R171 Tail lamp removal procedure - Mercedes Benz SLK Forum
 58Likes
#1 Old 08-12-2012
Quoted: 344 Post(s)
Thanks to Durkatlon for showing and explaining the procedure as we met this morning to remove ponia003's tail lamp assembly and install the AMG tail lamp (with the central horizontal smoked area).
Credit goes to Durk for explaining and demonstrating the procedure, and to Dan for the demonstrator vehicle.
The procedure has been described and illustrated in the following posts:
1. Link to John's (UK-C200) post: https://www.slkworld.com/slk-r171-gen...t-removal.html
2. Link to Zeiser50's post on removing the center panel in the boot/trunk: https://www.slkworld.com/slk-r171-gen...r-section.html
What follows is mainly a supplement to the above 2 posts, and perhaps the accompanying photos will make the procedure clear. This is by no means comprehensive and does not replace what a skilled and trained authorized technician may provide.
The procedure in outline form
Tools:
Small flat head screwdriver (more like jeweler's flat head screwdriver)
8mm socket and corresponding ratcheting wrench
T-15 Torx head screwdriver
wedge tool (optional)
1. The first procedure is to remove the center inside/inner smooth lining/panel inside the trunk/boot space and is broken down as follows:
a. Remove 8 (4 on each side) RECTANGULAR 2-piece expansion-type fasteners located at the upper portion of the panel
b. Remove 5 (2 on each side, one in center just below trunk latch anchor point) ROUND 2-piece expansion-type fasteners located at the lower portion of the panel
c. Remove 2 torx screws at each lower corner. These are covered (round). The covers are hinged open by using small flat-head screwdriver revealing the underlying torx screw.
d. Remove 2 rubber bumpers. Loosen the single screw that holds the second generation digital satellite radio receiver and pivot downward (older models: first generation satellite receiver may need to be removed using a different method)
e. Loosen the rear of the rectangular "horse-hair" borders that "protect" the complex hinges of the trunk/boot lid. These are part of the furry inner lining at the sides of the trunk/boot space. Loosen also the panels that one opens to gain access to the rear of the tail lamp assembly, e.g., when changing out the turn signal lamp.
f. Remove the center panel by pulling the panel's RIGHT outer edge inward and upward to release one side from the compression fitting at the lower corner (I labeled them "legs"), a wedge tool may be handy but not really necessary.
g. Once the right side is free, it will be easier to loosen and free the LEFT side but be careful as the wire connections to the trunk light (caution: hot lamp) and to the trunk lid separator mini-switch are still attached. Disconnect these once they are visible and accessible.
h. Center panel should now be completely free.
2. Remove the four 8mm nuts that fasten the tail lamp assembly to the body panel. As John stated, 3 are easily visible and the fourth is behind the furry panel but easily felt. Take great care in removing the nuts. Loosen first with the ratcheting wrench, then use fingers to loosen and remove completely. DO NOT drop these or they will fall into the deep recess of the rear body panel, never to be seen again. The tail lamp assembly can now be worked loose. Disconnect the wire harness that clips to the tail lamp assembly.
Post #3 (no post title)
Location of expansion-type fasteners, torx screw and rubber stopper/bumper:
yellow arrows point to the RECTANGULAR 2-piece expansion-type fasteners
red arrows point to the ROUND 2 piece expansion-type fasteners (including the center one)
blue arrow points to the rubber bumper
white arrow point to the torx screw position
The coloured arrows point to those at the right side of vehicle, there is a corresponding left side.
Post #4 (Removing RECTANGULAR 2-piece expansion-type fasteners)
What the RECTANGULAR 2-piece expansion-type fasteners look like:
Post #5 (Removing ROUND 2-piece expansion-type fasteners, and torx screws)
Post #6 (Removing the rubber bumper)
What the rubber stopper/bumper looks like after removal, notice the arrow-shaped lower end (be careful not to tear or damage these during removal)
Post #7 ("horse-hair" border loosening procedure)
"horse-hair" border at the trunk/boot lid hinge mechanism
What it looks like when all loosened (note photo shows the center panel already removed)
Post #9 (Removing the center panel)
Remove center panel from the right side first, then left. One must loosen the compression fitting or leg that is at the lower corner by pulling upward and inward or use a wedge tool to loosen.
Close up of the "leg" or compression fitting
Post #10 (Remove connection to trunk lid separator limit switch and trunk light, remove 4 nuts)
8mm nuts
What it looks like after removing tail lamp assembly. Notice the four holes through which the tail-lamp is fastened to the body.
Hope the above is helpful and clarifies the procedure better.
Assembly or replacement is of course the reverse procedure.
