Quick PSE Question - Mercedes Benz SLK Forum
  • 2 Post By LoveMeSomeSLK
#1 Old 10-17-2013
Vehicle: 1999 SLK230
Quick PSE Question
To start; after a really heavy rain, for the first time, my SLK alarm started going off at random. Every time I shut it off, locked it, walked away, it would come back on. I immediately suspected PSE; and when I took a brief look, there was a decent sized puddle under the foam box.
I've never removed my PSE, so the removal/cleaning/etc. will be a first for me. But, I was reading a few forums, Benzworld, Slkworld, and a couple others. Some people say they removed their PSE without disconnecting the battery and that it wasn't necessary. This seems odd to me as it is electrical; I would assume it is a MUST to disconnect the battery first.
The only plus of not disconnecting the battery would be not having to get my radio reset/code. May seem like a really dumb question; just wondering for those on here who have done this; is it necessary to disconnect the battery?
LoveMeSomeSLK is offline
#2 Old 10-17-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
When you remove and clean it , you might want to look into inverting it to reduce further problems !
curro101 is offline
#3 Old 10-17-2013
I'm definitely planning on inverting it; but still wondering - is it necessary to disconnect the battery before removing/re-installing it.
If not, it saves me a trip to the dealer for my radio code, if so, then I'll obviously do it properly. Thanks!
#4 Old 10-17-2013
Quoted: 6496 Post(s)
call your dealer up, supply what they need to give you the code or contact mercedes online
#5 Old 10-17-2013
I appreciate both of the responses; but neither really replied to my question.
Is it necessary to disconnect the battery before you remove the PSE? Thanks.
#6 Old 10-17-2013
I would.....why take a chance on an errant spike.
or wait for our resident r170 experts to chime in
#7 Old 10-17-2013
JiminFL's Avatar
Mercedes really protects the wiring very well. The most you will probably do is to blow a fuse. No big deal. But with the connectors they use, that would be unlikely, also. If re-coding the radio is that big a deal for you, then try it without disconnecting the battery. On the other hand, you might as well get the code for the radio now since you will have to replace the battery at some point anyway.
JiminFL is offline
#8 Old 10-19-2013
Quick update; getting it out was a breeze. To be safe, I went ahead and disconnected the battery. The pins were pretty badly corroded. One pin from the white connector completely fell out. And the board had green crap all over it. It was not pretty.
So, I took the board out, cleaned it with contact cleaner, pushed out the remainders of the old pin; took a sewing pin, clipped it to match the size of the broken pin, soldered it in - and all looked well...So, I cleaned it up, bought some 0.17" ID tube (1/4" OD - Sorry for the type-o previously!!!) from lowes for 32cents, flipped the PSE upside down, stuck it back in. And all is well. - Aside from the scare of the car running really weird for about 5 minutes after having the battery disconnected overnight. But, that went away once the car 're-learned' everything.
So, yeah...even if your PSE was covered in corrosion, missing pins, etc. it may be salvageable. It's not a tough job either. Just thoroughly clean the traces on the board with a tooth pick, make sure nothing is grounding anything else out, and you should be set.
curro101 and JiminFL like this.
Last edited by LoveMeSomeSLK; 10-28-2013 at 12:58 AM. Reason: CORRECTION TO TUBE SIZE - It is 0.17" Inner Diameter!
The Following User Says Thank You to LoveMeSomeSLK For This Useful Post:
Quick Question Algebal SLK R170 General Discussion 4 02-23-2013 01:51 PM
AMG Fog light replacement, quick question! li174 Performance MODS for the R171 3 07-02-2012 05:35 PM
Quick question - Jmjumper AMGs 32 12-08-2007 01:55 AM
