Removing Carpets - Mercedes Benz SLK Forum
#1 Old 10-15-2013
robinpompey's Avatar
Vehicle: slk 200 amg (2000)
Other Toys: MGB Roadster (Jan 1963), Motorhome
Removing Carpets
R1704442F201019
Can anybody help me. I have tried using the WIS system but I am unable to determine what I need to do to remove the carpet from the passenger side. The carpet got wet when the drain holes were blocked, and I would like to remove the carpet to dry it out completely.
robinpompey is offline
#2 Old 10-15-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
If it's anything like the R171, it's not a trivial job - you need to remove virtually the whole of the interior - seats, dash, centre console, various trim parts etc. etc.
Woolly is offline
#3 Old 10-15-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
Get a tall large fan and leave it on for a few hours, that should do it. I highly recommend the baking soda from arm&hammer for pets as well. That will deodorize nicely.
slk320chick is offline
The Following User Says Thank You to slk320chick For This Useful Post:
#4 Old 10-20-2013
Vehicle: 2002 SLK 230 K tip
Other Toys: Skoda fabia TDI
Use a fan heater it may require a few hours but it will work.
HZ123 is offline
#5 Old 10-21-2013
Majestic's Avatar
Vehicle: SLK 230 Kompressor , 2004 year of production (facelift)
totally agree use fan heater
Majestic is offline
#6 Old 10-21-2013
Quoted: 11 Post(s)
its not the carpet that holds all the water but the very thick soundproofing beneath if you move the seat all the way back and remove the plastic trim from the door step area you may be able to lift the carpet enough to dry the soundproofing under there out
beerbelly is offline
#7 Old 10-21-2013
Vehicle: 02 230
there is thick foam under the carpet that saturates and stays wet. i don't thing a fan will get to it. take out the door sill, the kick panel. remove the radio, faceplate, and screws under it, take the screws out of the console and lift it. also remove the front sides of the console. both sides of the carpet are 1 piece. it's not mercedes recommended, but I cut it in half at the console so I can take each side out separate.
wolf! is offline
The Following User Says Thank You to wolf! For This Useful Post:
#8 Old 10-21-2013
Quoted: 11 Post(s)
I did that in an old ford xr3 after a valeter cleaned the carpets with a steam cleaner if you cut behind the centre console it cant be seen when all back together. the foam took 3-4 hours hanging of a panel stand in front of a waste oil burning stove before they felt even remotely dry
#9 Old 10-22-2013
I was able to pull the carpets back enough to remove the foam insulation to dry separately. I must admit I did consider a cut to the carpet along the gear box housing and placing back with double sided tape ?
HZ123 is offline
Removing the plastic body panels jcjefferies SLK R170 General Discussion 8 05-08-2016 10:39 AM
Removing Fingerprints from Tan Interior? SuperSamyon Caring for your SLK 3 10-20-2010 03:28 PM
Removing Secondary CATs, 55 AMG. buckster Performance MODS for the R171 25 05-28-2010 10:31 AM
Help with removing trim where roll bar sits!! MDS General Modifications R171 4 02-20-2009 09:58 PM
Has anyone lowered there car by removing rubber shims? MaKEuhigh AMGs 7 07-15-2008 08:23 PM
