Oil filler cap - Mercedes Benz SLK Forum
 7Likes
  • 1 Post By gdb069
  • 2 Post By gdb069
  • 4 Post By PaulXLE
#1 Old 10-17-2013
PaulXLE's Avatar
Vehicle: SLK 230 Kompressor R170 auto 1997 in Imperial Red
Other Toys: Mostly computers, lots of them, opening a museum one day, maybe.
Quoted: 8 Post(s)
Question Oil filler cap
Um, I'm going to sound like a weed here, but...
is there a secret to removing the oil filler cap (1997 SLK 230K R170)
I suffer from arthritis and my grip is not what it was, but even so, mine won't budge!
do you press down and turn, perhaps, or is it just simply turn and off?
any suggestions as to how to free a stuck one!?
( - failed at first hurdle!)
PaulXLE is offline
#2 Old 10-17-2013
Vehicle: 2000 SLK 230
Quoted: 34 Post(s)
I used to work at an oil change and lube shop. I'm not a very big guy, of average build, so there would be times that I would come across an oil cap that was tightened too much. I would grab an oversized pair of pliers, put a rag over the cap as to not scratch it, gently grip the cap, then turn. normally the pliers would be able to do the trick, and everything would be good
SirClass is offline
The Following User Says Thank You to SirClass For This Useful Post:
#3 Old 10-17-2013
Vehicle: 2001 SLK 320
The MB oil caps are very tight. I have found that it is easier for me to remove the air filter/engine cover.. You need to push straight down and twist. For some reason, could be my RA as well, I find that I cannot get the right angle to push down and not hit the engine cover, thus, I remove it and then have no problems getting it off.
DIYGirl is offline
The Following User Says Thank You to DIYGirl For This Useful Post:
#4 Old 10-18-2013
leapyfish's Avatar
The secreet is to get a oil cap wrench.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#5 Old 10-19-2013
PaulXLE's Avatar
Quoted: 8 Post(s)
Cool
No, actually I just bought one of those, but that's for the oil filter
I'm talkin' about the filler cap, on top of engine
I haven't got a device that's wide enough to help with this
maybe I could invent one, and make lots of money selling it (don't tell anyone!)
PaulXLE is offline
#6 Old 10-19-2013
Vehicle: 2005 SLK350 MT
Quoted: 19 Post(s)
I find wearing a glove to remove tight lids/caps increases my strength to superhuman levels.
BarrySLK280 likes this.
gdb069 is offline
#7 Old 10-19-2013
IronMan gloves?
#8 Old 10-21-2013
Quoted: 19 Post(s)
Originally Posted by etyu View Post
IronMan gloves?
etyu and ajberrow like this.
gdb069 is offline
#9 Old 10-24-2013
PaulXLE's Avatar
Quoted: 8 Post(s)
Thumbs up Found a tool!
Just to lay this to rest, I did find a tool, pictured, lying at the back of a cupboard.
It's really for getting the tops off jars, but it worked perfectly at getting the filler cap off, and with no damage to anything too
etyu, slk320chick, DIYGirl and 1 others like this.
PaulXLE is offline
The Following User Says Thank You to PaulXLE For This Useful Post:
#10 Old 06-10-2016
Vehicle: 2001 SLK 230 auto
Does the oil filler cap on the top of the rocker cover / top of engine screw off anti clockwise ? Mine is on so tight I can't move it to get it off. Please help.
GEORGI is offline
#11 Old 06-10-2016
Yes........ it sure does screws off anticlockwise.....no need to push down on it just use a a rag and an adjustable wrench if tight.
GEORGI is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Leaking oil filler cap Chevytriker SLK R170 General Discussion 7 12-02-2014 12:37 AM
Best oil cap? BatMobile Performance MODS for the R171 8 03-07-2013 02:13 AM
