automatic transmission advise needed - BIG PROBLEM - Mercedes Benz SLK Forum
#1 Old 09-23-2013
dan2c1's Avatar
Vehicle: SLK 230 1998
Quoted: 14 Post(s)
I just bought an slk 230 1998 and it worked fine for a few days, but then the D gear did not have a lot of potence and it stopped working...i parked the car in the garage for the night. The next morning i noticed the transmission fluid was a little low so i put 2 quarters of transmission fluid in it. Everything seemed fine, i took it for a quick drive around the block and then all the gears went dead. I pushed the car forward and notice a big transmission fluid spill on the floor, a really big puddle.
The mechanic told me it was losing fluid through the little round shaped black breather valve located on top of the transmission...the side that's closer to the engine. We did replace the part, wich apparently was missing the lower connector (the inner part of the breather)
However this did not solve the problem... now it is dripping oil trough the other hole. This car has no oil meter for the transmission, so i wonder if the excess fluid was the cause of the massive fluid spilling.
So, my question is..
-Has anyone experienced something similar? Any ideas on what might be going on?
- Does anybody know the exact amount of transmission fluid that this car requires???
I don't want to take it to the mercedes dealership because here in costa rica it's probably going to cost me more than the car itself.
I would really appreciate some help !!
THANKS!!!!
Last edited by dan2c1; 09-23-2013 at 08:48 PM. Reason: forgot to include important info
dan2c1 is offline
#2 Old 09-23-2013
Quoted: 6498 Post(s)
moving to the r170 general discussion section
The diy section is for already made diys
Someone will respond if they can assist and answer your questions
#3 Old 09-24-2013
THANKS!!!!
Hi. Sorry to hear about your troubles. You have to remember that too much tranny fluid can be as harmful to your transmission as too little... Same as engine oil. When it's cold it reads one level and when it warms up it enlarges. Perhaps that's what happened with you. You put too much fluid and it had nowhere to escape from and popped a hose.
I'd advise to invest in the transmission dipstick tool:
http://www.ebay.com/itm/Mercedes-Ben...60aed1&vxp=mtr
It's not that expensive and you can measure your fluid from time to time.
The Following 2 Users Say Thank You to JaysonM For This Useful Post:
#4 Old 09-24-2013
Wheels52's Avatar
Vehicle: 1998 SLK Black Opal
Other Toys: 2010 SV6 Commodore 210kw, 4.7 Mtr Runnabout
That series is renowned for a leaky wiring plug on the right front of the transmission there are a couple of posts on how to fix the problem.
A inexpensive alternative to the MB Transmission dipstick is to go to your nearest motor vehicle recycler and purchase a transmission dipstick of the longest length/type in stock then measure up from the end of the dipstick and mark it with the relevant medasurements (avaliable in a post within this site) then run the transmission up to temperature and check the fluid level.
There is a post that gives cold and hot temps and fluid levels.
This is the method i used when I performed my own DIY repair.
[SIGPIC]Old but not broken!!
Wheels52 is offline
The Following User Says Thank You to Wheels52 For This Useful Post:
smartTOP installed, now big problem Rotatus SLK R172 General Discussion 17 07-13-2018 02:22 PM
Looking to get a used AMG 55 - Advise needed? Ruleman AMGs 28 10-20-2011 12:41 PM
Transmission Problem heezyo2o SLK R171 General Discussion 14 04-08-2009 11:26 PM
Help! Can Comfort Vario Roof Module cause Transmission Problem? ericmb SLK R171 General Discussion 12 04-19-2007 02:01 PM
