Fuel pressure regulator? - Mercedes Benz SLK Forum
#1 Old 10-19-2013
Vehicle: 2002 SLK230
Looking at what I think is the pressure regulator attached to the fuel rail I cannot see a fuel return pipe, which I understood was how the regulator bled off the excess pressure. The device has a part number on it A111 078 0392. Is this the pressure regulator and if so how does it work without a return pipe?
The car is 2002 SLK230 auto UK spec.
BlueMachine2.3 is offline
#2 Old 10-19-2013
Quoted: 6496 Post(s)
Diaphragm fuel line pressure damper A111 078 0392
#3 Old 10-19-2013
if you post your vin, i can get you a datacard.
#4 Old 10-19-2013
Here ya go!!
#5 Old 10-19-2013
part 80 pressure sensor
#6 Old 10-20-2013
Does anyone know if I have a pressure regulator as well as a damper?
#7 Old 10-20-2013
Quoted: 903 Post(s)
I don't have any info or really know anything about your engine (I have a 171) but a damper and regulator do different things. In my car at least, the regulator is part of the filter assembly in the tank -- there is no return line from the rail as with many FI systems. I'm guessing you have both a regulator and a damper in your car, but I can't say where they are exactly (sorry).
What led you to your original post?
efair is offline
#8 Old 10-20-2013
During the summer after a long run if I started the car after 1/2 to 1 hour I had to crank for an extended time before it fired. A friend, who was a test engineer with a German car company, thought it might be losing fuel rail pressure from a leaking injector or faulty regulator allowing a gas bubble to form. I don't really need to fix it but wondered how expensive a regulator was and how easy to replace as I assume an injector(s) would cost more.
#9 Old 12-07-2013
Update which may help others. The problem got worse and had to be solved. My 2002 has a pressure regulator in the fuel filter, changed the filter and problem solved . Seems Unipart fuel filters have a known problem, mine had only done 5K miles since it was fitted during a service.
The Following User Says Thank You to BlueMachine2.3 For This Useful Post:
#10 Old 02-10-2014
Sorry guys, had to revive an old thread.
Started the car today and smelled gas... Thought to myself hmmmm... maybe just moist and smell from the exhaust pipe got into the cabin by accidentally opening the door...
Drove it to pick up my wife and came back and she smelled gas...
I disconnected the battery and started smelling =))) Sounds stupid but it's gas after all...
Found that my fuel pressure regulator was leaking badly.... Perhaps again rubber seals got bad...
Ordering a new one. Replacement should be piece of a cake and I will post pics later.
I think I'm going to get a fire extinguisher =))) just in case, who knows, right? =)
Wont start no fuel pressure giossoj SLK R170 General Discussion 21 12-23-2015 07:02 PM
Fuel Pressure test questions Nine SLK R170 class DIY 22 08-31-2013 03:17 PM
Fuel Rail Pressure ??? Steve Karr SLK R170 General Discussion 0 08-08-2013 07:05 PM
Fuel pressure damper (regulator) leaks.. Mantist SLK R170 General Discussion 2 01-31-2011 11:02 PM
