Airbox, Piecha Power Converter, AMG exhaust, all LED lightning package.
fromero is offline
#5 Old 09-09-2012
REB_TN_06's Avatar
Chris,
The M272 is the V6 in the R171 - both the 3.0 liter and the 3.5, in the US these are called the SLK280, SLK350, and SLK300. The SCB does not list the R170 or the R172 as being affected. The M273 is a V8 based upon the M272 design, but I don't think any of the SLK55's used this engine, as they all seem to be the M113. The 55 guys will know for sure.
Fromero,
the way the SCB is worded I would expect worldwide, but your dealer will know.
FYI this does not impact the solenoids themselves, or the seal design that causes the oil to leak out, just one of the two wiring harness that attached to the solenoid.
Gene
#6 Old 09-09-2012
Quoted: 6346 Post(s)
the 55 m113 had its own version of oil leak with the 'free' trans mount seal replacement
#7 Old 09-09-2012
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
The problem does happen on 170. On the 170 230 they will replace the leaking cam adjuster and put in the wire patch. At not cost to owner.
170 (SLK) 2001-2004 / 203 (C) 2002-2004 Service Campaign 2009100001 DEC09 This on USA cars only.
The wire patch is a soild wire that blocks the oil from wicking in the wire loom. The wire loom is twisted wire and will wick old where a soild wire will not wick oil. You can DIY by stripping back the insulation on the wire about 3 to 5 inches and then soildering all the strands in the wire into a solid wire and then reinsulated the wire.
Der Flieger likes this.
Gbarringer100 is offline
The Following 2 Users Say Thank You to Gbarringer100 For This Useful Post:
#8 Old 08-02-2013
Vehicle: 2006 SLK280 (Mars Red)
Other Toys: 1999 Harley Fatboy (FLSTF)
Chats: 3
Gene I brought mine in today and they replaced all four sensors as well.
I originally went in for the P0410 (secondary air pump) but the pump worked fine.
The services adviser said the pump was getting too much voltage, they replaced some wires by the SAM and all's good now (crossing fingers)
Enjoy,
Dave
FLSTF is offline
#9 Old 02-05-2014
GlennJohnson's Avatar
Vehicle: 2007 SLK280
I called to register my car with Mercedes -
you can do it online here as well: https://www.mbusa.com/mercedes/ownersRegistration
- and they notified me that this was still needed to be done on my car.
Good customer service!
And of course I looked up all the detailed info on here... Thanks!
GlennJohnson is offline
#10 Old 02-05-2014
Quoted: 99 Post(s)
One good reason to take your car in for service. They have these fixes but do not mail out like they do for a safety recall. Take mine in once a year for service A only each time. All other items I will do or take it to an indy to do.
GlennJohnson likes this.
#11 Old 02-05-2014
jameslk55's Avatar
Vehicle: 2005 SLK55 AMG
Quoted: 17 Post(s)
Son of a bitch, I think this was the problem I had with my 350 and the dealership could not figure it out. I think the CEL was showing something about the purge valve. They did not notify me about any service bulletins. After an indie discovered the issue, the dealership was willing to fix it at full price. I had the indie do the repairs. The cam magnets and purge valve had to be replaced and the harness cleaned.
jameslk55 is offline
#12 Old 02-05-2014
Mr.Antwerp's Avatar
Vehicle: 2006 SLK 280
Other Toys: 2012 Grand Caravan - Irish Wolfhound Doggy Van :-)
Quoted: 37 Post(s)
Owners Registration is not available on the Mercedes Canada website …
Mr.Antwerp is offline
#13 Old 04-20-2017
Vehicle: 2005 SLK280
How about in the UK? - are they replacing this wiring free of charge?
How do I check??
Martin_L is offline
#14 Old 04-20-2017
Print out the thread info and proceed to your MB dealer and ask
Exactly how does the M272 camshaft timing adjustment work? efair SLK R171 General Discussion 11 01-30-2014 07:44 PM
Mercedes-Benz Recommended Service jbanks15 General Discussion 20 02-21-2013 03:39 PM
WIS Service Hrs for Service Type 1-20 and is Firmware Included Goggomobil SLK R171 General Discussion 0 08-20-2012 09:03 PM
Service query nakulan7 SLK R171 General Discussion 10 03-09-2011 08:35 PM
