My Reset, plus and minus (r, +, -) and Electronic Engine Oil Level checks don't work - Mercedes Benz SLK Forum
#1 Old 02-20-2015
lexl's Avatar
Vehicle: 2005 SLK 200K Tip Auto
I guess spring time is upon us and peeps are beginning to check the post winter Oil Level.
My issue is that the MFD just displays "Observe Waiting Time" - Permanently doesn't matter how long its left to sit. The other issue is that the Reset Plus and Minus Buttons on the Instrument Cluster just don't work... The Service chap said there could be a software update and it might (probably not) get the buttons working again.
I've just popped into the MB Dealership and got it booked in on the 2nd March for a diagnostic to see if they can tell me what is wrong.
I have considered the alternatives which is just to get a Dip stick...
Parts told me that on my R171 200K Auto there are different versions of the Engine and for my engine (M271) there is no Dip Stick - As it has the Electronic Oil Level system.
But there is a workshop tool A2710100372 which you can just use but not leave inside the engine bay and everytime i do check the oil i will need to replace the Red Cap as that is pressurised???
Oops - may have already removed it once ...
And the price wasn't so eye watering... slightly shocked.
A6460100035 - Cover - 3.00
A2710100372 - Oil Dipstick - 12.60
I will update in March as to what they reckon the problem might be with the Engine Oil Level System.
Is the oil system pressurised? removing that red cap seems to have had no effect that I've noticed?
lexl is offline
#2 Old 02-20-2015
DSSG's Avatar
Other Toys: Model planes
Quoted: 198 Post(s)
You hold the reset button in to reset mileage. If you want to enter the service menu after doing some other stuff, you hit it three times in rapid succession.
DSSG is offline
#3 Old 02-20-2015
Quoted: 6283 Post(s)
also: post #7
https://www.slkworld.com/slk-r171-gen...t-working.html
Wavetrac LSD thread here:
#4 Old 02-20-2015
DSSG's Avatar
Quoted: 198 Post(s)
The electronic dipstick isn't a new thing on the Mercedes. Check out this video:
People missed the dipstick, so Mercedes brought it back but kept the electronic on some cars.
My guess is that it still works the same way on your car.
DSSG is offline
#5 Old 02-20-2015
The owner's manual probably would say, only available for slk 55.
see thread from today:
https://www.slkworld.com/slk-r171-gen...evel-dash.html
#6 Old 02-20-2015
DSSG's Avatar
Quoted: 198 Post(s)
He has a SLK 200K which isn't covered in the manual for the 6 or 8!
DSSG is offline
#7 Old 02-20-2015
Just sayin'
#8 Old 02-20-2015
lexl's Avatar
So I'm looking at Post #7 posted by @ademk on thread: https://www.slkworld.com/slk-r171-gen...t-working.html
I perhaps need the instructions in another way, i got this far...
Where do i the put the 8 - 10 inch plastic thing to pop the "binnacle" foward?
I suspect if others have had non functioning buttons that mine may have fallen victim to the same problem...
I want to explore this before parting with my money.
lexl is offline
#9 Old 02-20-2015
send him a pm if you haven't yet. he was on yesterday.
#10 Old 02-20-2015
lexl's Avatar
Done, although nothing in the sent items? I shall be patient.
lexl is offline
#11 Old 02-20-2015
you have to put the check mark in your save sent messages in your usercp under edit your options
#12 Old 02-20-2015
DSSG's Avatar
Quoted: 198 Post(s)
I know what your problem is, you aren't using the system correctly to check the oil level via the electronic dipstick. If you don't precisely follow the procedure outline someplace in your MB Owner's Manual, you'll get a warning message. In your case, it is "Observe waiting time."
Actually Mercedes would probably prefer the message to be, "Dummkopf," but that might be bad for PR! LOL!
Try this:
1. Thoroughly warm up the engine. Don't just idle it but take it for a good drive.
2. Bring the vehicle back to a level surface and shut off the engine.
3. Wait three minutes.
4. Then go through the procedure to check the oil.
BTW, to reset the odometer, turn the key to the accessory position or to where the MFD displays then hold down the reset button until the odometer resets.
DSSG is offline
#13 Old 02-20-2015
r
Vehicle: SLK350 MT
Chats: 1297
Quoted: 119 Post(s)
Not as such - with the pistons wizzing up and down, the pressure in the crankcase increases whilst the engine is running, and as part of pollution control systems the space vents into the inlet system.
If you leave the cap off whilst the engine is running, you might get oil droplets spraying out - as you might if you remove the oil filler cap whilst the engine is running. You won't cause any harm by removing it.
Woolly is offline
#14 Old 02-20-2015
lexl's Avatar
Try this:
I will die before this displays any other message
lexl is offline
#15 Old 02-20-2015
DSSG's Avatar
Quoted: 198 Post(s)
When it says "Observe waiting time," it is saying you didn't follow the proper procedure to check the oil. You have to start over from the beginning of the procedure. Try maybe 5 minutes.
What I think is happening the waiting time is for the oil to drain back into the sump. The sensor won't record the level while the oil is draining.
DSSG is offline
#16 Old 02-21-2015
bac
DAS/STAR Registered Owner
bac's Avatar
Vehicle: 2004 SLK350
Other Toys: RS Megane 225
Quoted: 40 Post(s)
Have a look at my DIY on replacing the lower MFD in the instrument panel:
https://www.slkworld.com/slk-r171-cla...ng-shrimp.html
It has a step by step with pics of removing the cluster and also has one highlighting the ribbon cable that connects the +,- and R buttons.
Cheers,
Brian
bac is offline
The Following User Says Thank You to bac For This Useful Post:
#17 Old 02-27-2015
lexl's Avatar
All fixed!! My thanks to @ademk
Thanks for visiting and helping fix this one.
Turns out that the ribbon cable from the buttons had been caught between the Cluster housing and had pulled it out of the connector receptacle.
a bit of tape and pushing the connector back in
All working again
lexl is offline
The Following User Says Thank You to lexl For This Useful Post:
#18 Old 03-02-2015
lexl's Avatar
Now on to the Second part of this Thread... The non working Oil Level Check system...
I've Been into MB and i am now 230 poorer...
The problem has not been fixed.
What they did do:
Visual Inspection (I feel this is probably invoice padding)
Replaced the Oil Level Sensor (as this was throwing up a fault on their system)
They suggest:
Carried out inv into oil level reading not display, found stored faults for oil level sensor, replaced sensor, fault still present. Recommend possibly new dash or front SAM unit.
They quoted silly money for a front SAM unit which apparently needs to be coded to to
the car... so it looks like I have no fix for this and the solution is totally disproportionate.
Think I'm going to have to buy the workshop single use dipstick: A2700100372
On the plus side.. I got an oil change.
lexl is offline
#19 Old 03-02-2015
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 423 Post(s)
Thats an expensive list ....
I'd get them to look at the assyst settings and make sure that they're not screwed up ..
Had the same issue on mine, caused by me and a programming session - managed to rectify it by correcting the assyst / assyst plus settings in DAS...
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#20 Old 03-02-2015
Akonion's Avatar
Vehicle: 2005 SLK 350MT
Chats: 3
Originally Posted by Seanhump View Post
Had the same issue on mine, caused by me and a programming session ...
Been there... managed to fix it and after I did I avoided using DAS for "recreational" reasons for a while...
Akonion is offline
Tags
dipstick, electronic oil check, instrument cluster, oil, oil check