The Following 4 Users Say Thank You to etyu For This Useful Post:
#2 Old 08-13-2012
AZ SLK's Avatar
Vehicle: 2007 MB SLK 280, Remus Exhaust, TSR 17" wheels, Pirelli PZero tires
Other Toys: '15 Z51 Corvette, '12 Cadillac Escalade EXT, '11 MB GLK350, '04 Honda GoldWing, '13 Craftsman VT4000
Quoted: 25 Post(s)
Awesome and great timing as I should be getting my conversion DIY for LED brightness and turn signal mod from Durk early this week and have emailed the seller of LED tail lights and hope to hear back shortly.
Thank you for the additional pictures and narrative along with the the original posts.
Michael --
AZ SLK is offline
#3 Old 08-13-2012
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 266 Post(s)
Wow, fantastic post.
Eddy, it was great seeing you and Dan today and working on the tail install together. Amazing how hot it was at 7am! You can imagine what the rest of my day was working on the tail light module...
This will be my new go-to post for anyone with questions on the tail light install.
WarwickThumbNT likes this.
Durkatlon is offline
#4 Old 08-14-2012
ponia003's Avatar
Vehicle: 2006 SLK280, 2005 E500 (W211)
Other Toys: Horses
Quoted: 28 Post(s)
Great write up Eddy. I had a good time learning about the car with you guys.
Dan
2006 SLK280
Engine: 272.942 V6
Options: Iridium Silver Paint, Harmon Kardon Sound System, Heated Seats, Air Scarf, Vavona Wood Trim
Modifications: 18" AMG wheels, Brembo Sport Pack Front Rotors and Calipers, 290 mm Rear Rotors and Calipers, SmartTop, Akebono Ceramic Brake Pads, Mid-Size R171 Facelift Antenna, Clear Sidemarkers, Chrome Turn Signal Bulbs, Mercedes Star Valve Stem Caps, Custom Cabin Air Intake Screen, AMG Tinted Tail Lights and 3rd Brake Light, Xenon Low Beams, OEM Sport Air Cleaner with Custom Port Screens, LED License Plate Lights, LED Parking Lights, Lamin-X Fog Light Films
ponia003 is offline
The Following User Says Thank You to ponia003 For This Useful Post:
#5 Old 08-14-2012
Strgazr's Avatar
Vehicle: 2008 SLK 55 AMG
Other Toys: 1990 Honda CRX, 2004 Honda Element, 2004 SL600
Excellent and incredibly detailed writeup. I can't wait to put it to use and am sure it will be an easy job thanks to the efforts of you and Durkatlon.
LeftyS7 likes this.
Strgazr is offline
The Following User Says Thank You to Strgazr For This Useful Post:
#6 Old 10-13-2012
Vehicle: 2005 SLK 350
Excellent post! I'm definitely looking forward to doing this on my car
AndrewHart is offline
The Following User Says Thank You to AndrewHart For This Useful Post:
#7 Old 04-25-2014
Vehicle: 05' SLK 350
Chats: 10
Is there anyway to include the part numbers to the photos? Just for extra clarification? It's just a suggestion.
MrsSLK350 is offline
#8 Old 08-24-2014
Ozzyscot's Avatar
Vehicle: 2009 SLK200
Other Toys: 2004 CLK 240, 2011 Toyota Kluger. Previous cars 2000SLK 230
Thanks for the fantastic tip, replaced my rear tail light in an hour.
Ozzyscot is offline
#9 Old 12-07-2014
Other Toys: Jet Tablesaw, Nike Running Shoes, Fuji bicycle, 2000 F-150 XLT
Broken Tail Light
This looks like a great post and could be helpful for me. I went to lunch the other day and noticed on arrival that my right side tail light was broken. I have no idea how this happened. I am guessing some nice person in a parking lot "kissed" the corner of my car and then left. Replacing the assembly looks like a pain, but should be easy enough.
I have another question though, which might make me take my car to the shop. I have noticed that the plastic roof/lid protective separator no longer comes down and cleanly engages where it should.
I also noticed that whoever hit my car, pushed the light back into the body a bit - maybe no more than 1/8" to 3/16". I do not see any body panel damage. Just damage to the light assembly. Light bulbs are still intact and work fine. I am wondering if the rear has been twisted a bit? Does this sound like a possibility?
I'll be searching the forum more for replacement tail light part numbers. I am sure there are replacement recommendations.
Thanks in advance for the feedback.
curthslk2005 is offline
#10 Old 12-08-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 266 Post(s)
As you can tell from the picture of the SLK included in this DIY which shows the tail light removed, there is really no way for a tail light to be pushed into the body without the body panel warping. Since you mention that roof separator does not want to engage anymore, that lends additional credence to the idea that the body panel is slightly deformed in that area.
It sounds like a trip to a bodyshop is in order. If you want to save money on the replacement tail light, you can actually get the original manufacturer version from Amazon.
Here's the right tail lamp housing (CLICKY! CLICKY!) (non-AMG).
