blown battery - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Gbarringer100
  • 1 Post By CarolinaBluetec
#1 Old 10-11-2013
Vehicle: 1999 slk 230
Other Toys: zx11 ninja, zx10 ninja zrx1100, sv83 Suzuki
Quoted: 27 Post(s)
blown battery
Hi all, has anyone used a trickle charger and blew the battery? I am between making decision weather to by float charger or use my trickle chargers, I have few of those I use for my motorcycles, if trickle works I don't want to spend the money on float charger, looking at the prices of the c-tec they are expensive, unless someone knows a bran that is lesser expensive and does the work. Thank you all in advance for your input
ardo is offline
#2 Old 10-11-2013
Vehicle: 2003 SLK320 Magma Red
Other Toys: 2001 Vulcan 1500
I use a float for my m-cycle, they're about $30 - it just has to be smart enough to stop charging when the voltage reaches the desired level.
Don't remember the brand, but IIRC I bought it on Amazon (checking now)
spclk is offline
The Following User Says Thank You to spclk For This Useful Post:
#3 Old 10-11-2013
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Check Sears has they have one for 26.99 that has worked for me.
http://www.sears.com/shc/s/p_10153_1...1219000P?mv=rr
Gregg likes this.
Gbarringer100 is online now
#4 Old 10-12-2013
Quoted: 27 Post(s)
blown battery
thank you for the source for float chargers, at this time my question is solely educational; does the trickle charger cause any damage to the battery?, I always connect these to my bikes and I don't see any damage, my fear is that I thought the car battery is more durable there fore I had a maximum 10 amp charger, I connected overnight next morning my battery was blown, I washed the whole area with fresh water and saved from corrosion. This is why I am trying to learn the different types of devices, specially some of the float chargers say; they do not charge the battery, they only maintain charge, what does this means, my question may sound dumb, sorry if you feel this way, just a thought
ardo is offline
#5 Old 10-12-2013
Quoted: 99 Post(s)
A trickle charge is constant low amp. They are chargers you have a full charge they keep sending amps that can do damage to battery. Something like you had with a 10 amp charger.
A float charge again is low amps but has a way of detecting that the battery is fully charged and will stop putting out amps, when the battery drops below the full level it will put on amps again until full charged. Some will work with a low charged battery while some if battery is complete dead will not work. The idea is you have a full charge and just need to maintain while not in use.
If you go either route there is several posts on how to make quick hook up so it is as simple as a hidden plug that you connect or disconnect to use the car. Do a search.
Gregg likes this.
#6 Old 10-12-2013
Used a Battery Tender Plus on My MG that was stored during the winter. No problems. Cost about $55.
Gregg likes this.
CarolinaBluetec is offline
#7 Old 10-12-2013
Battery Tender Jr. is around $20 USD.
R171 Good Practice Tips (Includes Battery Connection Checklist) DansSlk SLK R171 Class DIY 35 08-31-2018 03:16 AM
Battery Trickle Charger pre-wiring install etyu General Modifications R171 79 02-13-2017 03:34 PM
A dead battery...some recommendations for next steps please.. robster SLK R171 General Discussion 15 12-29-2012 01:09 AM
05' 55 AMG Battery size / R&R ? coolsat SLK R171 General Discussion 8 04-25-2011 01:11 AM
Solar battery charcher/maintainer mod Theregans General Modifications R171 5 01-05-2011 12:58 PM
