Battery Draining - Mercedes Benz SLK Forum
  • 1 Post By leapyfish
#1 Old 10-11-2013
Vehicle: 1997 R170 SLK230
Battery Draining
I have recently replaced my battery, it was 8 years old and for some reason had lost its charge.
Upon replacing the battery my car started first time, however two days later the new battery was completely dead.
Just before I replaced the battery I noticed the central locking had stopped working, could this be cause of my battery drain?
Thank you in advance.
DirtySouth is offline
#2 Old 10-11-2013
Could be a problem related to PSE corrosion, or a shorted alarm siren which could drain battery (or blow F9 which will kill locking). This looks like you need to get the codes read by MB dealer or Indy with comparable package.
CarolinaBluetec is offline
#3 Old 10-11-2013
leapyfish's Avatar
You should also have the alternator checked.
Der Flieger likes this.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#4 Old 10-11-2013
Thank you for you reply, the last thing I had replaced was the alternator.
Excuse my ignorance what is PSE short for? I had a quick Google and come up with an interesting alternative
#5 Old 10-12-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
Pneumatic System Equipment, I believe.
On the right side, on the floor of the boot/trunk, tucked in under some of the plastics, wrapped in foam, you will find a pump and some electronics which control not only the pneumatics, but several other items as well.
The positioning of the unit results in the circuits getting wet if any water gets into the boot/trunk, resulting in corrosion of the board and failure of several sub-systems. Taking the unit out and cleaning the contacts can have a beneficial effect.
Search for PSE (Search is at top right of page) and you'll find dozens of threads about what can go wrong if the electronics are damaged.
There is a fix for the corrosion problem - lengthen the pneumatic hoses and mount the unit upside-down so that water can't get onto the circuit board.
You'll see lots about that in the search results. Be careful to connect the pneumatic pipes correctly after lengthening them.
ajberrow is offline
R171 Good Practice Tips (Includes Battery Connection Checklist) DansSlk SLK R171 Class DIY 35 08-31-2018 03:16 AM
What is draining my battery ?? pjgraham86 SLK R171 General Discussion 25 04-01-2018 02:45 PM
Battery Trickle Charger pre-wiring install etyu General Modifications R171 79 02-13-2017 03:34 PM
05' 55 AMG Battery size / R&R ? coolsat SLK R171 General Discussion 8 04-25-2011 01:11 AM
