ELECTRONIC STABILITY CONTROL MALFUNCTION: Suspension:Automatic Stability Control (Asc) - Mercedes Benz SLK Forum
SLK R170 Service Campaigns (TSB) This section is for any valid technical service bulletins (TSB) or service campaigns.
  • 1 Post By Salvador Martinez
#1 Old 3 Weeks Ago
Salvador Martinez's Avatar
Vehicle: 2001 MERCEDES SLK230
Arrow ELECTRONIC STABILITY CONTROL MALFUNCTION: Suspension:Automatic Stability Control (Asc)
today i called NHTSA and put my complaint on ELECTRONIC STABILITY CONTROL MALFUNCTION: Suspension:Automatic Stability Control (Asc) which we all know if it has append to you the sudden, unexpected change in vehicle speed and direction. so they told me to ask everyone that has this issue to open a complain the more there is they can open a case and make Mercedes Benz do a recall.last time this issue was looked at was back on 2017 and not a lot of people knew where to complain so the case got closed..so pls people take some time to put a complain and may be we can have money back if u already fixed it or get it done free..thank you
ELECTRONIC STABILITY CONTROL MALFUNCTION: Suspension:Automatic Stability Control (Asc)CLOSED no recall issued
2000 MERCEDES-BENZ ML320 -- ODI opened PE07-007 after receiving 4 complaints within a 6 week period alleging incidents of uncommanded brake application in model year (MY ) 2000 through 2001 Mercedes M class sport utility vehicles. Information contained in the reports or gathered in subsequent consumer interviews indicated that the incidents were caused by faults in the electronic stability program (esp) system which were repaired by replacing the yaw rate sensors. Although the same yaw rate sensor is used in approximately 800,000 other Mercedes M-class, C-class and slk models, to date there has been only one related complaint to ODI in those vehicles. During this investigation Mercedes Benz provided ODI with 327 complaints related to the esp system in the MY 2000 through 2001 M class vehicles. Seven of the complaints submitted by Mercedes alleged incidents of uncommanded brake activation while driving, with two of these involving vehicles identified in the ODI complaints. None of the incidents resulted in crash or injury. However, the owners did express safety concerns due to the sudden, unexpected change in vehicle speed and direction. On May 10, 2007 Mercedes Benz met with NHTSA to provide a technical presentation and conduct a driving demonstration of the esp system performance with simulated electrical faults in the yaw rate sensor. Mercedes showed that the esp system is programmed to diagnose electrical faults and that brake applications resulting from yaw rate sensor electrical faults are very short in duration (0.3 seconds or less) and do not affect vehicle control or stability. Nine of the consumer complaints to ODI and Mercedes alleged brake activations longer than 0.3 seconds, with several alleging that the incident lasted until the vehicle came to a stop. A complaint vehicle that alleged multiple incidents was evaluated by ODI at the Vehicle Research And Test Center (VRTC) in East liberty, Ohio. VRTC was unable to duplicate the condition. Due to the low complaint rate and only one new complaint to ODI or Mercedes since January 2007, this investigation has been closed. ODI will continue to monitor complaints in the subject vehicles and other Mercedes products using the same yaw rate sensor and Mercedes will provide updates on field experience (complaints, field reports and warranty claims) through the end of 2007. Investigation was initiated on February 01 2007. Closed on July 11 2007. For detailed information & supporting documents, see the official NHTSA page concerning investigation #PE07007 »
Last edited by Salvador Martinez; 3 Weeks Ago at 11:23 AM. Reason: miss spelled words
Salvador Martinez is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R170 SLK Class Cars > SLK R170 Service Campaigns (TSB)
