Valve Cover Leak R171 - Mercedes Benz SLK Forum
 3Likes
  • 2 Post By 100929
  • 1 Post By 100929
#1 Old 12-30-2014
Guest
Vehicle: 2007 Mercedes SLK55 AMG - Red
Other Toys: 2008 Audi A6, 24' Doral Cavalier boat.
Cool Valve Cover Leak R171
It looks like I have a leak at the back of the valve cover on the passenger side - drips onto the exhaust mfld. right above where it turns down to the cat. Is this an expensive repair to have the gaskets replaced both sides?
Rick
100929 is offline
#2 Old 12-30-2014
Quoted: 6459 Post(s)
https://www.slkworld.com/slk-r171-gen...-05-slk55.html
#3 Old 12-30-2014
Vehicle: 2012 SLK55 AMG, Diamond White
Quoted: 82 Post(s)
Really cheap if you find the right place. My indie just charged an hour and a half labour and didn't even need any new parts. This was for both sides. Problem solved
Captainrave is offline
#4 Old 12-31-2014
Vehicle: 2006 SLK350
Quoted: 17 Post(s)
It may not be the valve cover gasket. The M272 engine uses plastic plugs to seal the cam bore on the back of the heads. These are usually what leaks and is a 5 minute DIY repair. the parts cost about $25 at the MB dealer to do all the plugs.
A little story, Mine was leaking oil onto the exhaust and I thought bad valve cover gaskets. The dealer confirmed and quoted me somewhere north of $500 to fix it. I read about these plugs on this forum, checked it myself and that's what it was. $25 later and 5 minutes the problem was solved.
It broke my trust in the local MB dealer because if not for a little due diligence and research on this forum, I would have been taken for $500 by the dealer.
Good luck!
marktrue is offline
#5 Old 12-31-2014
pippins100's Avatar
Vehicle: SLK350 AMG 2005 6spd
Other Toys: Titus Racer-X Exogrid Mountain Bike
Good luck!
I am inclined to agree!!!
See this post
https://www.slkworld.com/slk-r171-gen...sion-plug.html
pippins100 is offline
#6 Old 12-31-2014
pippins100's Avatar
#7 Old 12-31-2014
pippins100's Avatar
Of course, you have a 55. I don't know if the engine has same cam expansion plug??
#8 Old 12-31-2014
Guest
Cool Valve cover leak
Did your guy just tighten the bolts or did he take the covers off and clean them up?
Rick
100929 is offline
#9 Old 12-31-2014
tricolour's Avatar
Vehicle: 2006 SLK 55 Designo Graphite, 2005 SLK 350 Black, 2001 SLK 320 Black.
Other Toys: 3.2 Boxster S, XJ 40 Jaguar, Bimota DB9C, Triumph Bonneville SE & Thruxton R.
Quoted: 34 Post(s)
On the M113 oil from a weeping cam cover gasket collects on the corner of the engine at the rear drivers side (LHD) and every now and then a drop will fall directly onto the exhaust.
The smoke produced is very impressive as it rises from the bonnet vent.
I have seen this twice on my 55 in the past 12 months so am not treating it as an issue.
I doubt that there is a 'cheap' fix but would happily stand corrected.
tricolour is offline
#10 Old 01-01-2015
Guest
Cool
Good luck!
Mine is the SLK55 AMG - I can't find expansion plugs ??
Rick
100929 is offline
#11 Old 01-25-2015
Guest
Hooray - I fixed the leak. It turns out that many of the valve cover bolts were loose. Some could be turned by hand using just a socket and an extension. I snugged them all up properly to 9 nm, cleaned the wet areas and the leaks are gone. There were 4 leaks in total and all at a valve cover bolt location.
jbanks15 and Yeravener like this.
100929 is offline
#12 Old 06-22-2015
Guest
Well it started leaking again - I took it to the MB dealer and they replaced the valve cover gaskets and resealed the breather covers. They also cleaned up the engine nicely. Two hours labour plus parts/supplies - $415.00 incl taxes. Now it is fixed !!
Rick
Yeravener likes this.
100929 is offline
R171 Outdoor Car Cover - mid range? sgh Where to get R171 SLK Items 13 01-17-2015 04:25 AM
R171 MB Indoor Car Cover Captandy SLK Parts For Sale 1 09-02-2014 07:08 AM
Valve Cover Replacement Magnesium Corroded Bradley61496 SLK R170 General Discussion 9 03-18-2013 11:54 AM
Valve Cover pemsland Where to get R170 SLK Items 17 10-06-2012 11:35 AM
