Removing sunshade and A-pillar cover/moulding - Mercedes Benz SLK Forum
 20Likes
  • 4 Post By etyu
  • 2 Post By LeonardoDaBenz
  • 2 Post By jbanks15
  • 5 Post By LeonardoDaBenz
  • 1 Post By LeonardoDaBenz
  • 1 Post By etyu
Old 03-08-2014
I have to remove the A-pillar cover today as some part of the rubberized material has loosened up and needed to be glued back (using Gorilla glue) and thought of posting a simple DIY.
So here are the photos and some attached comments.
1.
2.
3.
Close-up of connector (this supplies power to the vanity light).
Close-up of anchor at top of A-pillar:
Addendum: this piece I snapped off while trying to slide the A-pillar cover back on. No biggie, reassembly is easier without it and the A-pillar cover holds up fine
#2 and #3 may be reversed.
Assembly is the reverse of the above. Hope y'all find this helpful
Woolly, jbanks15, curro101 and 1 others like this.
The Following 5 Users Say Thank You to etyu For This Useful Post:
Old 04-18-2017
Vehicle: MercedesBenz SLK 200 year 2006
Thank you so much for the informatión!
I just buy the pillar A (see Photo) with the light to retrofit courtesy light in the sunshade, but also I have to change the sunshade to make apropiate contact to power on - off the light.
Somebody can tell me wich P/N I need?
Best regards!
amavial is offline
Old 4 Weeks Ago
Vehicle: SLK 280, 2007
Other Toys: Not really
I see only blurred photos with big "photobucket" logo on them - any idea what I should do to see the actual photos?
glushkov is offline
Old 4 Weeks Ago
Quoted: 2342 Post(s)
Unfortunately these are hosted on photobucket.
We had a work around, but PB have now worked out how to block that.
@jbanks15
@LeonardoDaBenz
Avel Du is online now
Old 4 Weeks Ago
LeonardoDaBenz's Avatar
Quoted: 1086 Post(s)
Although they are blurry (as above), if you right click on the blurry pic and "open in "new window (computer) or tab (tablet), it's as clear as it should be
You can also download it to your computer for clear viewing as well.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
Old 4 Weeks Ago
Quoted: 6610 Post(s)
still blurry for me
my choice is open in new tab (on a pc) and still blurry
message sent to etyu to see if he has the original pics @etyu
Avel Du and davyb like this.
Old 4 Weeks Ago
still blurry for me
I just did it on my tablet and it's all good. This is the first blurry pic in Eddy's post. And now the rest of them from that post.
etyu, jbanks15, Avel Du and 2 others like this.
LEN
(Moderator)
Old 4 Weeks Ago
Great Len! see if you can do the same for the other 2 threads
broomstick
and ctek quick connect
i will email u the links as they are removed from those threads
Old 4 Weeks Ago
broomstick
No can do. Those re- posted pics are not accessible, I guess because they are from a different time? Dunno but they're stock generic PB pics not SLK pics.
I might have some broomstick pics saved elsewhere but they're not available to me at this point in time. Definitely don't have the battery pics.
LEN
(Moderator)
Old 4 Weeks Ago
you did the best you could do
Old 4 Weeks Ago
There are multiple broomstick pics further down in that thread. All show.
https://www.slkworld.com/slk-r171-cl...ification.html
LEN
(Moderator)
Old 4 Weeks Ago
not photobucket pics i assume without checking
Old 4 Weeks Ago
Correct.👍 IIRC forum-stored pics
LEN
(Moderator)
Old 4 Weeks Ago
My apologies. None of the images were stored in the old digital camera and they were uploaded to PB.
