SLK 320 Loss of power - Mercedes Benz SLK Forum
#1 Old 10-09-2013
Vehicle: Mercedes SLK 320
Hello,
Can anyone tell me what my problem might be?
...I will be driving along and then have no power, if I pull over, turn off the engine and turn it back on again, it will work fine.
...I will be at a red light, when it turns green, there is no power, and I have to turn off & on again for it to work fine.
...I will have my foot all the way down on the exelerator and the car is moving but at about 10 miles an hour and then kick in to about 30.
I have recently had a service on the car (£1,300.00) and they didn't mention any problems with the accelerator.
The car is an automatic W reg.
Before I go back to my mechanic...Any ideas? Is this normal?
Appreciate any help here.
Sandy
Sandy is offline
#2 Old 10-09-2013
Quoted: 6498 Post(s)
Sandy,
moving to the r170 general discussion from UK section as other in other countries might be able to help
#3 Old 10-09-2013
Minion
slk320chick's Avatar
Quoted: 148 Post(s)
https://www.slkworld.com/new-members-...need-help.html
slk320chick is offline
#4 Old 10-18-2013
Vehicle: slk 320 Auto
I cannot find the answer to this one and have the same problem - what was the issue.
Regards
John
jvcarrier is offline
#5 Old 10-18-2013
John,
#6 Old 10-18-2013
Vehicle: 2001 SLK 320
Sandy, as part of the service, did they clean or replace the MAF? What did they do this service? Change the plugs and wires? Did you go to the dealer or a local indy? The reason I ask this is that the dealership will have a STAR system that can read all sorts of issues, the local indy will only be able to read engine and transmission issues.
Are you getting a CEL?
After you hit 30, does it accelerate normally?
Any backfiring?
If you accelerate using a light foot, not all the way to the floor, does it hesitate, does it get up to speed faster?
How many miles on the car?
Are you using high end gas? Premium with cleaners/additives in the gas?
Ever tried using a fuel injector cleaner?
John, if you want to provide the same info, we will help you work through it.
DIYGirl is offline
#7 Old 10-18-2013
ajberrow's Avatar
Vehicle: 2001 R170 230K
Haven't I seen these symptoms in other posts when the K40 needs resoldering or replacement?
Not been here long, so I may be misremembering some of the hundreds of threads I've looked at.
Does the 320 even have a K40?
ajberrow is offline
#8 Old 10-19-2013
Quoted: 903 Post(s)
Only if your indy doesn't have the equipment -- you should ask 'em.
efair is online now
#9 Old 10-21-2013
Thank you all for your advise, I think this is now resolved I had a sensor looked at £250, and for the moment everything is ok.
Sandy is offline
#10 Old 10-21-2013
nimbusgb's Avatar
Quoted: 252 Post(s)
Sandy, you really need to spend more time here! You've spent nearly £250 on a problem that could have been solved for around £50 I suspect!
Wow £1300 for a service! That hurts!
nimbusgb is offline
A 'Who's Who' in SLKWorld.com Woolly New Members Introduce Yourself Here 4 1 Week Ago 11:59 AM
P0123 code - Loss of power in 02 320 twowheelin SLK R170 General Discussion 9 09-10-2017 11:02 PM
SLK 320 Virgin garagegods New Members Introduce Yourself Here 18 10-14-2009 03:30 PM
