DIY - Retrofit electric seats - Page 3 - Mercedes Benz SLK Forum
 27Likes
#41 Old 08-31-2018
S L K Tech Enthusiast
SoCalBeachRunner's Avatar
Vehicle: Tellurium/Ash 06 SLK350 w Controller knob, Smartphone integration, backup cam; 05 SLK350 AMG package
Other Toys: Hackables: iOS/Android/Linux devices, Arduino, Macs, Cars, Life!
Quoted: 66 Post(s)
Send a message via Skype™ to SoCalBeachRunner
Thank you to @Seanhump and @brental1. My power seat retrofit worked out beautifully! Extracted the power seat harness from one purchased on eBay, a tedious process since I preserved the rest of the harness by carefully unwrapping and re-wrapping the affected sections.
The donor car was a beauty with lumbar air bladder and air lines etc. which my seats didn't have. Planning to re-sell the intact full-car harness on eBay for someone adding Airscarf, heated seats, lumbar, or apparently about every other option to their R171.
Loving the power seats. Feels a bit higher and provides a steeper angle sloping back/down in the base. More luxurious than the manual version.
Harness came with fuse box, all fuse holders and fuses. After a meticulous process to extract the required cables from the full harness it was just as tedious to get it into the car. Use disposable gloves to keep the gummy black cable wrap adhesive off skin and everywhere else.
The difficult part of the retrofit was routing the wire under the back of the center console. I could not for the life of me get the rear console section to budge after unfastening everything I could find and pulling a lot harder than I should have - luckily nothing damaged. Somehow - with much perseverance, some blood, and choice words heard more often in rap songs and cable tv shows - managed to route the end of the cable under the console in-place and carefully pull it though.
Second worst part was figuring out how to pop open the $#@&*!% CAN voltage distribution connector. Second only to the passenger footwell power socket connector, this black-on-black, tight fitting, "is that a seam, or not a seam?" plastic housing is actually an ancient puzzle out of a Dr. Who episode or Indiana Jones movie. I should have installed the SmartTop that's been in my cabinet for years but by then was too tired, sweaty, slightly bloody, running out of new swear words, and - most of all - loosing light. Yes there are pictures about this in other posts but I needed a video. Going to post one before long when I finally install the SmartTop soon.
In my car the power seat functions w/o the key inserted (the way I want it), and the memory function works w/o any programming. No easy entry function, need to read up on that but don't really care.
@Seanhump
Make sure the heaters work in the new bases!!
I must have damaged the driver side heater in the base since it's no longer heating, but the passenger side heats up in base and back. However, to me this is actually an improvement not a bug. The driver base used to get too hot for my taste and made my thighs feel like it was going to burn them. Now with only the back heater I can actually enjoy heated seats for the first time. Passengers side is toasty in base and back. I will probably double check the connector and continuity just for closure when adding the SmartTop. Had i know before what i know now, I'd probably have disconnected the power connection for the driver side base years ago.
This is a great and relatively straightforward upgrade. Great feature in terms of look, comfort and functionality.
brental1, brental1 and brental1 like this.
SoCalBeachRunner is offline
#42 Old 09-01-2018
Vehicle: 2006 SLK 280
Other Toys: 1976 280Z
Quoted: 8 Post(s)
Retrifit Electric seats
Congratulations. I can relate to some of your frustrations. I tore my car apart to install COMAND and HK one year before tearing it apart to do the seats. Wish I would have had all the components at the same time; but at least the second time was a little easier.
Brent
brental1 is offline
#43 Old 09-18-2018
Vehicle: 2009 SLK 55 AMG Palladium Silver
Other Toys: Yukon Denali
If anyone knows how to get air conditioned seats or ventilated seats I would be interested. Thanks.
Crose is offline
#44 Old 03-21-2019
Vehicle: red SLK 300, 2010
Hi, can I mount electric seats from the 2006 model to the 2010 facelift? Thanks
Ros Ch is offline
#45 Old 06-11-2019
Quoted: 8 Post(s)
Are there pics or schematics in WIS document GF91.29-P-5260SK giving the overview of components of the lumbar support (option U22)? If so, can you post them? What I really need is the routing of the 2 lines from the Vacuum Pump. One line has straight fitting, other has 90 degree fitting. I need to know which line attaches to which port on the pump.
I have noticed my pump constantly cycles. Don't know if I have it routed incorrectly, or if I have a leak in the system.
Thanks,
Brent
brental1 is offline
Sell full retrofit package 2 electrical, airscraft, heated Black leather seats with red-top stitching stefan SLK Parts For Sale 0 02-21-2014 02:40 PM
2014 Mercedes-Benz SLS AMG Electric Drive, a real shocker: Motoramic Drives jbanks15 Off Topic 3 03-08-2013 02:40 AM
Anyone installed electric seats? pontiuspilot SLK R171 General Discussion 3 01-27-2010 11:41 PM
Electric Seats aramis General Modifications R171 3 05-11-2009 01:08 AM
Manual to Electric seats? SLKman SLK R170 General Discussion 16 01-20-2009 03:00 PM
