Balance shaft sprocket M272/M273 - Mercedes Benz SLK Forum
 209Likes
#1 Old 11-23-2013
Quoted: 6483 Post(s)
Applicable Models (Not Applicable to Model 164.156, 204 or 216.386): Equipped with M272 Engine Up to
Serial No. 2729..30 468993 or M273 Engine Up to Serial No. 2739..30 088611.
The material for the balance shaft sprocket and the timing chain guide wheel (idler) was modified on
engines past the serial numbers listed above.
the ... represents 'any number'
Courtesy Efair
Added by jbanks15:
Balance Shaft Gear Issues
M272 engines that were sold between 2004 and 2008 with engine serial numbers below 2729..30 468993 often show early wear of the balance shaft gears, requiring extensive repairs at a retail cost of over $4000. These complaints led to a class action lawsuit against Mercedes Benz (Greg Suddreth and Paul Dunton v. Mercedes-Benz USA, LLC), which alleged the M272 engines are equipped with defective balance shafts gears which "wear out prematurely, excessively and without warning, purportedly causing the vehicles to malfunction, the check engine light to illuminate and the vehicle to misfire and/or stop driving." The suit further alleged that Mercedes knew of this problem, sending out repair bulletins on how to address this issue and ultimately changing the balance shaft gears to avoid this problem. This suit was ultimately dismissed with the judge agreeing with Mercedes that because the gears fail at 60 -80K miles and outside of the warranty period, Mercedes is not legally responsible for these problems. A second class action lawsuit is being organized. [7]
7. "Mercedes Benz named in class action over safety issues related to its M272 or M273 engines". Retrieved Mar 12, 2013.
http://gotaclassaction.com/mercedes-...-m273-engines/
Do the video test to see if you have the issue, posts 106 and 117 and here
from Michael H.
https://www.slkworld.com/slk-r171-cl...0-minutes.html
Easy Balance Shaft Check from Brad Wessels here:
https://www.slkworld.com/slk-r171-cl...revisited.html
Check your engine number in your free datacard:
https://www.slkworld.com/vehicle-dat...-datacard.html
Here are sister threads on this issue:
https://www.slkworld.com/slk-r171-ge...-sprocket.html
https://www.slkworld.com/slk-r171-ge...ions-pros.html
https://www.slkworld.com/slk-r171-ge...ml#post4410515
Here is Notice of Pendency and Proposed Settlement of Class Action attached
see last pages of this thread for discussion
The Balance Shaft/Idle Sprocket settlement was approved by the court
post 156
Read the court document https://eclaim.kccllc.net/caclaimforms/mse/docs.aspx
Originally Posted by George_in_KG View Post
FCPEuro is my first choice for on-line MB and Volvo parts. They just published this guide for common problems with the M272/273 engines and I thought everyone here would find it interesting. It is a nice summary of many topics that are covered here on slkworld.
https://blog.fcpeuro.com/the-definit..._hsmi=70579093
ryanwmusic and Michael H. like this.
The Following 7 Users Say Thank You to jbanks15 For This Useful Post:
#2 Old 12-08-2013
DAS/STAR Registered Owner
Akonion's Avatar
Vehicle: 2005 SLK 350MT
Chats: 3
Quoted: 106 Post(s)
My engine (272963 30 003441) seems to fall within the range. If I were to encounter balance shaft issues what would the symptoms be, and what could I do to be proactive against it?
Akonion is offline
#3 Old 12-08-2013
bac
bac's Avatar
Vehicle: 2004 SLK350
Other Toys: RS Megane 225
Quoted: 40 Post(s)
Often there are no major symptoms until the CEL comes on. If you have STAR, you can periodically check for codes relating to cam bank timing issues. Other than that there is the visual inspection technique for checking the cam bank timing marks are still aligned (search on here for link to video).
Not much you can do to be proactive about it - if it's going to happen, it's going to happen.
Cheers,
Brian
bac is offline
The Following User Says Thank You to bac For This Useful Post:
#4 Old 12-08-2013
Akonion's Avatar
Chats: 3
Quoted: 106 Post(s)
Cheers,
Brian
Damn.. I know that the sprockets are not too expensive, but is the labour on them killer? If this may be an issue I want to budget for it.
Slkoko likes this.
Akonion is offline
#5 Old 12-08-2013
bac
bac's Avatar
Quoted: 40 Post(s)
Engine must be removed from car and I think other parts are also required to be changed while it is out. At some point Mercedes actually put together a kit of parts needed to address the issue. Google and you should find it.
I believe the labour component of the job is north of 50 hours. Total cost figures I have seen reported vary between $4K-$10K.
Cheers,
Brian
bac is offline
#6 Old 12-10-2013
Quoted: 899 Post(s)
My invoice shows the balance shaft kit at $465 USD. Motor mounts, head gaskets, intake gasket, tensioner, breather cover, cam sensors, cam actuators, and fluids brings the parts tally up significantly though -- to about $1400.
efair is online now
#7 Old 12-23-2013
Vehicle: 2012 SLK350 White
Courtesy Efair
Hi, since what model year could we say this issue was resolved? I am looking to buy a used one and it would be easier for my search.
Thanks!
