Electrical issue with Fuel gauge - Mercedes Benz SLK Forum
  • 1 Post By marlonm
#1 Old 10-13-2013
Vehicle: 1998 SLK 230
I have a 1998 SLK230 and removed the instrument cluster to replace some burned out bulbs. Upon re-install everything worked fine except the fuel gauge which simply didn't move. To trouble shoot the issue, I measured resistance at the connections on the fuel sending unit at roughly half full (38 ohms) and full (1 ohm). This seemed to indicate to me that the fuel sending unit was doing the right stuff so I assumed it was the instrument cluster. I replaced the instrument cluster but have the same issue - all gauges in the cluster work except for gas gauge. I don't know the pin-outs on the connector so it's a bit challenging to know how to troubleshoot from here. Does anyone know what the current reading should be at empty or full from the sending unit? Anyone know what pins on the instrument cluster would go to the fuel gauge? I welcome any advice on how to find the source of the problem.
Marlon
marlonm is offline
#2 Old 10-14-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
Marlon,
I have no experience of this with a SLK, but writing from general experience, I think the following things need checking :
. That all wires are seated properly in the connectors. Check that there's not one that's pulled out completely and is hidden inside the dash.
. That none of the wires has broken or pulled loose somewhere away from the cluster.
. That the connectors are clean and properly fitted. Ensure that none of the blades (or whatever constitutes the connectors) are bent.
I doubt that it's the sender, since all was OK until you disconnected the cluster; but of course the process may have caused damage if the system hadn't, for some reason, completely shut off power.
Anthony
ajberrow is offline
#3 Old 10-14-2013
problem solved. The connector at the sending unit was loose I'm guessing. I took it off and made some electrical measurements and then put it back on, the gauge worked again.
slk320chick likes this.
marlonm is offline
#4 Old 10-14-2013
Vehicle: 1997 SLK 230 Kompressor
Other Toys: RC Car
Hi Marlon
May I ask where is the connector for the fuel sending unit, as mine have similar problems.
Many thanks
Leo
bigheman is offline
#5 Old 10-14-2013
Vehicle: 02 230
sorry for the late reply, that's what i found the problem, plug and unplug the thing a few times till it works. BTW if you buy a few spare bulbs as insurance and keep them in your tool box they will never go bad again. ;')
wolf! is offline
#6 Old 10-15-2013
Firm's Avatar
Can someone describe or post a picture of where you can access the plug for the fuel guage....Exact same thing happened to my brother in his `98.
Firm is offline
#7 Old 10-21-2013
You can access the fuel sending unit from the trunk quite easily. The retractable cover in the trunk that must be extended for the roof to go down needs to be removed. It is held on by two bolts. If you remove those bolts with a 10 mm (I believe) socket then the whole piece will pull out. Then you need to remove the carpet piece that sits behind the retractable cover. there are two additional nuts that must be removed (they sit in the trunk below the rear windshield). Once those two nuts are removed, you can pull out that piece of carpet. You will then be staring at the top of the fuel tank and the top of the fuel sending unit will be staring you in the face. There are two connectors. The one on the left at you are looking at it is the one I measured the resistance between at full and empty tank. If you have more questions, I will do my best to answer them.
Marlon
marlonm is offline
#8 Old 11-07-2014
Div
Vehicle: SLK230 R170 '97
Hi, guys!
I have some problems with my gauge cluster. When i bought car (VIN WDB1704471F013431), there was gauge cluster from non cruise control version (my car have it).
I bought 170 540 23 11. When i pluged-in it, fuel arrow lived with it own life But there is no problem with it on non-cruise version.
What reason can be?
Soz for my eng
Div is offline
#9 Old 11-07-2014
Quoted: 6496 Post(s)
Div,
Please update your vehicle (year,ie 2007) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. Your profile is NOT updated in your ‘personal garage’.
Tags
fuel gauge, fuel sending unit, instrument cluster
Faulty fuel gauge stefan SLK R171 General Discussion 33 03-03-2014 09:27 AM
Electrical issue with instrument cluster/fuel gauge marlonm New Members Introduce Yourself Here 14 10-21-2013 12:16 PM
Fuel Gauge Problem curthslk2005 SLK R171 General Discussion 8 05-30-2012 08:44 PM
