Oil Leak, Possibly cam shaft expansion plug? - Mercedes Benz SLK Forum
#1 Old 01-07-2014
Vehicle: 2006 Silver SLK280 bone stock.
I noticed the dreaded smell of burning oil this morning after cranking up the slk. Upon inspection, the oil seems to be seeping from a black round plastic cap that is to the left of the oil dip stick. The fact that it is dripping down to the catalytic converter scares me as it could be a fire hazard. Can someone please confirm that the part I'm looking at is the cam expansion plug? This is on the passenger side, 06 slk280.
Tx280 is offline
#2 Old 01-07-2014
Chats: 2
Quoted: 13 Post(s)
If you are talking about the flat, black disk on the back of the head, then yes, that is probably where the leak is happening. Is there oil on the rear of the head? It's an inexpensive diy fix.
Think outside the box!
Galo is offline
The Following User Says Thank You to Galo For This Useful Post:
#3 Old 01-07-2014
Thanks for the reply. Yes the flat disc is where I suspect the leak to be coming from. There is oil on the back of the head, some has even managed to drip onto the cat. Is is really just a matter of prying the old one off and popping the new part in? Is there another thread with a DIY instruction for this? Any idea of how much the part will cost?
Tx280 is offline
#4 Old 05-22-2016
Vehicle: 2009 SLK350
Other Toys: 64 Pontiac GTO Rag Top
Quoted: 25 Post(s)
Found this same smell and oil leak on my 09 SLK350. Easy and inexpensive fix.
Thanks to this 2014 thread I was able to find and fix. See attached pics with part numbers.
RNVSLK is offline
#5 Old 12-31-2018
Vehicle: 2005 SLK350 6-speed
Quoted: 14 Post(s)
Found oil on the garage floor, smelled oil burning when running up through the gears, saw smoke coming up through the hood vents after the car has sat for a while and took a shirt run to the store.
Finally had a look, found what you've described here. Thanks to this old thread, I'll fix it myself.
https://youtu.be/OfyuBqqJ60c
Sean65 is offline
#6 Old 01-05-2019
Quoted: 14 Post(s)
Ok, that was a 1 minute replacement of the large plug. The SLK appears to be an easier replacement than what I saw on YouTube examples.
What confuses me is, this plug doesnt have a rubber seal that fails, it's just plastic. I don't understand how replacing it with another plastic plug is a remedy.
I'll keep an eye on it.
File Type: jpg 15467126222064973704618905284270_1546712665145.jpg (36.9 KB, 5 views)
Sean65 is offline
#7 Old 01-05-2019
Quoted: 14 Post(s)
I take it back. There is a rubber seal along the side of the plug.
File Type: jpg 15467131253423350486911979473445_1546713171093.jpg (22.6 KB, 9 views)
Sean65 is offline
Oil leak and cam expansion plug korgua SLK R171 General Discussion 16 05-09-2018 10:35 PM
Blackstone Lab oil report - 2005 SLK350 fgwinn SLK R171 General Discussion 12 08-10-2009 06:11 PM