Ben535 is offline
#8 Old 12-23-2013
see the reply by Woolly in your other post. Oil was usually 2005 and sprocket 2006-8
#9 Old 01-26-2014
Vehicle: 2005 SLK350 6-speed
Quoted: 12 Post(s)
Found this amateur video showing exactly what a worn balance shaft looks like and its location within the engine. Also gives tips on repairing the job yourselves... yeah, good luck.
For Ipad users:
jbanks15 and caschoug like this.
journeyman is offline
The Following User Says Thank You to journeyman For This Useful Post:
#10 Old 05-14-2014
Vehicle: 2007 SLK 280
SLK 280 Balance Shaft Problem
Are there any other people on here in the UK that has had this issue?
I have recently purchased an SLK 280 and have now been told that balance shaft needs replacing at a cost of £5000+
Car is 2007 and only 22,000 miles
Repair represents almost half the cost of the car :-(
Rob
Optim8 likes this.
RobHufton is offline
#11 Old 05-14-2014
bac
bac's Avatar
Quoted: 40 Post(s)
Very sorry to hear it! Would have thought it quite unlucky to strike this problem on a 2007 car...
Have you tried approaching Mercedes directly for a goodwill gesture given the very low mileage and the fact that it's a well known problem?
Hope things eventually turn out OK.
Cheers,
Brian
bac is offline
#12 Old 05-14-2014
Star/DAS Registered Owner
Quoted: 503 Post(s)
Rob
Seems like very low mileage for this to be showing up. What are the symptoms and what has been done to confirm the problem? Is a second opinion warranted? Since you just recently purchased the car does the seller share any obligation here?
mchild is online now
#13 Old 05-15-2014
Cheers,
Brian
Thanks very much Brian,
I have asked my local MB service manager to ask MB if there is a possibility of contribution towards this known problem, but he does not hold out much hope as car is more than 6 years old :-(
Regards,
Rob
#14 Old 05-15-2014
Hi there,
Car has fault codes 1200 & 1208 (P0017 & P0017) which are usual indicators, plus cog fragments found in my engine are pretty conclusive...
I purchased car with 3 months seller warranty which has now expired
Regards,
Rob
#15 Old 07-06-2014
Sandtoes's Avatar
Other Toys: 2006 VW GTI; previous: 1986 VW Jetta GLI (owned 17 years), 1997 VW Golf K2 (16 years)
Different Part Number for improved part?
Wife drove home today from running an errand, describing the rough running and CEL that came on - I fear the sprocket issue is saying, "Hello!" Our SLK350 has about 41,000+ miles.We'll be taking it in tomorrow.
Didn't have luck searching but I apologize if this is answered already...what I'm curious about is did Mercedes come out with an improved sprocket to replace the problematic one? Is there a part number revision from the old part number that confirms there is a change? Just would like to know if this is going to become a "regular replacement part" to be aware of, or the fix is a long term/permanent solution.
Sandtoes is offline
#16 Old 07-06-2014
per efair's post above:
so i think it would be the parts kit n not just the sprocket.
i checked epc and there is no new 'shaft/sprocket' replacement number i can find
#17 Old 07-06-2014
Sandtoes's Avatar
Ooo man, that doesn't give me the warm fuzzies. I'll give up thinking about it until tomorrow - no sense in wasting the last hours of a long holiday weekend dwelling on it. Jeff - your powers of replying to all these posts - amazing! Thanks!
Sandtoes is offline
#18 Old 07-07-2014
Quoted: 899 Post(s)
Don't panic -- the balance shaft symptoms aren't "sudden onset" like this; plus there are specific codes for the problem. Have your codes read and cleared for free -- most parts places offer this service (just be sure you write them down before they're cleared). Let us know what they are.
jbanks15, Sandtoes and Danielmease like this.
efair is online now
#19 Old 07-07-2014
Quoted: 12 Post(s)
It seems only Mercedes knows the statistics on this sprocket failure. The teeth wear occurrence is sporatic; I've found the mileage range to be from 20k-120k. How are some cars having this issue at only 20k miles?
My trusty mechanic says if you use a good oil (not Mobil 1), and change your oil every 5k miles, you will not see this sprocket wear problem. The main goal for engine oil is to prevent wear of the internal metal parts. There is a reason why Mercedes updated the oil change interval from 12k miles to 5-6k miles.
carlover likes this.
#20 Old 07-08-2014
Quoted: 37 Post(s)
Hi there,
Regards,
Rob
If the car was purchased less than 6 months ago you would still have have the a
Sale Of Goods Act.
Mark
Danielmease and LouisvN like this.
Mark999 is offline
Balance shaft failure symptoms ? Michelle's SLinKy Performance MODS for the R171 9 02-14-2017 07:07 AM
Balance Shaft Sprocket srs-1 SLK R171 General Discussion 54 05-12-2016 11:42 PM
Balance Shaft Sprocket Worn M272 V6 Ken Walker SLK R171 General Discussion 58 09-02-2015 04:43 PM
balance shaft (again) A14RDX SLK R171 General Discussion 2 11-23-2013 08:52 PM
Balance Shaft Sprocket problems MadHungarian SLK R171 General Discussion 6 05-30-2013 07:32 AM
