Tail Light Recall - Mercedes Benz SLK Forum
SLK R170 Service Campaigns (TSB) This section is for any valid technical service bulletins (TSB) or service campaigns.
 5Likes
  • 1 Post By Carl Beck
  • 1 Post By wallew
  • 1 Post By dennispymm
  • 2 Post By bryantMoll
#1 Old 02-28-2014
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Tail Light Recall
There was a recall on tail lights and at this time it might be closed. Check with dealers in USA.
Gbarringer100 is offline
#2 Old 10-09-2014
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Find recall campaign for your Vehicle
Mercedes-Benz USA
This will also allow you to look up any prospective purchase VIN numbers and confirm if the vehicle recall has been serviced by MB-USA and if/when it was completed.
slk320chick is offline
#3 Old 12-09-2014
Vehicle: 2003 slk32
Thank you for the info
mardarati is offline
#4 Old 03-07-2016
Vehicle: My wife's first 'fun car' 2002 SLK 32 AMG
Other Toys: 2007 Dodge Magnum Police Interceptor
Quoted: 16 Post(s)
It's funny, but my wife's SLK 32 AMG was recalled and the tail lights done back in 2007.
Now in 2016, we are doing them AGAIN.
Total price shipped was $395 for both sides, complete with sockets and bulbs.
Not too bad. Either I or my mechanic will install them. Shouldn't take half hour per side.
A rattlesnake in the living room tends to end all discussion of animal rights. "Vengence is mine" sayth the Lord, but sometimes he subcontracts...
wallew is offline
#5 Old 03-22-2016
Vehicle: 1999 SLK 230 "Sport"
Quoted: 26 Post(s)
Some questions - of course:
Who is "we"? the Dealer/MB and you, or you and your mechanic?
Why do they have to be redone again? Same problem or different problem?
thanks,
Carl B.
Wago likes this.
Carl Beck is offline
#6 Old 03-22-2016
Quoted: 16 Post(s)
thanks,
Carl B
Carl,
OK, the 'we' is basically my wife and I. I purchased the two replacement tail lights from an online MB dealer I've used several times now.
So I guess you could add that MB dealer into that 'we'.
But since I turned 60, the wife doesn't require ME to do the work any more. Our mechanic is super, mainly working on my stuff (chevys & dodges) but he has also done work on HER SLK32 AMG as well. He replaced BOTH tail lights in a cold light rain while the car was under the awning in less than ten minutes and then tried to wave his fee, which I had to put my foot down.
I pull my own freight OR pay for it to be pulled these days, anyway.
So I guess that the 'we' is all four. ME for ordering the parts and knowing which dealer to use, My wife for owning the vehicle, the online MB dealer for the part and my mechanic who first discovered the issue and then put in the replacement parts that I got for him.
I hope that helps.
wallew is offline
#7 Old 03-25-2016
Quoted: 16 Post(s)
Carl,
Sorry, I only halfway answered your question.
The problem is, the tail light buckets get 'soft' over time and usage. That allows each bulb to twist in their sockets and NOT connect to the power source.
After receiving the replacement buckets with bulbs, I was impressed with their design.
The fact that the buckets replaced in 2007 had to be replaced again because they had deformed (you could see where it had sagged just a little bit) is a testament to their design, but not the plastic used in their manufacture.
Hopefully the ones we put in last week or so won't only last for five years - hopefully they will last at least the nine years like the replacement set lasted. And if they do need to be replaced. we will buy another set. $400 for a complete with bulbs set spread over nine years is less than $50 a year in maintenance costs.We can afford that price.
Hey, it IS a 2002 SLK 32 AMG. - EVERYTHING ON THIS CAR is more expensive than any other car we have owned except my 1978 911 SC Porsche I owned back in the 80's.
European cars just cost more (we've owned a SAAB as well) to maintain. You know that going in. Or you should know that before you purchase one.
Carl Beck likes this.
wallew is offline
#8 Old 03-26-2016
Vehicle: 2001 SLK 320 Silver
Other Toys: Fletcher Zingaro Powerboat (520hp)
I had the same problem on my 2001 SLK 320 soon after I first purchased it back in 2005. Both sides indicating a bulb gone. I removed the light cluster to find the bulb contacts had burnt through. The best remedy and the cheapest (practicallyŁ0)was to file off the burnt metal down to clean steel and build up a solder blob over the hole. I haven't had a problem since (11 years!).... the local MB dealer recommended replacing both light clusters @ appx Ł160 each!!!! No thanks, if the problem does reappear I shall just add a bit more solder. It's so nice to find simple, effective and cheap solutions. Hope this is useful to all you SLK owners.