#11 Old 12-09-2014
Thanks Durk! Your post seems to confirm my suspicions. I guess my girl hasn't been to her favorite body shop in a while. Just not the time of year I wanted to have to do this.
When I called the Benz dealer they wanted my VIN to ensure the correct part. Did these lights change during the 2005 model year?
#12 Old 12-09-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 266 Post(s)
No, but there are 2 versions of the light, one for AMGs and one for everyone else. The difference being that the center section (which has the backup lights) is smoked on the AMG version and clear on the other one (the clear version being the one I linked from Amazon in my earlier reply).
I remember that the dealership wanted $450 for a single AMG tail, which I subsequently picked up from Amazon for $300. So there's definitely some savings to be had.
etyu likes this.
#13 Old 02-18-2015
Quoted: 344 Post(s)
Moderators, is this thread worthy of a Sticky in the DIY R171 section?
jbanks15 and LeftyS7 like this.
#14 Old 02-18-2015
Quoted: 6103 Post(s)
As you wish Dr!
Wavetrac LSD thread here:
#15 Old 02-19-2015
DAS/STAR Registered Owner
Akonion's Avatar
Vehicle: 2005 SLK 350MT
Chats: 3
As you wish Dr!
Behold, the power of Jeff!
Akonion is offline
#16 Old 07-01-2015
Vehicle: 2011 SLK 350
Other Toys: C270 estate
Quoted: 35 Post(s)
Is it possible to change the side panel with out disturbing the roof .
racall is offline
#17 Old 09-08-2015
Vehicle: SLK 55 AMG 2009
Other Toys: E-Type S1 1963 OTS, Ferrari 355 GTB, Rural Willys SW
Quoted: 13 Post(s)
Hi Eddy/Durk,
Yesterday I found one of my brake tail lights not working. Could one of you confirm the product below is suitable and reliable as replacement?
9 LED P21/5W 380 BAY15D 1157 STOP REAR BRAKE TAIL LIGHT BULBS SUPER WHITE | eBay
Thanks!
Fred
fredmec00 is offline
#18 Old 09-08-2015
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 266 Post(s)
Originally Posted by fredmec00 View Post
Hi Eddy/Durk,
Thanks!
Fred
I don't think those will work. The tail lights on the R171 use a bajonet fitting where the two bajonet prongs are at a less-than-180-degree angle (PY21W a.k.a #7507) and only the "+" pin is sticking out the bottom (with the "-" being the body of the bulb housing). The bulbs you linked use a 180-degree bajonet and have both a "+" and "-" pin on the bottom.
Additionally, after installing LED bulbs you need burn off the excess current through a parallel resistor. If the bulbs do not have this resistor built-in, the car will throw up a "bulb out" warning on the dash and turn the bulb off. You can remedy this by installing a resistor yourself, but this involves wire splicing etc, which you may or may not be ready to pursue.
The eBay ad you linked says the bulbs run off less than 1W of power, which leads me to believe that these do not have a resistor built-in and will therefore give a "bulb out" warning.
#19 Old 09-09-2015
Quoted: 13 Post(s)
Very good point Durk, I believe you right. Those bulbs are advertised as SLK compatible by the seller... the usual ebay problem.
Would you have the part number for the Brake-tail bulb for an SLK 2009? I am new into SLK world and I find difficult to manage replacement parts, since I have no access to the part numbers until I take things a part.
Any clues where I could get a hardcopy for the parts catalog?
#20 Old 09-09-2015
dbgrn's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 1035 Post(s)
@fredmec00, A word of caution... using online parts references can sometimes differ from your own car's requirements, due to geographic differences. I used an online SLK R171 owner's manual to check what new front foglamp bulbs I needed for my 2005 SLK 55 AMG, and it suggested I needed HB4 bulbs (I think it was a U.S. version of the manual). However, in the UK, it appears that the front foglamp bulbs on my car are actually H7 type bulbs, so I had to reorder a different type of bulb!
So, my recommendation is for you to check the hardcopy owner's manual for your car (or, at least, make sure it's one for your country's marketplace) to find out what bulb type you need.
- Dave
Mods:
(MB p/n A1718202075)
wind deflector
• Post-FL wing mirrors
• CF-effect interior trim
• AMG LED puddle lights
• Piecha DRLs
dbgrn is offline
How to: Access rear lamp assembly to change tail light bulbs on a 2006 SLK 350 wallyh010 SLK R171 Class DIY 25 02-10-2018 08:34 AM
R171 Door mirror indicator lamp replacement Ikarus SLK R171 General Discussion 13 12-17-2016 06:58 AM
Going to Baptise my R171 on the Dragons Tail pbt3 SLK R171 General Discussion 9 07-15-2012 05:11 PM
DIY: SLK55 R171, Exhaust Manifold Removal, Repair, Replacement lebmingling SLK R171 Class DIY 10 02-26-2012 02:21 AM