Okkie likes this.
dennispymm is offline
#9 Old 03-26-2016
Vehicle: SLK200 Blueefficiency AMG Sport 2012
Quoted: 62 Post(s)
Yep. It's also worth mentioning that the recall only applied in the US - not Europe!
godfather is offline
#10 Old 03-26-2016
Quoted: 26 Post(s)
Carl,
......{snipped..cjb}....
Hi wallew - I just got the notice today, that you had added a reply 4 days ago. So I'm a little late in responding.. Thanks, for taking the time to explain what happened. Now I'll know what to watch for..
Carl B.
#11 Old 03-27-2016
Quoted: 16 Post(s)
You will get a 'yellow' light bulb like warning light on the lower right of the dash. My wife said it was 'the sun'.
But it's lower right of the dash board and it did not go away until the light bulbs were screwed in a certain way That is what caused my mechanic to look closely at the light buckets and discover they was an ever so slight ripple in the black plastic part, not the lens.
That when he started looking for recalls and found the one issued back some time in mid 2000.
$400 later, it's all fixed and worth every penny.
wallew is offline
#12 Old 04-18-2017
bryantMoll's Avatar
Vehicle: 2002 SLK230
Quoted: 7 Post(s)
Below are some photos of a damaged assembly, Particularly the brake light circuit. The damage created was deep pitting at the contact point of bulb housing.
Final image is my repair.
Obviously not a correction to the actual problem, but it should temporarily correct functionality.
bryantMoll is offline
#13 Old 04-20-2017
snoopykissedlucy's Avatar
Vehicle: 2004 Mercedes SLK230
Quoted: 8 Post(s)
Thank you bryantmoll for the pictures!
Every now and then, I get the sunburst warning light too.
I checked my VIN online and the Safety Recall #2006080005 showed up.
I called the Stealership and they say there is no recall showing up in their system.
I mentioned this Safety Recall number. The lady repeats that there is no recall in their system under my VIN number.
Does this mean the recall was already performed? Or the recall didn't apply to my specific vehicle?
(she didn't answer either of these two questions)
PS- Stealership wants $425 for a replacement key transponder!!!
snoopykissedlucy is offline
#14 Old 04-21-2017
Quoted: 16 Post(s)
I recommend that you contact the North American Mercedes Benz office.
Explain the situation. AS LONG AS YOU CAR HAS NOT HAD A NEW SET ON THIS RECALL, they should give you a new set for free.
I paid over $400 for the pair, but my wife's care DID have a set replaced for free by the dealership. They don't do the recall twice. But if your vehicle has NOT had a free set put in, they should give you a set for free.
Just my .02 - good luck
wallew is offline
#15 Old 11-06-2017
bryantMoll's Avatar
Quoted: 7 Post(s)
UPDATE: Just received this info from MBUSA:
Dear Bryant,
Thank you for your email to Mercedes-Benz USA.
The recall #: 2006080005 was performed on your car on 4/19/07 at 53,110 miles and is closed.
There are no open recalls or service campaigns available at this time for your 2002 SLK230.
We appreciate the opportunity to respond. Have an enjoyable day.
Sincerely,
Debbie A.
Mercedes-Benz USA
-----------------------The photos attached to the original post we're of the updated lens! OBVIOUSLY the update was not a viable repair or correction------------- So-far no troubles with my repair.
#16 Old 11-06-2017
6007.us
Padgett's Avatar
Quoted: 556 Post(s)
You can take your VIN and go here to check (mentioned in post #2 ). Mine has been done and when I had one out it looks new.
Padgett is offline
#17 Old 04-28-2019
Vehicle: Current: 1999 SLK 230 Sport, 5 speed Future: 2007 SLK 280 6 speed
Other Toys: 1969 Mustang
The tail lamps on my 1999 were replaced before I purchased it. I tried soldering the plastic connectors, but this fix only worked a few months for me. I got a little more aggressive by drilling a hole through the smaller plastic guide and the inner plastic base itself. I installed a sheet metal screw in the hole to form a more solid connection between the bulb circuit board and the plastic assembly. a $1 repair.
https://jsuiha.bn.files.1drv.com/y4m...&cropmode=none
slk230_itch is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R170 SLK Class Cars > SLK R170 Service Campaigns (TSB)
SPYDER Headlights Durkatlon General Modifications R171 374 08-27-2018 08:33 PM
Tail Light Saftey Recall SLKman SLK R170 General Discussion 28 03-20-2017 10:27 AM
New Tail Light Installation XOFMOT SLK R170 class DIY 11 05-22-2016 05:41 PM
Any Reliable R170 Aftermarket Brake / Tail Light Assembly ezeman200x SLK R170 General Discussion 4 05-25-2013 04:44 AM
Tail Light Tinting...How to? chuenwing General Modifications R171 2 09-18-2008 07:03 AM
